On 4/7/2024 at 8:03 PM, Geograndpa said:
Does anyone know what cm stands for in the Mamoli instruction material key? Thanks in advance.
I don't have here a sheet of Mamoli ships but usually if related to lenght, cm is a fraction of meter in terms of lenght. 100 cm=1 m = 1000 mm
the cm are used often in Italy, but internationally not.
Internationally are more often used mm and meters.
Edited by Cristiano
    Done:          Venetian Polacre http://modelshipworld.com/index.php?/topic/7290-venetian-polacre-by-cristiano-sec-xviii-from-original-drawings/
                              Halifax  http://modelshipworld.com/index.php?/gallery/album/844-halifax/
                              Ranger  https://modelshipworld.com/gallery/album/2175-ranger-revenue-cutter-by-corel/
                              HM Bark Endeavour (Corel kit heavily kitbashed) : http://modelshipworld.com/index.php?/gallery/album/125-hmbark-endeavour-corel-kit-bashed/        Venetian Galleon (from scratch) - Pirate Junk (from scratch) - Sicilian Speronara (from scratch)
In progress: Model Shipways Picket Boat
On the shelf (still packed):     Artesania Le Hussard....
I looked at several instructions for Mamoli kits and while they all had the CM descriptor only one (instructions for the Sâo Miguel ART. MV21) had a label for CM and that label was in Polish only (it was removed from the English translation portion of the instructions). It stated: CM – sklejka 1,5 mm which using Google translate, appears to translate as plywood. That translation makes sense for, at least some of, the parts that I saw labeled as CM.
Hope that helps.
Edited by VTHokiEE
if cm is in capital letters (CM), is right.
The old sheets of Mamoli kits present some tricky abbreviations for materials.
They made acronyms using Italians words, and sometimes not related in anycase to Italian words.
So the best way is to check the drawings and see which material can be related and use it for all the matching acronyms.
Some example:
NO= Noce (walnut)
CO=Corda (rope)
MET= metallo (metal)
OTN=ottone (brass)
and so on.
