Good work,   they  will  make  So much difference  when you  start  the  Standing  Riging  as they will  not  bend  like  the  plastic  ones  would have done.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Messing around with some vinyl Sparrow logos for a pirate flag…a good friend made these for me onto crate paper
I have some fabric for sails that I will try and get these on or used as a template
Edited by Twokidsnosleep
Scott
1/72 Zvezda The Black Pearl
Very nice video  -  puts  it all  into  perspective.
OC.
Current builds
Completed works.
I have thes  riging  studies  of the  Pearl  hope  they  help.
OC.
Current builds
Completed works.
49 minutes ago, Twokidsnosleep said:
Thanks OC
I have seen the bottom ones but not those in the first pics. Excellent!
No problem Scott,  glad  to  help.
OC.
Current builds
Completed works.
Bowsprit and Lower foremast are cemented in. I did a metal rod in Bowsprit and pinned it to the foremast so things won't move
The two mast locked together
The anchor line is in and test fitting the railing  up front
Then I added the Gammon rope to the Bowsprit. A bit fiddly and not perfect but it will work
Scott
15 minutes ago, Jeff T said:
Gammoning looks good!
Does the polyester line tend to smooth out well, or does it need a lot of tension to straighten it when it is rigged?
Thank you
The polyester is lovely to deal with. It holds the knots fairly well and stays put as I wound it around.
A bit of fun trying to thread it through the base part but it went ok
Mind you , I have not used natural fiber rope before so cannot really give a full comparison
Scott
41 minutes ago, Twokidsnosleep said:
Thank you
Those ropes  look awsome,  the  threads  I was using from the kit  and  stash  from my old  wood  build, needed  smearing with  diluted PVA  to tame  the  fraying  -  a  tedious  job.
OC.
Current builds
Completed works.
OC.
I agree
These polyester 'ropes of scale' are fantastic to work with and the results are very encouraging
More work on the bow and you get another angle view of the gammon rope
I have started to fit in the cathead block for the anchor support and the starboard forward side dasher is now glued in
Scott
Well this was a thing. Getting some more ‘deck furniture’ ready before the ropes of rigging are in the way
adding brass pins so it fits tight to the deck and won’t pull up easily
I broke a belaying pin with little effort🙄
I don’t trust this styrene is areas of stress so repaired it with brass…and will replace  the rest of them the same way
Then testing of weathering the flat black hull
Some grey cement pigments. There will be some rust as well and salt wash lines
This stuff can be wiped away with water so is easy to control degree of weathering
Scott
3 hours ago, Snug Harbor Johnny said:
  'Looking good.  What's next on your list? ... the Flying Dutchman?
Ooo good question, yes the Dutchman would be a good next ship project
I have a few other  unfinished builds I want to get done, The Miss Budweiser Hydroplane is among those
Have the Blue nose kit and would love to find the Gotheborg Swedish wooden kit but it is out of production
Scott
I would appreciate some knot tying input here
Am trying to tie off the anchor line that is quite thick. Internet searching finds an “anchor bend”
my attempts at this knot..it still needs the seizing part at the top
whaddya think??
Am I way off base here??? Help!!!!
Scott
whaddya think??
@mtaylor  can you  help  spread the  word  about this  please.
OC.
Current builds
Completed works.
Happy little blackened screaming heads temporarily positioned on the starboard side
I busted one and lost another to the floor
Yes they will all be aligned perfectly when they are fixed to position…everything is a dry fit here
Scott
Found an interesting research source today…the site of the team that made the scale version of the Black Pearl for filming
https://www.jduncandesign.com/work/project-two-8wzh7
some good clear pics for me, especially details around the cat heads and anchors
The amount of weathering and gunk on the bottom of the hull are also interesting
super cool stuff made by very professional modellers with exceptional pedigrees……unlike me🤪
Scott
If you  can  position the  dead  eyes  so they all  line  up  perfectly  -  your  a  better  man  than me  and  most  others  -  threading  the  dead eyes  is  a  delicate  operation  -  well  it  was  for  me.
OC.
Current builds
Completed works.
Love  these  pics  -  just  shows  they  where  just  like  us  model  makers  but  on bigger  scales.
OC.
Current builds
Completed works.
Talking of large  scale   -  check  out  this  restoration of  a  super large   HMS  Warspite   -
OC.
Current builds
Completed works.
OC.
Wow That is a big project. Very interesting.
I wonder if they finished, so many things get started and then disappear off the internet
Have lost many good modellers off my other forum site with Covid and life changes. Sad people just vanish
Scott
