I have one line left I am curious about. In the photos I attached there is line #1191. In the instructions it goes from the mizzenmast down to the bottom of a the flag pole. It looks like a stay of some sort. Not sure if standing rigging or running rigging, or a complete Hellerism!  Any ideas?
Edited by Bill97
Thanks Henry. No. I rigged 1040 the way you guys advised a ways back in the blog. How about line #1114?  It is the line that goes from the bottom corner of the sail. Heller has a block at the bottom of the flagpole that a tackle reeves through. The more I look at it the more I wonder.
Edited by Bill97
My guess would be to rerig just foreward of the flagpole. Someone correct me if i'm wrong, but i believe the same forces would be at play as with the main braces. Belay on a cleat.
Edited by Ferrus Manus
"Bee nott afrayed of anny man thatt walks beneath the skys,
tho big he bee or small you bee, for I will equalize"
- carved into the grip of a Colt army revolver, 1870's
Bill,
1114 is the mizzen sheet and you are correct it would not be fastened to the flag staff.  It would have an eyebolt in the deck for the lower block and a cleat for belaying.  But, if you find moving it would be a hassle, leave it there.  It is the least offensive of the three that Heller wants to belay on the flag staff.
Regards,
Henry
Henry
Laissez le bon temps rouler !
Here you can see what I did. I put an eyebolt on the starboard side of the flagpole for the lower block. I put another eyebolt on the port side of the flagpole to act as a tie down since I have exhausted mysupply of cleats. A rope coil will be added to the tie down later. Finished rigging the mizzenmast.
Ian I am not sure I know what a taffrail/transom is?
According to Google it is:   The handrail around the open deck area toward the stern of a ship.
in the case of the SR there is no handrail, just the stern plate, I guess?  At any rate the only connection point is the base to the deck. The red block in my photo.
Edited by Bill97
1 hour ago, Bill97 said:
snip..snip>
Hard to believe there wouldn't be a brace to the stern plate at the upper end of the "lower flagstaff" (as opposed to the "flag top-staff"???).
Even more basic question; why are there two parts to the flagstaff, with a little "cap", at all?  Seems like another Hellerism to me. Perhaps Marc has some historical prints which shed some light on this.
At this point I believe that is a Hellerism I am going to live with since I have it in place and rigged around it.
Doing an inventory of all the belay points to see if any empty ones are accidental omissions. So far so good. Just need to make the tackle between the fore and mainmast. Then several hours of delicate paint touch up, trimming loose ends and make a bazillion coils to hang at the belay points, add the lanterns to the stern, and make decisions about the boats. A lot to go but in the stretch, to use a Kentucky Derby term.
Edited by Bill97
Ok doing some cosmetic stuff. Added the lanterns to the stern which really finished it off nicely. Added the little swab buckets to each of the visible cannons. Started making the rope coils for the belay pins.
What do you guys think?  I picked up this set of figurines from Artesania Latina. The L. Hermione La Fayette. The scale is slightly different than my SR. The scale of the set is 1/86 compared to the SR 1/100. The period of the set is mid 1700’s where the SR is late 1600’s. However the uniforms are still French naval officers and sailors. Thinking about using them as crew on my SR.
For ease of consideration, Bill, consider the scale of SR to be 1:96, 1/8” to the foot.  If the Hermione figures are 7/8”, or taller, they will not seem credible at all.
Prieser makes figures in 1:100 scale, but they have to be heavily modified to look like 17th C. sailors.  I thought the old Revell Spanish/English galleon kits came with figures in 1:96.  Might be worth seeing if you can locate those on the market somewhere.
Gentlemen here is a handful of pictures. Except for adding the crewmen and deciding if I am going to put the boats on board, I think my SR is very very close to finished!  I am sure I will find a few threads here and there that need to be trimmed, belay points that still need a coil, and a touch up bit of paint here and there, but with all you guys I think I got it across the finish line.
Build commenced:  Oct 2022
Build completed:     Jan 2024
Duration: 15 months
Bill, you have to have set a record for this ship model build!  She looks wonderful ... I love the sails partly brailed up ... excellent work. You are now a master.
Congrats! What's next? A Roman galley perhaps? 😏
Thanks guys for your very kind compliments. It was truly a work of love I could not have even began to complete without each of you. If I scroll back through the build log I find times each of you provided me with the advice and encouragement I needed to accomplish a task I was struggling with. For all those times I am forever grateful. Marc early on I decided I could not replicate what you are doing, but continued to follow your build to pick up small bashes I could do here and there. I will continue to follow to the day your artistic masterpiece is revealed. Ian as always, starting with my Victory, you are the professor with the ton of knowledge I able to go to for the needed answer. And Henry, with your background, you always seem to be the guy with first hand helpful knowledge. That knowledge way back lead to moving the big knighhead that was positioned behind the foremast, and learning to mold and cast additions to the ship. Again thanks to each of you so much. I am in hope that my build log will be helpful to future builders of the SR but I have yet to find where the moderators have included it in the index.
