Hi team,
I'm new and although I have searched the forum I haven't found anything specifically on the timber sheathing and iron nail filling of RN ship hulls prior to the introduction of copper sheathing.
I am building the new 1/65 Artesania HMB ENDEAVOUR and research indicates that the hull was timber sheather and iron nail filled with the idea that the nail heads would rust forming a rust coating over the whole hull.
This being the case, how would one model such a finish.  A rust comes in a multitude of shades I would guess stippling the hull with various rust colours combined with a little medium would create the 'authentic' used feel.  But how would one represent and brand new finish?
Completed:
PORT JACKSON - 1803 Topsail Schooner 1/50 by Modellers Shipyard
HMB ENDEAVOUR - 1768 Bark 1/64 by Artesania Latina
Under Construction:
HMAV BOUNTY - 1/60 by Amati
NORFOLK Colonial Sloop- 1/64 Scratchbuild
HMS EURYALUS - 1:48 Scratchbuild POF
Next Project:
HMS THUNDRER - 1/48 CAF Models/Scratchbuild
Planned:
HMS SUPPLY - 1/64 Scratchbuild
HMS SIRIUS
Hello Peter,
I will be interested in what others have to say since this sheathing is seldom represented on models.
You may find the text around page 34 and 35 in this document helpful:
TAR in keel construction.pdf
STAY SAFE
current builds:
Hi Peter, I also would be interested.  My understanding was Endeavour was coated with 'brown stuff' with a sacrificial timber sheathing.  How the sheathing was attached I do not know.  The brown stuff was a pitch/tar and straw mix I think - so learning more about this will be of interest.  I simulated this on my model of HMB Endeavour by initially coating the bottom with motorcar 'underbody' preservative (bitumen mix).  This went on well and dried beautifully and looked just right.
However, this was in winter and when the first hot days arrived it went very soft and started to 'slouch' in places 😟.  I then scraped and wiped it off which left a nice darkened effect on the walnut planking I used - the net result (accidental finish)  worked for me in providing a difference in wood finish to delineate the upper and lower planking while leaving the planking detail still visible).  Below are a couple of pictures, but the finish may not be to your taste.
cheers
Pat
1522164741_BowwithHatches.jpg.ac7b029d235b152f7895bb9823f6624c.jpg2002723831_EndeavourSide18Feb14_msw.thumb.jpg.59cc505c8daa3c5b540e36c2de238cdf.jpg
Edited by BANYAN
Peter, the best way to replicate a hull surface would be to paint the hull with a color you think best portrays the combinations mentioned in there below paragraph, IMHO.
 Paragraph from the below link on page 212.......
"In the 18th century, after lead, with which" it apparently alternated, had been pro- nounced a failure, wood sheathing was again in general use (12, 49). It was sometimes filed with iron or copper nails having large heads, put in so closely that the heads were touching and formed a kind of metallc sheathing (38, 69). This wooden sheathing also was often painted with various mix- tures of tar and grease; with sulfur, oil, "and other ingredients"; or with pitch, tar, and brimstone"
https://darchive.mblwhoilibrary.org/bitstream/handle/1912/191/chapter 11.pdf?sequence=20
Edited by Keith Black
