Hi,
I bought above model and am now stuck on step 53
monofilament included is ridiculous to put together because you need microscopic eyesight to see what you are doing
can someone guide me through this pls as well as explain other steps involved with monofiliament from steps 48 onward?
instruction manual is not clear at all...
thanks
Have you got any photos of the problem? Maybe then we might be able to help you out a bit more.
Regards, Scott
Completed builds:
Awaiting construction:
All the best
Kevin
KEEP IT REAL!
On the build table
https://modelshipworld.com/topic/25373-hms-enterprise-by-kevin-caf-148-august-2020/
My other builds:
Melloch,
More info is needed... like which kit manufacturer?  Photos would go a long way toward being able to help you.
I built an Academy? Titanic maybe 20 years ago; I used very thin gauge (straight) wire for the rigging and guywires on the funnels... the kind you can buy at the hobby store. It is much easier and gives a better result than the crappy kit line.
