Hello, I am back from illness and do look for a big but small project.
I voted for the IJN destroyer AKIZUKI (Snowwind) published in Poland
japanischer-Zerstoerer-IJN-Akizuki-1942-1200_2969.jpg.299bfaf31fa4a7507d7afe74c07c9511.jpg
by Answer in the 1:200 scale also due to the nice shape of the lines of this type of destroyer:
The difficulty in a medium range of two of three does give some hope to me that I could manage this kit.
Screenshot_2023-02-22-00-41-14-630_com_ebay.mobile.thumb.jpg.7cc5cb912ecd607a0efc917f52303623.jpg
As I did find this booklet about her and could afford the price for some drawings of
Screenshot_2023-02-22-00-43-21-605-edit_com_ebay.mobile.thumb.jpg.a89fd5ccf2085aac0517d275ae112936.jpg
very nice and helpful detailling. That made it clear to me I will have to use superglue to hardning the paper, sanding the coloured surfaces, repainting it afterwards and die to this all the printed Details will have to be added in the right thickness and shape.
Due to my last strokes I have to search for a bigger scale on a smaler project and so I found this quadro turret destroyer a nice idea. I struggeled hard with the 1:350 plastic kit but as these were/are nearly twice the price I murdered this temptation shortly after it's beginning dawn.
THE PROTOTYPE
Sideview_of_No4_turret_of_japanese_destroyer_Harutsuki_at_Maizuru_in_1945.jpg.5de6004afd1620a8c922137f94077530.jpg
The AKIZUKI class was equipped with twin 100mms barrels in four fully enclosed turrets and very firstly fitted with surface radar model "Go". These destroyers were planed and built to escort CVs so their guns were able to elevate up to 90° as a dual perpuse weapon and the number of  torpedotubes was reduced to four. Their length of 134ms to fit the fourth turret on the hull made them very long drstroyers - close to a light cruiser's typical length. Very often these group leading destroyers were misjudged by USN-submarines as CLs due to their size and shape of the funnel. The missing catapult would have been the most obvious detail of destinguishing them safely.
THE KITS
There are two kits in the German market: an Answer and a nearly three times more expensive Avangard kit - both in 1:200 scale.
The some 1100 parts Answer kit seem to be astonishing detailed - but with this Avangard kit it must be brutally more. So I ordered both kits (and additives) and do hope the best the Avangard kit will not force me to buy an electron microsope to get modelship built...
THE PLAN
I do think about a diorama in resin - an imaginable scene at anchor. So I could cut the under water part of the hull and the LC-parts down to less than an inch below the CWL. This will be enough hullred to be seen in the greenish resine, but I will avoid all the complexity of hull building, shafts, rudder, Propellers, and so on. The AKIZUKI by Avangard will be the second build and she may be used to show one of the six sisterships - slightly different in detail and rigging.
So I do await these parcels from Poland to get started.
"Let's add every day 1/2 hour of
modelship building to our
projects' progress..."
Take care!
Christian Heinrich
simple, true and inpretentious motto of ROYAL LOUIS, 1668
Sunking's mediter. flagship most decorated ocean-going ship
Ships on build:
SAINT PHILIPPE, 1693:
1st rang French 90-gun ship - Lavente flagship (based on Heller SR - 1/92 & scratch in 1/64)
TONNANT, 1693:
1st rang French 90-gun ship - sister of SAINT PHILIPPE (mock-up/test-object for S.P. - scratch in 1/64)
Projects in planing:
L'AURORE, 1766:
French Pleasure Corvette (after Ancre plans - scatch in 1/64)
Some Spantaneous Short Term Projects
Having worked on my USS England in 1/250 scale, my honest assessment is that most steel navy warships done in card should only be rated difficult, really difficult, or insanely difficult -- they are one of the hardest, if not the hardest, card model subjects to pull off well. I look forward to watching your progress and seeing how the products from the two publishers compare.
Cheers!
Cheers!
That is so true. Building out of paper cards adds a considerable level of difficulty to the model. It is unfortunate because of lot of very interesting and rare models are available in cards only.
Yves
Hello Yves and ccoyle, thanks for the Infos and enthusiasm - I do think about building the model as a paper claded hull - mainly painted over in the IJN-grey, linolium and brass to get the most out of it. I absolutely cannot afford some 300 euros for a modelship in the same scale in plastic and etched partsbso I am dealing with any Trick I will figure out to get the best result out of the cardboard kit in detail - without of any idea of a Kind of pruristic nothing-than-paper-and-card-enthusiasts...
22-GO_and_13-GO_radar_on_forward_mast_of_japanese_destroyer_Harutsuki.jpg.3335d4ed152cf7151d2635e1eab61938.jpg
...as I am completly incompetent to build this surface 13-Go and 23-Go radar and this complex mainmast in combination out of some pice of paper and woodglue alone.
And there will be a plenty of problems more araising from this kit.
Sorry for this.
Take care!
Christian Heinrich
Ships on build:
TONNANT, 1693:
L'AURORE, 1766:
Today the long awaited parcel did come with my kit - and I found my twin-scales ruler for the imperial-loving Americans... 😉
Also the brass milled barrels and the detail set were in there.
So I started with the typical cutting out and sanding the LC-skeletton (not to tell a well known story a third time in here).
But I borrowed a table saw from a friend and started to get the spaces filled by balsa wood blocks. I decided to take the measurement directly from the kit's middleframe onto the "distancer". For a better orientation later on I decided to give Roman numbers to them - adding C (100) and L (50).
Than I cut the balsa wood filling in to shape starting with the between-bulkhead-compartments C, I, III, IV, V, VIII, XI, XIV, and XVI. Re Rest will be a more indiviually kind of workload.
It is my job to get them into the right breadth and after this into the right hight as the maximal hight is between a fracture below 12mms or 1/2" and 31mm or 1- 1/8 at the bow's tip. For this I'll have to pile my cutouts from the several thicknesses and glue them onto top to get the correct hight. Not to forget (I have learned 35 years ago) to lay a slip of newspaper between each wooden layer to imitate the PVA's additional thickness - and dotting the glue so the needed air to bond the glue can reach everywhere between the layers and not only to the outside.
By all this I do hope to get a solide wooden hull I can clad by paper &t. as I saw it in the wooden warship builders so often filler the space between their bulkhads/moulds.
For my very first model trial I decided not to cut the underwater parts in to slices of 10mms to get a proper underwatership illusion. "Let's get something finished - stay on the more simple side!" a friend told me - a less perfekt model is better ready than a mount of unfinished but more perfect kit builds...
Sorry for this alteration of the plan - I will try to come to this feature with the building of the Avangard kit... hopefully
Edited by Heinrich der Seefahrer
The alteration of the plan.
Take care!
Christian Heinrich
Ships on build:
TONNANT, 1693:
L'AURORE, 1766:
2 hours ago, yvesvidal said:
Very good idea to mix wood with the paper cards.
Yves
Thanks a lot Yves! Hopefully it will Work out as plan(n)ed.
Today I cut further wood into slices to fill the "gaps". As the stem's part will need more and more "thickness" with less breadth I cut a pile of balsa (10 & 5mms) to get ready when doing mit hot phase next week.
I glued the hull basis on a 4mms thick piece of balsawood so I may be able got give AKUSUKI a bit of a deepness under water by trimming ut into shape. Now my hull skelton is resting in my terrarium.
Take care!
Christian Heinrich
Ships on build:
TONNANT, 1693:
L'AURORE, 1766:
Okay Friends and followers, the critical mass is reached... there the Kagero 23 pageed  booklet arrived and NOWPolish_20230224_115143506.thumb.jpg.e8ac1de59507d7d65ce3c67fcb4c99c5.jpg
I do realise what a massiv model (even as WL-build) I brought home from the fishing boat in the WavesWavesWaves... 😉
And by leaving through the sides of this fantasticly made booklet
with all it's fine drawings. I am starting to get an idea what tons of detailling I do have to deal with in card - and altering it to resin, wood, paper and other materials.
Let's just go through two sides so you do geht an idea of the helping hand you get offered:
On sheet three we do see the bow deck - interestingly the anchor chain differs very much to most 1/350 and 1/700 plastic kits (showing her going across) I looked ad.
Going closer I can see the different vents on deck and I do get them in the next page Polish_20230224_120420228.thumb.jpg.88ca1c7e8d643c36987f735a420a1655.jpg
as a detail plus capstain plus anchor (plus turret and handrail with sun fabrice holders).
Such a proper drawing of them does give me some help and I figured out to have seen the mid right "mushroomer" in some photo in the very foreground on an other destroyer or light cruiser so it is a kind of standard-item.
And then I got a horrified view onto the scuppers and decided to add "plastic sheet" to my list of materials I will need:
So this is the Impact of the booklet in some pictures I will go to my psychiatic surgeon for better pills...
Take care!
Christian Heinrich
Ships on build:
TONNANT, 1693:
L'AURORE, 1766:
I do plan to "harden" the balsawood and cardboard combination with superglue -  needing few gallons (-; onto this big surface only...
QUESTION:
Is the sanding result the very same? Or is balsawood soakef in superglue- and Bond still softer than Cardboard treeted the very same way?
Does anybody have got any experience in this?
Thanks a lot
Take care!
Christian Heinrich
Ships on build:
TONNANT, 1693:
L'AURORE, 1766:
Hello, just short message and a first picture from sunday's progress silent
 in the model ship yard in the fifth floor.
Doing the necessary filling between the bulkheads by cutting balsawood.
I am trying foreward to keep the hull without look like the spine of Richard III. found some years ago. So I do have to get a straight red line to  controle it perfectly. I do think about a little cut into stem and sterns - so a red thread has to stay in the centerline's middle...
Take care!
Christian Heinrich
Ships on build:
TONNANT, 1693:
L'AURORE, 1766:
