Welcome to our new sponsor - Engine DIY. See banner ad on Home page. ×
On 10/18/2024 at 10:24 PM, Pfälzer said:
This will be the right Book to present this ship when finished
I'm not sure I understand.  Will you be giving the ship the book?  or using the picture in your presentation case?
Beautiful workmanship.  Sehr Schön!
This are the parts to build the Stand
Funktionierender Build:
San Martin -
Occre
Endender-Build:
Cala Esmeralda - Occre
Lady Nelson-Victory-Modelle
Gorch Fock-Graupner 1985
I builded an Adapter to drill the Hole in the Keel for this Screw.
Its for the Stand.
San Martin -
Occre
Endender-Build:
Es kann sein, dass die Kanonen nicht zu hoch sind, nur dass einige von ihnen leicht nach oben geneigt sind. Vielleicht könnten Sie kleine Keile unter das innere Ende der Kanonen stecken?
(translated using Translate Google)
Yes, the mounts are too high. But that's because I planked the deck thicker than Occre intended.
I think simply wedging underneath would be the wrong way to go. There is still room for manoeuvre at the bulge for the gun, so it will be a smooth mount instead of a curved one. Stupid, because I've already spent days preparing and ageing it. But that's the way it is. I also didn't want my current intestinal upset and have to live with it.🤣
Greetings
San Martin -
Occre
Endender-Build:
The Woodwork on the outer Hull are ready. Now i must think about the Takelage from the Cannons.
San Martin -
Occre
Endender-Build:
Hello lovelies,
I would like to explain the stand in more detail.
It's made of soapstone, which I found about thirty years ago at a rubble dump.
In our wild years it was used for chopping various powders to party the night away. Then it was used as an ornament on one or two cupboard shelves and now fulfils a very useful purpose.
I had to drill two three-millimetre holes and fill them with walnut dowels to install a nameplate holder. Small problem, unfortunately I measured the original pins of the holder and didn't realise that the actual hole in the holder is 4mm. Not dramatic, the ship is not yet fixed, the holder is temporarily lined with adhesive tape.
I'll have to look into getting a 4mm brass tube in the next few days, which I can then use to level out the discrepancy.
Have a good Sunday
Translated with DeepL.com (free version)
San Martin -
Occre
Endender-Build:
So, ihr Lieben,
das Boot ist nun kampf- und wassertauglich. Jetzt gilt es, es segeltauglich zu machen.
Auf die Geschütztakelage werde ich wohl verzichten müssen.
Als die Schanzen angebracht waren, dachte ich, ich sollte die Löcher für die Ösen bohren, bevor ich den nächsten Schritt machte. Nach dem nächsten Schritt dachte ich, oh, ich sollte die Löcher bohren. Nun, anscheinend habe ich das oft gesagt, denn als ich die Kanonen auftakeln wollte,
hörte ich mich denken: ****, da war was mit Löchern.
Deshalb machen wir Fehler, damit es beim nächsten Mal nicht wieder passiert.
Na dann, ich muss Masten schleifen, tschüss
Übersetzt mit DeepL.com (kostenlose Version)
Edited by Pfälzer
San Martin -
Occre
Endender-Build:
So, orle, ihr Lieben,
jetzt braucht er euren Rat. Ich habe zwei Stunden damit verbracht, meine erste Seilschlaufe zu binden. Die erste, größere, ging gleich wieder auf.
Ich fand sie zu groß für den Maßstab 1:90. Also habe ich eine kleinere gemacht. Die mir jetzt fast zu klein vorkommt.
Lasst mich bitte wissen, was ihr davon haltet.
Liebe Grüße
Edited by Pfälzer
San Martin -
Occre
Endender-Build:
Ich glaube nicht, dass es in diesem Maßstab eine große Rolle spielt, welche Seilgröße Sie verwenden. Aus praktischen Gründen würde ich das wählen, mit dem man leichter arbeiten kann. Niemand wird Ihr hervorragend konstruiertes Modell betrachten und ausrufen: „Der Maßstab die Seileschlaufe ist falsch!“
That is some awesome work that you have done. Very nice sir.  :cheers:
"Start so you can Finish!"
In progress:
The Dutchess of Kingston - 1:64 Vanguard Models 🙂
In queue:
Astrolabe 1812 - Mantua 1:50;  Pegasus - Amati 1:64
Completed:
Santa Maria - 1:64, La Pinta - 1:64, La Nina - 1:64, Hannah Ship in a Bottle - 1:300, The Mayflower - 1:64, Viking Ship Drakkar -1:50 all by Amati. King of the Mississippi - Artesania Latina - 1:80  Queen Anne's Revenge - Piece Cool - 1:300  The Sea of Galilee Boat - Scott Miller - 1:20
Ohjee, the spanish art of Plan
San Martin -
Occre
Endender-Build:
Looking good. You're in the home stretch now.
Mikki
"You're gonna need a bigger boat."
Working on: Dusek's San Martin
Completed: Good ol' first ship build- Constructo's Albatross; Mamoli's HMS Bounty; Mamoli's Golden Hinde; Amati's Drakkar; Occre's Revenge; Artesania Latina's San Fran
This dosnt realy makes me happy
Edited by Pfälzer
San Martin -
Occre
Endender-Build:
