Options for the ship's layout:
2 members have voted
  1. 1. what should i do?
    • Build as a viking longship
      0
    • Partially scratchbuild into a nef
      2
    • something else entirely??
      0
Okay, as much as i love the date "1197", i will change it.
"Bee nott afrayed of anny man thatt walks beneath the skys,
tho big he bee or small you bee, for I will equalize"
- carved into the grip of a Colt army revolver, 1870's
Also, in my opinion, the guy climbing up the backstay in the Winchelsea image is just bad seamanship. Why not unfurl the yard while it's resting on the deck? Also, why put unnecessary strain on the rigging by climbing it? Why, also, make the lives of the people hauling on the windlass harder by, presumably, sitting on the yard? And if you fall? Well, now your ship has one less man to operate it, and your mates have to find a new crew member.
I cut some more parts from card: the extended stem and stern posts, and the stanchions for one of the ladders.
The rudder that they gave me in the kit looks a bit sad. Let's change that!
First order of business was to drill two holes in the rudder: the smaller one at the bottom is for the uphaul, and the larger one in the middle is to replace the plastic attachment with something more accurate. Now, these rudders were not, actually, attached with regular rope. The rope would, upon getting wet, weaken and stretch. So, they used withies (a flexible piece of green wood). However, i do not have a withy. However, tarred rope would not have the issues regular hemp would upon contact with water. So, that is what i did.
Also, the tiller was looking pretty half-assed. So, i drilled a hole and made a new one.
Here is the finished rudder:
Now, the sharp-eyed folks will notice the aft raised portion of the deck lying in the background. Notice the three holes in it. These are in lieu of an actual frame to connect the rudder rope to. Even better, i can manually adjust it using tweezers!
Viking Shipbuilding Pg. 4 in 2023 | Vikings, Viking ship, Boat building
I was disappointed in the fact that i had to install it now instead of being able to save it for the very end. However, the fact that we have now replaced all the plastic attachment points with rope, means that we can abuse the crap out of it for the rest of the build and nothing will snap.
I just need to make some kind of a wedge out of card.
Edited by Ferrus Manus
Alrighty. This is the deck:
I wanted to install a lot of the deck details before i glued the deck in. I added 22 eyebolts in 3 sizes, as well as 5 cleats.
I will probably wait on the receiving block for the halyard until the deck is in. The only other significant piece of deck furniture is the capstan, which i have a plan for.
What's with all those small eyebolts in the front? Glad you asked. Those are the rings used to lift up the removable planks, which, in the Middle Ages, are what you use in order to gain access to the below deck area. There are a grand total of 8 removable planks, and two eyes per plank.
I did this one just for you, Steven.
image.thumb.jpeg.56509cb3f6c55c3d6f48f7c2692d544f.jpegimage.thumb.jpeg.7621ce490b79e3810c64e7e8dee3617d.jpeg
The lovely girl in the background of the first picture is the Queen Elizabeth. (English Man O' War)
Do you have a copy of Zu Mondfeld’s Historic Ship Models?
If so, there is a great jig detailed in there for making ladders.
I have used it in the past with great success.
I have also duplicated the Amati method of making ladders in my current build.
It has worked quite well for me.
Both have some setup, but both are conducive towards making ladders that are evenly spaced and properly squared up.
Building:
I have actually never made a ladder before, but i can do it without a jig. I don't think i'll ruin it. (famous last words)
Basically the equivalent vessels - at least in the Atlantic - were nefs but without castles, at least as far as the pictorial evidence shows. As I mentioned above, the first I've seen with castles were c. 1225, and they only had a single castle, at the stern.
Steven
the first Mediterranean ship, or the first ship at all?
Alright. I was going to make two square openings in the castles for the ladders, but that is going to be an issue, and here's why. The forecastle is two small for a hole. A hole (say, 2x2 feet) would considerably reduce the amount of standing space there is on a castle. And on the sterncastle, the hole would mean that the ladder goes right through the arc of the tiller swing.
All good questions, but this is what is shown on these seals, not just the Winchelsea one but others as well. And regarding climbing the rigging, there's this (Crewmen on 20th century dhows)
image.png.14200aa603061c622857cc70371d14ed.png  image.png.832d7b835fa677b29f4f80089177f2c6.png
Woodrat made one from a bit of creeper out of his garden, in his "Elusive hulc" build. See post #125 at
but you've come up with a good workable alternative.
Nice paintwork, by the way.
The first Atlantic ship, as the nef is part of the Atlantic tradition. There are Mediterranean ships shown with castles at each end on the leaning tower of Pisa (probably from the late 12th century) and in the Annals of Genoa (last decade of the 12th), but these are lateeners, not part of the nef tradition in my view. In fact, for the Med we can go right back to about the 10th century, when dromons are described as having central wooden castles (xylokastra), or even earlier, to Roman times, when warships had a central castle.
Looking forward to seeing how you solve this one. I was aware of the standing-space problem on my own nef. Though I had a hole for the ladder in each of the castles, I put it at the extreme inboard edge. Nonetheless it had a crossbeam at the outer edge of the opening that you'd have to duck your head to avoid (this was for structural strength).
I'm not sure they existed at this time. I've seen one on the Bremen cog, but that's dated 1380 or so, but windlasses are a pretty definite thing.
Coming along nicely. I look forward to the next instalment.
Steven
A lot of the castles of Landstrom's nefs seem to show the ladders leaning up against the front of the castle- no hole. Thank you for the Dhow image. The withy Woodrat got was in 1:32 scale, this is 1:50- quite a bit smaller. Stick around! Major update in less than an hour.
PS I meant to say windlass!!
The things i have gotten done are as follows: The rudder, the uprights for the castles, the transversal crossbeams for the sterncastle, the dry-fitting of the mast, and the installation of the proto-bowsprits.
image.thumb.jpeg.012369781e0219b504e9ae054c16dc8c.jpegimage.thumb.jpeg.7fc7147a6602de8a264798f066d3acbc.jpeg20230901_220118.thumb.jpg.9728f34071a7e18d78882244164ed1fd.jpg
These are the beitasses, or sail stretchers, from the original kit. They were used by Vikings as a way to open a sail up for the wind. Landstrom depicts them as taking on a second use over the centuries, as a form of proto-bowsprit for receiving the bowlines.
By the way, we're long past the point of being able to haul it across the room in a fit of anger and have everything be mostly fine. That literal ship has figuratively sailed.
Ok Steven, like you probably assumed, this is a small testbed. This is the point at which i begin to develop the techniques that will be used on the Senora Fielden.
image.thumb.jpeg.e1c12b0ec564e8b0bc4d1e6d859745ae.jpegimage.thumb.jpeg.b78452e40df399ec91db42ffda92e196.jpeg
One more question: have they ever recovered bilge pumps from a cog? If so, what did they look like?
Thank you. I know about the pumps on carracks and later ships, i just don't have a solid date on when they first appeared. I am aware of the pumps you put on your Winchelsea Nef, i just don't have a solid date for the introduction of pumps.
i just finished a major part of the ship. This is the sterncastle platform (my very first scratchbuilt deck), the receiving block for the halyard, and the capstan, which has yet to be glued to the deck. Not pictured are the transversal beams for the forecastle.
Coming along nicely. Good to see you coming over to the Dark Side (scratch building) if only a little so far.
Pumps go all the way back to Roman Times (they even had chain pumps, but they seem to have been lost in Western Europe at least, judging by a comment from a western commentator about them in (I think) the 15th century.) There's evidence suggesting there was a chain pump on the 11th century Serce Limani wreck, lost off the southern coast of modern Turkey, which was then part of the Byzantine Empire, but it's a bit equivocal. However, based on that I put chain pumps on my dromon.
There are papers on all this. I can send a couple to you if you're interested.
Steven
You're a sick man, Steven! The Dark Side has called to me patiently and persistently, so much so that i decided to start my own huge, major scratch project (out of timber!!)
Alright, second castle is done. The planking of the castles, with some intelligence and planning, were surprisingly easy, and both only took one attempt.
20230904_162251.thumb.jpg.b7598a08426349e2f42a551ebe13daed.jpg20230904_162257.thumb.jpg.92dc6b22c6aada57c2be7458be1b4105.jpgimage.thumb.jpeg.d2d93356f016585e0b5df0b5d4f4b332.jpeg20230904_172257.thumb.jpg.0f119b288f0e57fe38c1cb60987ba92a.jpg
That's a nice bit of work, mate. Keep it up. I'm looking forward t seeing what you do with the sides of the castles.
Yes, come to The Dark Side - you know you want to . . . . :D
Steven
The sides of the castles, as in under the deck or above it?
Above it - as far as I've seen the castles were open underneath. In fact quite a few of the contemporary portrayals (though not all, by any means) show the helmsman working underneath the aftercastle.
Though the supports for the castles were sometimes quite decorative, most were very simple - just uprights -and I don't see there's any need to get complicated with them (unless of course you want to).
Steven
Okay Steven, i have a theory on that. These were the most simple and ordinary merchantmen of the High Middle Ages. I genuinely believe that, regarding the ornate Gothic castles, either the artists/coin minters took considerable amounts of artistic license, or it was a running joke. As for the castles, i will be alternating 1x1 cm and 1x2 cm strips of cardboard running vertically as the walls of the castles, making it look a little bit like actual castle parapets. These will be painted off-white cream and a sort of cream/sea green, in alternation.
The castles are done, minus the ladders and any potential other stuff i decide to put there. At this point, basically everything above the actual top of the hull itself is made out of card.
image.thumb.jpeg.3d7f58164ff3232fe176dd67468306bf.jpegimage.thumb.jpeg.966566f02dd7312835665acc326b135e.jpeg
