Thought I would get a drawplate, but since the Byrnes is not available, is there a good alternative?
Current Build
Midwest Crabbing Skiff
Completed Builds
Model Shipways Lowell Grand Banks Dory (1/24)
Midwest Skiff (1/12)
Build Queue
Model Shipways Norwegian Pram, Model Shipways Muscongus Bay Lobster Smack, Midwest Crabbing Skiff, Midwest Sharpie Schooner, Midwest Sea Bright Dory, Midwest John Alden Sloop, Midwest Chesapeake Bay Flattie, Midwest Sakonnet Daysailer, Dikar Hawkins Gunboat #3, Dumas Skipjack, Corel Shenandoah Confederate Smuggler, Blue Jacket Schooner Yacht America 1851, Amati Pinta
10 minutes ago, Dziadeczek said:
Jewerly equipment suppliers have various draw plates.
Yes they do but they're about two or three time as expensive as the Micro Mark version. On the up side you can be sure they'll work very well. But yes Otto Frei, Contenti, Rio Grande all have drawplates. Actually Contenti carries some in the same range as the Micro Mark.
Aren't those made for wire?   I read the wire drawplates are not interchangeable with drawplates made for wood.
Edited by jcurtis55
typo
Current Build
Completed Builds
Build Queue
1 hour ago, palmerit said:
I just bought a bought a Byrnes. It arrived a few days ago. Maybe I got one of the last ones they had?
Their web site says they no longer have them in stock.
Current Build
Completed Builds
Build Queue
Amazon has several draw plates, their prices ranging from inexpensive to quite pricey.
Notice that the holes in the plates are drilled not simply through, but their profile is conical. Which means that on one side of the plate each hole is bigger (base of the cone) and on the other side it is smaller (apex of the cone).
The same plate can be used for pulling through a soft metal wire, as well as drawing wood.
You insert a wire from the base side (larger hole) of the plate and pull it through the apex (smaller hole).
With wood you do it from the opposite side.
In other words, to make a thinner wire, you squeeze it through the plate, but with wood, you shave it (apex side has sharp edges).
From my own practical experience with a draw plate, the best wood is prewetted bamboo (skewers from grocery stores), because bamboo has long and strong fibres that can withstand pulling with forceps. Other wood tends to break more easily.
If you want to use something other than bamboo woods, like fruitwoods, or boxwood or similar for your treenails, use rather treenail cutters from Vanda Lay Ind. - he used to make them in 3 sizes, later on only 2 and finally, as far as I know, stopped making them altogether. Possibly you can still get this gadget on Ebay or similar sources.
Picked up a drawplate from Model Expo for $12.   I'll try it before spending over $50 at Micro Mark.
Current Build
Completed Builds
Build Queue
Hello,
jewellery (wire) draw plates usually have a chamfer on the small side of the holes, so wood is not shaved when trying to draw through. One could try to grind the plates till the chamfer is away, but it's a lot of work the plates being hardened steel, and you'd have to go through all the grits like in knife sharpening, otherwise there'd be scratches in the dowels. Also I've got cheap plates that are awfully warped, so grinding would be out of question.
