Trevor is right about the instability of the heavily rigged American topsail schooners. The British originally had more conservative rigs, but the American vessels could just run away from them to avoid a fight. When the Brits did start using the larger tophamper they learned just how dangerous it was. I think it was in one of Chapelle's books he repeated a British captains story of a topsail schooner that was passing his ship running with the wind in heavy seas. The schooner rode up on one swell, dove down bow first into the next, then cartwheeled stern over bow and dove out of sight in seconds taking all hands with it!
I looked at Chapelle's drawings of the Lynx in "The Search For Speed Under Sail" and in both the hull drawing on page 217 and the sail plan on page 219 the fore mast rake was about 13 degrees and the main mast was about 14 degrees. The drawing says the vessel was built in Baltimore in 1812 and the lines were taken at Portsmouth, May 1816, and the plans are at the U.S. National Museum, Smithsonian Institution. These rake angles are common for Baltimore clippers, and usually the greater rake is on the main mast! If you look at the photo of the Lynx model at the U. S. National Museum on page 216 it looks as if the main mast has a bit greater rake than the fore mast.
However, if you look at his drawings of the Musquidobit on pages 84 and 85 of "The Baltimore Clipper" the rake angles are 17 degrees for the fore mast and the main mast is 14 degrees! This "draught" is labeled as taken at Portsmouth Yard, May 1816!!
Note: In both cases I measured the angle to the waterline marked on the drawings. But the hull plan "waterlines" are drawn parallel to the bottom of the keel. The keel had greater draft at the stern than at the bow.
And to confuse things even more, in Chapelle's "History of the American Sailing Navy" Plate X after page 74 (a photo of an original sail plan drawing) shows an 80 foot schooner named Lynx with a foremast rake of 10 degrees and the main mast at 11 degrees. He says (page 292) this schooner was built in 1814 at Washington or Georgetown, and was lost in 1820 in the West Indies (page 354) while still in American service!!
If you figure this one out let me know!
Edited by Dr PR
Phil
Current build: USS Cape MSI-2
My best guess is that the explanation lies in Chapelle having an enormous field to explore and only one lifetime in which to do it. He worked fast, covered a lot of ground but in process made mistakes, which fall to us of later generations to correct. No criticism there: Where would we be today if he had spent his time perfecting "American Sailing Ships" at the cost of never publishing his other works at all?
I suspect (1) that only the one Lynx / Musquidobit had her lines taken off, (2) that that job was done in Portsmouth (England), where they seem to have had a dock set up for the purpose, (3) that the original draught is still in the Admiralty collection in London (probably now in Greenwich), (4) that a copy of that draught (either a photo reproduction of some kind or else Chapelle's re-drafting) is in the Smithsonian, and (5) that when he re-drew the plans at smaller scale for his books, he was not as careful as he might have been. If so, anyone building a model (or a full-size replica!) has the option of raking the masts as seems right, given what is known of other, similar vessels, or paying for a copy of the original draught.
Trevor
Thank you, Phil. I will remeasure the rake on the Musquidobit plans using the base of the keel as a waterline and see what I get. I am planning on getting this as historically correct as I can but, that being said, I doubt anyone visiting our home will have a protractor with them :)
At least we have a window to work in. From what Phil has said here and in other conversations, it would appear we are looking at numbers between 11 and 15 degrees. You made a good point, Trevor, about the scaling down of the plans for the Chapelle book and the inherent errors therein, quite valid. To be 100 % correct here one would really need to get their hands on the plans you mentioned that might be at Greenwich at this point.
I grabbed the low res image of the plans from https://prints.rmg.co.uk/products/lines-plan-of-musquidobit-1813-j7636
Brought them into Fusion, and made a quick measure of the angles.
I get 13.4 degrees for the foremast and 10.1 degrees for the mainmast.  These might be off by a few tenths of a degree since I was just eyeballing my drafting lines in Fusion.
I've done this for a few other schooners, and the masts are never parallel.  There is always some difference in the angles of the rake.
Peter
In progress: Amanda F. Lewis, Chesapeake Bay pungy
Completed builds: Virginia 1819 from Artesania Latina, Sultana (gallery) with laser cut POB hull and 3D printed components
Excellent, thank you, Peter. I think I will go with those figures and be done with it. I recently looked into Fusion with regards to 3D designs. I have the "home use only" free version. Maybe I should spend some time getting to know it better. Up to now I have used Tinkercad more than anything else which, since they added the new sketch tool, has gotten a lot better.
On with the build then.....
I measured and shortened the base of the transom then glued it in place:
By the way, there is A LOT of char on anything I cut out of the laser cut boards. I have to take them outside to sand away all the really black edges. Nasty stuff, it looks and smells like soot. Next up I glued the knees in place:
And the lower deck was planked and fitted. I know planking wasn't necessary here but it served two purposes - 1. It is always good to practice and 2. I will know it is there :) You will be able to see it if you happen to look into any of the hatches too. I did realize the scale of the planks I used was a bit off (after the fact) but this is not the main deck so I left it as is.
Once the lower deck was dry I did a 50/50 glue and water wash on all the bulkheads to tighten them all up before the planking starts:
The transom itself was then clamped in place and left overnight to conform to the correct contours. The next morning I glued it in place too:
I fabricated the counter and did a dry fit. This is where I am veering off the Panart plans and actually doing something related to the Mosquidobit build plans. It will need some fine tuning but I am happy with the way it looks:
The Panart plans suggest planking the boat with both layers before adding the cross beams that the main deck will sit on. Because I am intending to put some fillers in between some of the bulkheads and I don't want to have to sand or chip them away when the bulwark stays are cut off once the planking is done, I wanted to know the height of the deck. I intend to stop the fillers below deck level. I hope that all made sense. Image to follow once I have it done.
Edited by SaltyScot
Text added
Mark, I've been looking at the last few pictures in your last update, and I fear that the shortening that you've done at the stern will cause some issues.  To my eyes, it looks like the transom and sternpost are too close together and this won't allow enough room for the rudder stock to come up between them.
Peter
Peter,
Wow, that is something I had sadly overlooked and thank you for pointing it out. I am going to be out all day tomorrow and will probably not be back in the shipyard until Tuesday some time. That will be the first thing I will tackle, sir.
Peter,
Thanks for the measurements. They are close to what I got from one of Chapelle's drawings. And it dpes seem to confirm that the foremast had a greater rake than the main mast.
Mark,
I like what you have done for the stern counter, but I agree with Peter that you might not have enough room for the rudder post. You can do two things:
1. If you are confident about your deck measurements and overall length of the hull you can carve off a bit from the rear of the false keel/center piece to move the rudder post forward sufficiently.
Note: The "length between perpendiculars" that is often used to measure hull length of wooden sailing vessels is from where the front of the bow cuts the water at the normal load waterline (Fore Peak) to the normal load waterline at the center of the rudder post (After Peak). If you have this dimension for the Lynx you can check where your rudder post should be.
2. Or you can remove the transom, extend the framing a bit and reinstall the transom.
Before you start any planking on the hull or the deck I advise you to check the side-to-side (transverse) dimensions from the center line to the outside of the frames, especially at the stern. On my schooner build (started in the 1980s) I somehow got the distances port and starboard at the stern unequal by a bit. When I was planking the deck and came to the part for nibbing the planks into the margin board/waterways a few years ago I discovered the mistake. That left me scratching my head for a solution.
Fortunately I was able to cut the nibs into the margin board a little deeper on one side so the ends of the planks were aligned on both sides. Unless you know to look you would never notice the difference - especially now that a lot of this area is covered with the boom, sails and rigging.
But it is a good idea to stop, take a deep breath and recheck all of the dimensions before planking. You can always make corrections by sanding off a bit from the outsides of the bulkheads before starting the planking. After you have installed the planking it is too late.
Phil
That was my intention, Phil, but the idea of basically shortening the false keel is a valid one. I will be sure to get those measurements before I do any cutting or sanding. Thank you for the graphics.
As far as the transverse dimensions go, I am so very glad you pointed that out. It was something I believe I had read somewhere when I first joined MSW but, with everything else I read, it got lost in the hubbub. Measurements will be taken, sir, of that I can assure you. What @SardonicMeow said about the transom being too short was the first lucid thought I had this morning and, like I mentioned last evening, it will be taken care of as soon as I am back in the yard.
I was able to get the transom off and the size readjusted. I had originally cut it down by 10 mm. I added 5 mm back on by adding a piece of the same wood the laser cut pieces were taken from. The support knees were removed and the counter was then refitted. I will do the final sanding once everything is nice and dry:
As per @Dr PR's recommendation, I measured the transverse dimensions from the centerline to the outside of the frames. I only had two that were at most 1 mm off. A quick sanding will take care of that. I noted the measurements on the bulkheads so that I would remember which ones they were:
I am just about ready to begin planking now. Believe me, there will be a lot of checking and measuring and rechecking before the first plank goes on :) Before that though, I want the deck beams on and the bulkhead fillers in.
Edited by SaltyScot
Text added
Looking good!
Before you put a lot of planks on the hull clamp one on each side at the top of the bulkheads. Look at it from straight on bow and stern and see if both sides have symmetric curvature. I see a fair number of models that have wavy or asymmetrical curvature to the cap rails on the bulwarks because this last check wasn't performed before starting the planking.
Your measurements and sanding probably will be enough, but it doesn't hurt to make this last check. This is a last chance to get it right.
Phil
I actually did that check on the Endeavour hull too, Phil. It certainly paid off.
I had noticed an error on my part when I "fixed" the transom. The intention was to move the counter away from the keel post to make place for the rudder head (thank you once again @SardonicMeow for pointing that out to me). What I did instead was just increase the wrong side of the transom plate which didn't really affect the counter at all. I stripped it all down this morning, made new parts, including the counter, and glued them back on. I took the enlarged plans of the Musquidobit to hand and tried to replicate the counter she had (see red circle in the image below). I liked how the keel post fed straight up into the trailing edge of the counter.
I had luckily not thrown away the support knees to mount the transom piece itself so they got tacked on again and the transom remounted.
I received a nice message from @Jolly Jo this afternoon. He had found a build log for the Lynx in a German magazine from the 80's and sent it to me (thank you again, Jo!) What is very interesting is the image on page 17 of the magazine. It is titled "Baltimore Clipper 1812" and has a fantastic drawing of the deck plan. The odd part is the keel post and the counter. In this image from the German log, she has a counter:
In the 1812 Lynx plans I have, she has no counter:
I just found that interesting is all. The German log plans also show how the cannons were placed and rigged. Priceless!
Hi Mark,
That plan (Chapelle's from "Search for Speed Under Sail") does have a counter, its shape where it crosses the centreline here marked in red:
The German deck plan certainly looks nice but I wonder whether it is anything more than a re-interpretation of Chapelle's version, in "Baltimore Clipper". They all rely on the 1816 draught, prepared in Portsmouth, because there is nothing else specific to this one vessel. You have posted part of that draught and (as expected) it had internal arrangements shown on the longitudinal drawing. Whether it also had a deck plan, I cannot say, though I think that would have been unusual at the time. If not, all reconstructions must take the locations of hatches etc. along the midline of the deck and infer what, if anything, was placed outboard of those.
Trevor
See, blame that on my not only old eyes but inexperienced ones as well :) I guess it was my excitement that clouded them over, Trevor. Always nice to her from you sir and thank you.
Hi!
I've been following the construction report from the beginning.
I noticed that the French plan of the ship, from the first album of Admiral Paris Souvenirs de Marine, shows the construction of the rudder and sternpost in more detail. Perhaps that will be of interest to you.
I'm attaching the relevant plan excerpt.
Edited by Chapman
Well thank you, Chapman, that was a nice thing to do. I did have the plans from Chapelle's book enlarged but this graphic is nice and crisp. Thanks again.
Today I decided to start fairing the hull and, after finishing up the transom (finally!) I test fitted the rudder:
I wanted to do a dry fit of the first strake and looked at the plans to get the correct measurements for where exactly the strake would sit:
I then placed the plank accordingly to check the run along the bulkheads:
I decided to make a simple jig to preshape the plank. I copied the shape from the kit plans and transferred it onto a piece of wood that I could lay the plank on. Then, it was simply a matter of soaking the planks (I did both sides at once) for a while and then securing it to the template with push pins:
I will let these dry overnight and let them take the shape.
I now turned my attention to seeing how the deck would sit on the cross beams once they were installed. I had wanted to put them in to get a deck height check on the bulkheads so that I could drop a few fillers in below deck level. Using a thicker plank from some scraps I had, I laid it across the beams:
The bow and stern beams sat well and the plank I laid across to test the height hit all of the beams:
The midship beams were a different matter. One of the beams was seriously low:
My immediate thoughts are to bolster this beam up with shims to meet the deck height. At this point I can see no reason why I should not do that. If any of you see an issue I am overlooking, please feel free to chime in 🙂
Edited by SaltyScot
Image removed
I don't see anything but that looks a very big offset to be an error in the kit's manufacture. Is there any other part to go in that might explain it -- structure around a hatchway, perhaps, or support for a mast or something? You have probably read through the instructions and checked everything but, if not ...
Mark,
That beam definitely needs to be raised to meet the level of the other bulkheads. I have had this happen with kits too. Perhaps the bulkhead is a bit too low. If so you might see some problems with hull planks around the turn of the bilge.
It looks like the low spot is just aft of the main mast. Maybe there are structural pieces to frame the mast opening (partners) that rest on this bulkhead.
On my Albatross build I had to add shims to the tops of several bulkheads to get a fair line for the deck.
You may also need to shave a bit off the tops of other bulkheads to get a good lay of the deck.
When bending planks it is best to heat the planks to make the bending go faster. I use a small quilting/plank bending/sail making iron and usually bend the planks in situ on the hull. to get the proper curves and twists in the planks.
https://modelshipworld.com/topic/37060-uss-cape-msi-2-by-dr-pr-148-inshore-minesweeper/?do=findComment&comment=1074225
https://modelshipworld.com/topic/37060-uss-cape-msi-2-by-dr-pr-148-inshore-minesweeper/?do=findComment&comment=1075263
Phil
Thank you for the comments @Kenchington and @Dr PR. I had looked through both the plans and the instructions regarding the gap but could see no indication that the space was dedicated to anything in particular. I am going to recheck dimensions and spacings and then start shimming and/or sanding down.
The reason for the low beam has been discovered. The CEO just happened to be in the shipyard this afternoon and I mentioned the issue to her. She saw straight away that bulkheads 6 and 7 were in the wrong place. If we go back to the 4th post in this blog, I wrote how similar those bulkheads were and that I had to change my decision as to which one was which several times:
The solution is simple, I will lower #6 by filing it down to the measurement of #7 and raise #7 accordingly (if that makes sense). Once done I will check the outer measurements and make sure the "flow"of the hull is correct. By the way, the red numbers on the "ears" of the bulkheads that you see in post #52 above correspond to the cross beams and have nothing to do with the original bulkhead numbers (didn't want anyone getting confused there).
Edited by SaltyScot
Text added
The issue is resolved. I had some 2.5 mm thick strips in my wood shop from some past job. I needed to add 2 mm to bulkhead #7 and take that much off bulkhead #6. The deck line is a lot smoother now and contacts each cross beam on the way across:
Mystery solved!
For what it is worth, you aren't the only one to switch two bulkheads. On my Cape scratch build I carefully cut out each bulkhead, using pasted on prints of each one drawn to scale. Then after I had them in place on the center piece/keel piece there were nasty wavy high an low spots when I was fairing the bulkheads for the planking. I finally realized that I had mis-labeled the two parts when I was preparing the template drawings that were glued to the plywood to guide cutting out the parts! I had to take a bit off one and add some to the other.
This is why I recommend pausing and measuring everything before starting the planking - or installing the deck. After the planks are on it is too late to correct mistakes.
Phil
What would we do without our spouses! Great that you could so swiftly correct the trouble.
But it is good to know that the kit manufacturer was not that badly out with one bulkhead. That would have shaken my confidence in all kits.
Trevor
Phil,
I was going to ask if you wet them beforehand but then hopped over to the links you shared and read the notes. I am going to get one of those wee irons, it will be a valuable addition to my (ever growing) tool chest here in the shipyard. As always, your insight is very much appreciated sir.
