I have a couple of really old and cheap razor saws, they came with an aluminium mitre box which is long gone.  They were originally bought for RC model aircraft building projects, but that was many years ago, and they are now quite bent and pot-marked with corrosion.
So time to buy some new ones, I looked at the Zona range and instantly became overwhelmed.
They do three different thicknesses / kerf
Ultra Thin - 0.20mm
Fine - 0.25mm
Medium - 0.38mm
In the ultra thin they do, 52TPI, 42TPI and 32TPI
In the fine they do, 42TPI, 32TPI and 24TPI
And in the medium they do, 16TPI (flush cut) and 24TPI
They are all pull-cut.
That’s 8 different saws altogether and I’m not about to buy all of them.
In summary, in the hobby of model ship building, which would be the most useful?
Many thanks,
Nigel
To me, the kerf isn't that important as I'm cutting off a piece.  There are charts around that show tooth count vs. wood thickness and this is the important part, IMO.  If I'm ripping wood on a table/hobby saw then kerf is a factor due to waste, warpage, etc.  But again, there's tables for those.
the zona saws are awsome. i have the complete set of 8 plus the 4in1 kit. like you, it seemed an overwhelming variety and a waste to get them all. in hind sight i could have gotten by with the 4 in 1 multi blade kit for $13. that has been my main go to saw, especially the keyhole blade.
with no regrets buying them all, i found the other saws very useful for setting guitar and other instrument's frets. fret wire comes in many different kerfs.
for model building, these saws are a must have.
https://www.amazon.com/zona-saws/s?k=zona+saws
Edited by paul ron
Relatedly, I'm wondering if people have suggestions for thin keyhole saws. I saw them used by someone building the Norwegian Pram, which I'm doing now. You drill a pilot hole and then can saw out a slot with the keyhole saw (obviously, something a razor saw cannot be used for).
 the combo zona razor saw has a keyhole saw blade (about 3") ive used to cut a keyway for a box lock through a solid wood basement door.
i also wish they had a bigger version of the keyhole blade, or even replacement blades. dont under estimate those saws. they cut like nothing else.
Edited by paul ron
