Good Evening Folk
Using Captain Slogs diary for inspiration, I was a bit concerned about lining up the decks one on top of the other as they are not the same width or length, as pointed out by the Captain
There is no instructions for this step
The templates I am using have 10 cutouts on each deck so I am assuming I have to line these up with the use of a tab
Wondering if the Captain could not use this method as he was using the laser cut parts and there was no cutouts on the decks?
Nothing glued as yet on the upper hull, but I have noticed that my port n stbd sides are not quite symmetrical in certain areas
Hopefully I can improve on this once the upper deck is planked...may have to double plank once the lower and upper hull is joined together permanently
Hopefully make some progress over the weekend
Hi RN,
Good to see progress on this.
Yeah I made tabs from the waste laser cut forms to place in the slots to align the decks but didn’t glue them in.  I can’t remember but I think final positioning was with the Mk 1 eyeball to get even spaces all round.
_______________________________________________________________________________________________________________
HM Bark Endeavour (First Wood, On Hold)
Borodino (1:200 Card, Current Build)
Admiral Nakhimov (card 1/200)
Mazur D-350 Artillery Tractor (1:25 Card)
F-8 Crusader (1:48 Aircraft, Plastic)
