Right I have come to a decision
I have decided to paint  :o
I will do it the Caldercraft matt white
I am fairly happy with the planking but it is far from authentic with it's points etc so I think it will be better and more realistic to have the white paint finish as a lot of the Endeavours have including the replica  B)
I will get the hull finished and then do the base painting, the Blue, middle staining and the white hull, then I will add the strakes and do the black
I think that will work well :dancetl6:
Right off we go, it's good I have come to a decision  :cheers:
Keeping it up  :10_1_10:
Mick
<p><strong><span style="font-family:'times new roman', times, serif;"><span style="font-size:18px;">Keep it up :10_1_10:</span></span><span style="font-size:18px;font-family:'times new roman', times, serif;"> </span></strong></p>
<p><strong><span style="font-size:18px;font-family:'times new roman', times, serif;">Mick</span></strong></p>
<p> </p>
<p><span style="font-size:12px;"><span style="font-family:'times new roman', times, serif;">Current Build --- Will Everard --- </span><a data-ipb='nomediaparse' href='http://modelshipworld.com/index.php?/topic/3636-will-everard-by-micklen32-billing-boats-167/'>http://modelshipworld.com/index.php?/topic/3636-will-everard-by-micklen32-billing-boats-167/</a></span></p>
<p><span style="font-size:12px;">Current Build --- Endeavour --- <a data-ipb='nomediaparse' href='http://modelshipworld.com/index.php?/topic/2804-hmb-endeavour-by-micklen32-occre-154/'>http://modelshipworld.com/index.php?/topic/2804-hmb-endeavour-by-micklen32-occre-154/</a></span></p>
<p> </p>
<p><span style="font-size:12px;">Completed --- Guitar --- <a data-ipb='nomediaparse' href='http://micksjem.blogspot.co.uk/'>http://micksjem.blogspot.co.uk/</a></span></p>
<p><span style="font-size:12px;">Completed --- Barcelona Taxi --- <a data-ipb='nomediaparse' href='http://micklen-taxi.blogspot.co.uk/'>http://micklen-taxi.blogspot.co.uk/</a></span></p>
<p><span style="font-size:12px;">Completed --- London Tram --- <a data-ipb='nomediaparse' href='http://micklen-tram.blogspot.co.uk/'>http://micklen-tram.blogspot.co.uk/</a></span></p>
<p><span style="font-size:12px;">Completed --- OcCre Mississippi --- <a data-ipb='nomediaparse' href='http://modelshipworld.com/index.php?/topic/1803-spirit-of-mississippi-by-micklen32-occre-180-a-hopefully-accurate-rendition/'>http://modelshipworld.com/index.php?/topic/1803-spirit-of-mississippi-by-micklen32-occre-180-a-hopefully-accurate-rendition/</a></span>
Hi Mick,
I will see how it ends when you paint the hull.
You have a smooth surface for that !
Great feeling that you have made the decision?
Hi Mick,
Yes Sjors
I was deliberating a bit and it is good to come to a firm decision
I have sent off for the paint and have a lot of sanding blocks ready
This is how the finished side looks BTW
Mick
<p> </p>
<p> </p>
Thanks for the pictures Mick,
I think that you can get it very smooth.
Only one thing…at the stern, the end where the rudder is gonna be attach, try to get a smooth line from bottom to top.
The planks that starts at the keel and end at the light colour planks.
Yeah I see that Sjors
The judicious use of a scalpel with a new blade  :piratetongueor4:
I got that all in hand  :cheers:
Going to finish the other side tomorrow after having a few x-rays taken of my arthritis so the physios can see what it's like inside
Not had any of the joints for a long while and they want a fresh look  :dancetl6:
Mick
<p> </p>
<p> </p>
Right the planking is done  :dancetl6:
I am hoping the paint will come tomorrow but I do have a lot of sanding to do first
I am very pleased at how the sides look but the bow and stern do let it down a little  :(
Still after a lot of sanding it should be nice and smooth and after an undercoat it should take the white very well
I see in the instructions that a lot of the parts are scratch built so I will really need to take my time there
There is the hull to paint next then the first part of the build are the rubbing strakes closely followed by the gallant rails
I am looking forward to starting building the furniture but my arthritic fingers could do with a day or twos rest I think  :P
Still tomorrow
Sanding  :huh:
Mick
<p> </p>
<p> </p>
Looks really good Mick
I wouldn't rush into the painting. Have a look at other logs - it might be wise to do some other work first. In other words, I'd plan a sequence to work out when painting is "the next step". The paint is the finish and if you damage it during the rest of the build it is very hard to fix (I speak from bitter experience).
Cheers
Alistair
Cheers
Alistair
Current Build -
Cheers
Alistair
I totally hear you Alistair
My problem is I do tend to follow the instructions in the book as it were
What I could do is just the blue paint for now as that will be needed before fitting the gallant rails and then do the strakes and painting when it gets close to starting the bits that go on the hull
I do have a question for you all while I am on
What should the finish of the keel be
Natural wood or black paint or what?????
Thanks a lot
Mick
<p> </p>
<p> </p>
Hi Mick
The main keel should definitely be painted white with the hull. Below is a link to my model of the AVS (I still haven't figured out to link it through my signature....) You can see the effect. Work out a painting sequence allowing for the addition of the strakes and other bits. Painting requires as much patience and thought as all parts and while you'll have to do touch-ups as you go you want to get the sequence right in the first place. I haven't done the Endeavour and urge you to look at the other logs for it and look at the approaches to the sequence. You've got the hull sorted out - take your time and make the rest really sweet!
For masking I'd suggest Tamiya masking tape. I know that lots of others here use it. Properly applied it has no bleed.
Take your time and enjoy.
http://modelshipworld.com/index.php?/topic/392-armed-virginia-sloop-by-aliluke-model-shipways-148/page-1
Cheers
Alistair
Cheers
Alistair
Current Build -
Hi Mick
Cheers
Alistair
Thanks Alistair
That looks perfectly logical looking at your photos and others
It's just working out when to do it
If I followed the instructions it is done next prior to fitting all the strakes, then the gallant boards followed by the transome and rudder
I do get a little nervous going away from the instructions because I worry about missing something until it's too late to put it in satisfactorily
I have done that twice before on other models and I don't want to make a third  :huh:
Looking at the Eaglemoss Endeavour build videos as they do it exactly the same
I have looked at that as we presume it is the same model
http://www.build-endeavour.com/en/guide.htmlhttp://www.build-endeavour.com/en/guide.html
It also looks as if on your build it is not too much different so I think that is the way I will go on
Thanks a lot for the pointers Alistair
It will all come good in the end  :D
Mick
P.S.  To put your AVS link in to your signature just do the same as I have using cut and paste for the addy
Edited by Micklen32
<p> </p>
<p> </p>
Never been known to hold back  :P
Gave the hull a very good rub down
And tried the blue paint and the stain  B)
The blue looks great
The stain is a little darker than I expected but I think it will be good
I used Frog tape which is supposedly totally bleed free
It did bleed a little though but that is not so bad as I need to bring the blue about 5mm lower
I did that just in case it did bleed a little  :D
I have Tamiya tape on the way  ;)
The walnut still needs a little more sanding but my hand and arm was dropping off  :(
I am pleased with the way it looks and when the black strakes are on there it should look real good
Mick
<p> </p>
<p> </p>
Been hard at work today :dancetl6:
Been undercoating the hull and fitting the rubbing strakes one side
Well pleased with how it looks and over the moon that I have it perfect as the illustrations show me
If you look at the stern shot you will see the 3 thicker strakes fitting underneath that curved bit and the thinner one on the side just as the illustrations show so I am well chuffed :cheers:
Still waiting for the tape to finish the painting off properly hoping I have enough white as it doesn't seem to want to go very far :huh:
Tomorrow I will fit the other side strakes and maybe give the blue it's second coat then stain and fit the gallant rails if I have the time
That or give the few humps and bumps on the hull a sand B)
We shall see
Mick
Edited by Micklen32
<p> </p>
<p> </p>
Hi Mick,
I like the blue but ……  personally I don't like that orange.
Maybe is should be darker?
But it is your ship and you are the captain and it is your choice !
You like it, that's the most important thing !
Hi Mick,
Hi Sjors
Thank you
It will be a bit darker as it will have a coat or two more and that will darken, but the blue should stay pretty much the same
The tape didn't arrive today so I have to wait a little longer  :(
May get the gallant rails cut and stained
I will see how I feel
The arthritis is having a bit of a field day or three in my fingers recently  :angry:
Mick
<p> </p>
<p> </p>
Hi Mick,
We have really a sickbay on this forum.
I'm on the way back and I hope you will follow me.
I will wait for the end result of the paint before I give anymore comment …….
Cheers
Alistair
Hi Mick,
you are coming along in leaps and bounds but I got to agree with Alistair about holding off with the white.  I left doing mine until all the man handling was finished with. Now I can safely leave it in the cloth protected cradle to do all the little details and attachments. You have still a lot of manipulating to do with channels and rails etc.
Cheers
Slog
_______________________________________________________________________________________________________________
HM Bark Endeavour (First Wood, On Hold)
Borodino (1:200 Card, Current Build)
Admiral Nakhimov (card 1/200)
Mazur D-350 Artillery Tractor (1:25 Card)
F-8 Crusader (1:48 Aircraft, Plastic)
Hi Mick,
Cheers
Slog
Yes Slog I have to agree with you
I have done some undercoat to see how it looked and I see one or two points that need a bit of work
Once that is done and I have put another bit of undercoat on I will leave the painting until it is necessary
i am wondering if I can fit the rudder before painting  :huh:
The hinges are quite small and would be difficult to paint round easily so I will probably put off fitting the rudder until I have to and use that as my starting line for the white
Mick
<p> </p>
<p> </p>
Right
Been a busy boy today as my hands and fingers were good  :dancetl6:
Have a look how she looks now  :o
I have decided not to paint the white and black until I have to
As you can see the next major job is for me to make the samson posts, pillars etc to go on the gallant rails
Now I do have a question for you all  :)
Should I reinforce these parts with a small pin into a hole in the gallant rail or is that overdoing things and just making sure there is maximum surface for gluing and a spot of CA glue enough ??????
All the items to go on the gallant rail, and there are 74 ish of them  :o are scratch made so that will keep me bust for a day or two so there is plenty of time to get plenty of answers to my question  :P
Mick
<p> </p>
<p> </p>
Hi Mick,
For the rudder I was able to attach mine but it was removable if need be.  When it came time to paint the white, I attached it so I could get the water line to flow straight across the hull and rudder together so the line was...in-line right through.
I left the rudder on to apply the Tamiya masking tape front one end to the other for the same reason as above.  Once this was I done I removed the rudder for masking up and painting separately knowing when I reattach it the paint line will be level across the gap.  Not sure if OcCre allows the rudder to be shipped/unshipped once done.
Cheers
Slog
Hi Mick
Looking good.
As to your question - if there is tension on a part from the rigging in particular, you should use pins as well as glue. If the part fails during rigging you'll regret not having reinforced it. Much easier to pin now and be safe later! If it is not going to be under any stress then CA should do. For the most stressed pieces I also tend to use epoxy glues even though I really hate working with them. Epiglass Epiglue for instance, once cured (that takes 4 days!), forms a bond that will be stronger than the pieces it connects. In other words the wood will fail before the bond does. CA is much more brittle especially if there is not a lot of bonding surface.
Hope that helps.
Cheers
Alistair
Cheers
Alistair
Current Build -
Thank you all for your comments  :)
Slog.  Unfortunately once the rudder is it it is in
However looking at the plans I think it can be left much later than OcCre say
Alistair.  Yes I see what you mean
Looking at all the photos I have seen of the finished model there seems to be nothing putting strain on anything on the gallant rail
All the ropes etc seem to go to cleats or rings
I am not a fan of epoxy and only tend to use them in connection with fishing rods
I don't think contact adhesive is suitable so I may try fast acting wood glue as that will give a solid finish without the brittleness
Anyway at the moment I have my head down  B)
I have 34 of these to make, then lots more posts and other parts  :o
I also want to carve the breakwater as the one in the kit is not great and it's a quite important part
I have a nice piece of bass wood and the Dremel so I should be ok  :P
Mick
Edited by Micklen32
<p> </p>
<p> </p>
Hello Mick,
I've been following your log quietly for the last days.
You are making some great progress.
Make sure you give your hands and fingers some rest in between tasks.
Anja
Those we loved but lost are no longer where they were, but are always where we are.
In the gallery: Albatros 1840 - Constructo
Thank you Anja  :)
Making these small pieces by hand puts a lot of stress on the fingers so I do very few before resting for a bit
I am getting there with the samson posts and columns
I made a skylight to have a bit of a rest and I also carved the breakwater from a piece of basswood, so I am not being lazy  :D  :P
There are other bits of deck furniture I can build to give me a break from the small stuff
I will do some photos tomorrow so you can see how I am getting on
One thing I did find very difficult was the transom surround which in this kit is done with strip layers of a very thin lime veneer
It was difficult because the veneer was so thin the glue was actually coming through it  :o
I think I have it sorted now though and it just needs cutting back and sanding
In the instructions it shows it stained, but personally I think it will look better painted blue, as the transom is
So as you can see I am keeping it up  :10_1_10:
Mick
<p> </p>
<p> </p>
Hi Mick,
Anja is running that fast …….but I'm running with her ( not to long )
I watch your samson post and one comment…( If you don't mind  )why are you not using a round file ?
What I'm talking about, you are doing more then I do at this moment !
I can only give comment  :D
Great job on the stern….love the blue !
Keep on going and I'm following.
wow you have progressed heaps and its looking good :)
it ll probably another year before i am where you are
Current builds : HMS Bounty, Constructo Pilar
Next build : undecided
On the Shelf : AL San Juan, Mamoli HMS Victory
Builds on hold : Ochre Gorch Fock, Hachette/Amati Black Pearl
Previous Builds Gallery : Virginia; King of Mississippi
Previous Builds logs : AL King of Mississippi 1/80
Guest
This topic is now closed to further replies.
