8 minutes ago, stuglo said:
If cotton or linen thread has the "fuzzies" even after fitting, try judicious use of lit taper or match to singe the buggers
You're a braver man than me Stuglo.  I tried passing a naked flame very quickly under the 0.15mm thread and didn't have anything left.  To try that after fitting to the model when access is limited, well as I said, you're a braver man than me :)
Chimp
Current Build: HMS Granado - Caldercraft
Previous Builds: HMS Beagle - OcCre,   HM Schooner Ballahoo - Caldercraft
When I was a kid, I remember the barbers using a lighted taper over newly cut hair .(? seal against some suspicion of loss) -never saw anyone go up in flames. Obviously, use a rapid once-over. If the worse happens, you have a model of a fire-ship!!!!
current build- Swan ,scratch
on shelf,Rattlesnake, Alert semi scratch,Le Coureur,, Fubbs scratch
completed: nostrum mare,victory(Corel), san felipe, sovereign of the seas, sicilian  cargo boat ,royal yacht caroline, armed pinnace, charles morgan whaler, galilee boat, wappen von hamburg, la reale (Dusek), amerigo vespucci, oneida (semi scratch) diane, great harry-elizabethan galleon (semi scratch), agammemnon, hanna (scratch).19th cent. shipyard diorama (Constructo), picket boat, victory bow section
  • 9 months later...
I use a Weller soldering gun with a flat tip, hot enough without the flame to burn off the fuzzies. Run the flat tip quickly across the thread, you get some smoke but I haven't yet burned through a thread. If you burn the thread just gives it a weathered look.
