Hi All,
Just a goofy question I was pondering as I get ready to mark the waterline. After the procedure of marking, there will be a pencil line. Do you mask allowing the pencil line to be covered by the white? Does the white paint cover the pencil line OK?
Dave
Current builds: Rattlesnake, Curtis P-40 Warhawk - 1/33 Card
Completed builds: Lady Nelson
On the shelf: NRG Half Hull Project, Various metal, plastic and paper models
Don't make a real dark pencil line and the paint should cover it with no problem.  Just able to see the line is adequate and you don't want to disturb/scratch the primer or underlying paint.
Kurt Van Dahm
Director
NAUTICAL RESEARCH GUILD
www.thenrg.org
CLUBS
Midwest Model Shipwrights
North Shore Deadeyes
Butch O'Hare - IPMS
Theoretical question:
If a charcoal pencil - a sorta soft (HB or so) - was used for the line - used over a paint layer - would a spit wet Kleenex rub the mark off before the area was painted over?
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
Not sure but Denatured Alcohol will do the job.  Dampen a clean WHITE cloth and wipe the area and the pencil marks will be gone.  Use a white rag because the coloring of the rag may be affected by the Alcohol.  The Alcohol shouldn't affect the primer or paint as long as the paint is dry and the rag isn't saturated and rubbed too hard.  This works well for pencil marks on bare wood too.
Kurt Van Dahm
Director
www.thenrg.org
CLUBS
Butch O'Hare - IPMS
