I have a fiberglass hull that is a replica of my fathers commercial fishing boat (pic below).
The hull is about 44 inches long stem to stern, and 13.5 inches wide across the stern.
I'd like to start with an electric motor and add RC controlled steering and speed controls including prop and rudder. I'm completely new to this and I would rather spend the money putting the right gear in side the boat than rip it all out later and start from scratch.
Can someone give me some pointers on where to start, and what brands/equipment I should be considering.
Also since this is a model of a commercial fishing boat, is there anywhere online that sells scaled parts and accessories like tackle blocks, mooring fittings, etc.
Thanks,
CodeMonkey
Edited by CodeMonkey
I can't help with running gear, but Model Expo and Bluejack both sell such items.  They sell by "size" and not by scale on those....
Hello CodeMonkey; Being a subscriber to the British "Model Boats" magazine, I'm having the
privilege of contributing to and being the recipient of model-build helps & suggestions. You may
wish to subscribe to the "digital" edition to benefit from the excellent Forum coverage of R/C,
electronics, motors, fittings source, etc.  Regards, pollex
I know it's old fashioned, but in some countries there are still model shops you can go to, get advise and pick up a good set. What set depends largely on what country you are in and what frequency is legal. I'd go for 2.4 GHz
Freek
Hi Cornwall model boats is a good place to start I would go for 2.4 ghz digital they are cheap and you don't have to worry about interfering   with anyone or anyone interfering with you you will need as a minimum 2 servos (forward reverse right left) and if you want to have any other moving things you will require more (like working lights, winches, anchors. And such) you will need a speed controller, you will need to experiment with where you place batteries and ballast. The most important thing with rc is rc on first then receiver receiver off first then rc or you may have a runaway boat.
