The AL Belem was chosen to gain knowledge and experience building model ships in particular the rigging.
This is my first build so please excuse any wonky terminology.
First I have to become familiar with the forum and creating/formatting posts.  The next few posts will be an experiment with the existing photos I have.
The next step is to clean up the parts and do a dry assembly of the model to understand the sequence of assembly before using any glue.
Edited by TannumIan
Testing
Ian
Current Builds
BELEM AL Scale 1:75
Extra plywood bracing was added to the cabin sides to maintain the deck curvature when the roof was fitted.
All parts were assembled without glue.  When all components were true and aligned the frames were spot glued with CA.  This created a rigid frame that was fully glued with CA.
Edited by TannumIan
Ian
Current Builds
BELEM AL Scale 1:75
To steam a plank for bending the plank is wrapped in a wet cloth and heated for about 30 seconds using a domestic iron on the highest heat setting.  This is fairly severe compared other methods but the plank has little spring back after being bent and clamped in desired position.
The domestic iron also heats up quickly.
These planks were edge set prior to fitting to the bow.
These are the stern planks holding their shape after removing from the frame after cooling.
Edited by TannumIan
Ian
Current Builds
BELEM AL Scale 1:75
The garboard plank caused me grief as I could not see how to make it.  The forums seem indicate that this is a common concern.
I eventually made a cardboard template and then set about replacing the carboard with planking.  The bow section was two planks glued together and cut to shape with the bandsaw.
The garboard was kept away from the vertical section of the stem and low on the deadwood.
Ian
Current Builds
BELEM AL Scale 1:75
An invaluable tool.
This old low angle plane was sharpened to 2000 grit using a Veritas sharpening jig.  The plane was also flattened on a sheet of glass and many sheets of 400-800 sandpaper.
Notice the fine shavings from the planks that were trimmed.  The plane will be used to tapper the planks as the finish if far better than a knife or sandpaper.  For curved planks the Veritas Miniature Low Angle plane is an excellent plane.
24_PlankPlane.thumb.JPG.91f2e189f47292596421ce77eee01313.JPG    25_VeritasPlane.thumb.JPG.3f8fd1428239d3d9dcc085b1b5b2a546.JPG
Ready for lining out and planking.
Edited by TannumIan
Ian
Current Builds
BELEM AL Scale 1:75
The hull planking is divided into 3 bands of 5 planks.  Full width planks of 5mm will taper to 3.6-4.0mm at the stern and stem.  As this is my first planking effort, the bands around the keel will be fitted first where they are least visible.
I have finished the planks with thinned Wattyl sanding sealer to stop any dirt and grime buildup on the timber before fairing the hull.  This sanding sealer powders well when sanded without clogging the sandpaper.
The next big job is to build a quick release plank vice.  The vice shown below is slow and tedious to use.
The Veritas Miniature Block Plane shapes the planks with ease until you meet some of that curly grain.  I keep the curly grain planks for straight lengths as it refuses to bend and be seated with accuracy.
While this jig is functional, it is slow to get the plank out for measurement and back to the jig.
I have some of these toggle clamps to use in the new plank jig.
Hopefully I will get this done before XMAS when the noise and time constraints start.
Edited by TannumIan
Ian
Current Builds
BELEM AL Scale 1:75
The lower hull planking is now complete.  It was a steep learning curve that just had to be done to get some practical exposure to planking.
While the result is a bit rough it is suitable for filling and painting black.
Next step is to complete the upper hull planking.
Ian
Current Builds
BELEM AL Scale 1:75
A major milestone is reached - Planking is now complete so the filling and final fairing can start.
I have placed the cabin and masts in position to get an idea of the hull shape.  This is a feel good look rather than any build planning.
In 50 years of modeling this is the most challenging item I have made.
Like balsa, sharp tools are a pre-requisite to aid in the best outcome to any wood machining.
I have read in build logs to treat every plank as an individual project.  This is so true.
Tonight will be spent studying the manual to determine all the holes that require drilling in the hull.  I think it will be be best to do now rather than later.
The stern has nice curves.  The 2mm² planks were very flexible after some steam treatment and only required rubber bands to hold them in position while the glue dried.
My wood filler has suffered from old age so tomorrow I am off to Bunnings (aussie Home Depot) for some Poly filler.
Edited by TannumIan
Grammer
Ian
Current Builds
BELEM AL Scale 1:75
CHANGE of PLAN
I started this build as a learning exercise as it had plenty of planking and rigging.  The end result was not expected to be that good and would have probably ended up in the bin.
However, the hull when painted will be satisfactory so I have decided to keep the model when finished.  To that end I have acquired an old AL Virginia kit that I will use for some rigging practice and hopefully do a reasonable job of the BELEM rigging.
Progress so far has been fairing the hull and making some of the smaller components.  I have decided against trying to paint a timber finish onto the plywood parts and just used some Golden Teak stain for the finish.
Next steps are the decking and preparing the hull for paint.  I have to find a way to airbrush the port holes without sending them into some endless orbit.  The plan is to use an etch primer before the main color.
Ian
Current Builds
BELEM AL Scale 1:75
Ian,
Nice work. This may be your first sailing ship build and the most complicated thing you have modeled, but your prior modelling experience shows. You are doing a very good job - especially for your first hull planking!
Phil
Current build: USS Cape MSI-2
Yves, Phil
Thank you for your kind words.  The stylish lines of the hull will only get better when painted with gloss black.  I am also considering only having the standard rigging or maybe one or two sails.  Does anyone have an opinion on not installing the running rigging and sails.
Thanks
Ian
Current Builds
BELEM AL Scale 1:75
For something different, I am building the smaller parts into final assemblies.  Below are the hatches and light/vent boxes.
The PE parts are stainless steel and much easier to work than brass that must be annealed to avoid work hardening and cracks.
Paint finishes are a regular topic so I have included what I used on the PE parts - generally what I have for the plastics car models.
The SMS Etch Primer was the first coat on the metal followed by grey surface primer and then white lacquer.
I have always used Mr COLOR Leveling Thinners for lacquer and acrylic paints. The leveling thinners was a game changer for my car finishes where a little sanding with 1500 - 5000 grit sandpaper before the cutting polishes produces an excellent result.
Ian
Current Builds
BELEM AL Scale 1:75
I have decided to assemble and paint all the PE and cast parts in 1 or 2 batches.  There are many hours filing to clean the s...alloy cast parts but the end result will be worth the effort.  Below are some photos of the portholes and rudder ready for etch primer.
Ian
Current Builds
BELEM AL Scale 1:75
  • 5 months later...
This build stated as a learning exercise with the end result being a throw away.  This is no longer the case and I will aim to build a ship that presentable to most people.
After completing the hull and starting the deck it became apparent that I had to educate myself to have a deeper understanding of the deck and rigging construction.  Then there is the replacement of the smaller parts laser cut from plywood that are weak,  unusable and look terrible.
Pin rails and belaying pins
The kit provided 2mm plywood for the rails and 0.8mm brass for the belaying pins.  I will replaced these with walnut rails and the Syren belaying pins.
Rope
I purchased the Syren Rope Maker and some Gutermann Mara121 and Mara151 thread from Ropes of Scale.  These treads can produce 3 strand ropes from 0.010" to 0.060".  I have yet to experiment with the 4 strand rope.
With a little practice and experimenting making rope is easy.  It is also a good talking point.  The Chuck Pasaro YouTube videos are the most concise resource while the forums have a bit more theory and alternatives (but be prepared to go down a rabbit hole).
Rigging and fittings
There plenty of excellent resources available with the forums and books.  I have 2 books that show the rigging systems in detailed sketches.
They are
The Rigging of Period Ship Models A Step-by-Step Guide to the Intricacies of Square-Rig by Lennarth Petersson
Rigging Period Fore and Aft
For fittings I purchased the Syren blocks.
Ian
Current Builds
BELEM AL Scale 1:75
Replace Pin Rails and fit Syren Belaying Pins
The existing ply pin rails have been replaced with laminated 0.4mm ply.  I used 3 layers of 0.4mm ply that were each rotated 120° and glued with Titebond.  The resulting  board was very stiff with no weakness in any direction and could be worked without any tear out.  Mounting posts were made from 1/32" brass rod and concentric sleeves to make an overall 3/32" diameter post.  The pin rails were finished with Syren 1:64 Belaying Pins.
This is the AL version of pin rails and the new laminated plywood pin rails.
PR01.thumb.JPG.e4987d5f6fd59e1aa5e11a5a3e392156.JPG  PR02.thumb.JPG.b2510bd1c6594038e8f5110410e14fc5.JPG
I made the posts from brass as I had the material and it easy to work and fit.
PR03.thumb.JPG.3fda40923e83e47e0c1f416a88911486.JPG  PR04.thumb.JPG.3682ba2c3f59d7af0d46b4751c18546e.JPG
Fitting the posts to the deck was easy to align by drilling through the rail and deck together and inserting a brass pin to hold the rail position while the other holes are drilled.  Then just insert the brass sleeves to complete the posts.
PR05.thumb.JPG.4243099ef78277fa0d08cb20077a16a1.JPG   PR06.jpg.5b79f909675f2edcd2ef6cb4da756981.jpg
The end result is now presentable but I will give the timber pin rails a slight reduction in size before final painting and fitting.
Edited by TannumIan
Ian
Current Builds
BELEM AL Scale 1:75
  • 4 months later...
I have had a break from the BELEM after mast pin rails and the ladder PE parts crumbled.  Moving on, I have painted the hull and prepared most of the deck parts for final assembly.  While waiting for the new PE ladders to arrive I built some out of scrap timber.  I will use the brass ladders as this is closest to the full size ship - photos seem to show brass treads.
The mast pin rails were made from 3 layers of 0.5 plywood.  The larger Syren belaying pins look the best even though they are a bit oversize.
The final ladders will be the brass treads glued to the original side rails.
The plastic parts trays were money well spent to keep all the parts neat and tidy.
Ian
Current Builds
BELEM AL Scale 1:75
