Rigging books for 1855
Go to solution Solved by Snug Harbor Johnny,
  • Solution
  'Depends on the type of ship ...  For square rigged commercial vessels, 'Masting & Rigging the Clipper Ship & Ocean Carrier' by Harold A. Underhill - 1946 (available as a pre-owned book) has a wealth of information, much of it applying to the 1850s, when patents for splitting the top sail were being adopted.  The time range applies from the late 1840s through the early 20th century.
  For many sailing warships,  'Rigging Period Ship Models by Lennarth Petersson has material applicable from roughly 1800 through the 1850s (e.g. the rebuild of the U.S.S. Constellation).  A different kettle of fish from commercial vessels.
  There are a couple of books on fore-and-aft type ships (e.g. schooners), but the name of them escapes me at this moment (Edit: one of them may be Underhill's  'Sailing Ship Rigs and Rigging' 1955 , that covers additional ship types).  However, I find that 'The Bluenose II' by L.B. Jenson (who also documents the original Bluenose of 1921 - the rigging virtually the same) has much information that might be applicable for earlier schooners.  Again, fore-and-aft rigging is a different kettle of fish from the above two classes.
  EDIT:  R.C. Anderson '17th Century Rigging' (1952) expands the time period somewhat, and provides further insight. Anderson's 'The Rigging of Ships - In the Days of the Spritsail Topmast 1600- 1720' (1984) further stretches the time period and ship type.
Edited by Snug Harbor Johnny
Hi Jerome, there are others also writing in this era, including:
Robert Kipping (as per John above) - "Rudimentary Treatise On Masting and Mast Making" 1853/1854/1858 editions
John Fincham "A Treatise on Masting Ships and Mast Making" 1854
G.S. Nares (Commander, RN) "Seamanship" - 1868
More related to USN is:
SB Luce "Seamanship" - 1868, and
Brady "The Kedge Anchor" - 1852 edition
Most of these are available as digital copies (PDF) produced by Google.  The search engines now try and point you to 'print on demand' or paid versions, but if you persevere and look further down you can still find the free pdf versions easily enough.
cheers
Pat
I have put together a lis of published literature specifically on masting and rigging. There are some more titles in addition to those already mentioned: https://www.maritima-et-mechanika.org/maritime/maritimebibliographies/masting&rigging-bibliography.pdf
Those marked with 'E' are available in digitised form, but you would need to look for yourself for a link.
Edited by wefalck
Hallo wefalck,
vielleicht noch eine Ergänzung für deine Sammlung:
Die Sprache des niederdeutschen Reepschlägerhandwerks, Jürgen Eichhoff, 1968, im Rahmen "Niederdeutsche Studien"
interessanter herausgegeben vom
Landschaftsverband Westfalen-Lippe
perhaps another addition to your collection:
The language of the Low German rope-making trade, Jürgen Eichhoff, 1968, as part of "Low German Studies"
more interestingly published by the
Regional Association of Westphalia-Lippe
Grüße,
Andreas
"Torpedos, das Stück für 20.000 Mark, und was wir brauchen ist für 50 Pfenning alter Draht!" "Das Boot"
Thanks, I was aware of this work. Interestingly, their terminology differs in places from the one used in maritime circles - but this is rather a discussion for a German forum (where we already had it, I think).
Those marked with 'E' are available in digitized form, but you would need to look for yourself for a link.
  Very impressive - a veritable compendium of sources ...  The most recent (and more easily accessible) are still those by Anderson Petersson and Underhill.
