My progress is quite slow. The next kit I am planning is a resin kit, so I'm not sure it will be much cleaner then this one.
This week I put a base coat on the decks. I also started using milliput to fill in the blast bags. For my first time working with milliput I think it turned out alright.
I have lost a few pieces of the kit, so I decided to use it as an opportunity to practice casting some parts. I used oymaru to make the molds. It will soften in hot water. I then put the milliput into the molds. There is a lot of flash, but with a little cleaning the parts seem to turn out ok.
I found the white milliput to be very crumbly, even when dry. I tried the standard and that seems to be much more durable. I had to remake the 2 propellers.PXL_20221112_183912089.thumb.jpg.702a02b73c6f57f241a2a624a85609b2.jpg
With a but more experimentation, I found a makeup applicator worked well for forming the blast bags. I have a bunch for applying flux for solder. They were nice and small, daily stuff and held a little water.
The capstan with the kit were very poorly molded, so I decided to make a new one. PXL_20221111_211726630.thumb.jpg.6ff80008a8f2c59295cbe70abe5713e6.jpg
I use my freedom to turn down a styrene rod. I used a hacksaw and files for tools.
PXL_20221111_210834126.thumb.jpg.d11d782f61d21d02a154cf3ec33c1ea4.jpgPXL_20221112_183809422.thumb.jpg.0aca4815cd6eec97bc72b3b3a36515cd.jpg
