9 hours ago, Kenchington said:
My alternative was to cut a new bottom piece for the step from the same sheet of basswood..... I made sure that the grain ran along the length of that bottom piece
Good call, Trevor. That was just a split waiting to happen with that grain on the footer the way it was.
Step 15, inwales, completed; Step 26, rubbing strakes, largely done; Step 40, display stand, begun
The pram has the upper edge of the sheerstrake sandwiched between 3/32-inch square-sectioned "inwales" (ugly term but I don't think there is a better, standard one) and 1/8-by-3/64 "rubbing rails" outboard, lengths of appropriate stock being supplied in the kit. The former need to be steam (or alternative) bent and I should have set that up to dry overnight. However, they are so thin that they dried quite swiftly, without loss of time. I bent them along the outside of the sheerstrakes, which worked well.
Getting them to fit inside was more tricky, as there has to be a 3-D bevel at each end, to fit against the transoms, while the length has to be just right to put both bevels into place. After a long job with the first one, I evolved a better solution:
With the bent inwale loose in my fingers, I held one end against the edge of the transom and drew a pencil line where transom and inwale crossed. After bevelling to that line, I worked by trial and error, first adjusting the second dimension of the bevel, then perfecting the fit (or close enough to perfect to satisfy myself). I then turned to the other end of the inhale and shaped the much more awkward bevel against the bow transom. That gave me a bevelled inwale but one much longer than the space available. I dry fitted the bow end in place, clamping to the sheerstrake and working aft, until I could  go no further. The surplus end of the inwale projected outboard of the stern transom and above the sheerstrake. I penciled a length mark, removed everything, cut at the mark and then aligned the cut-off end with the new cut. With the old end as a guide, I started the bevel of the new end.
Because of the rake of the transom, there has to be quite a bit more shortening, in order for the aft end of the inhale to drop down, flush with the top of the sheerstrake. That shortening gives plenty of opportunity to perfect the bevel. So I clamped the forward end of the inwale back in place, gently pried the aft end away from the stern transom, sanded the bevel, dropped into place, lifted, sanded some more, dropped back ... and on and on until everything fit.
Compared to all that, applying glue and clamping in place was easy:
(I bought all those pegs because that's how many the hardware store sold in one pack. Never thought I would us them all at the same time!)
The instructions leave the outboard rubbing strakes until later in the build but I decided to complete the strengthening and stiffening of the upper edge of the hull at one go -- not least because it will simplify sanding everything flush. So, once the inwale glue was set, I removed the clamps, glued and place the rubbing strakes and re-clamped. That was almost too easy: No need for pre-bending, as the stock is so thin, no worries over length, which was trimmed after, not even any char to remove. Just glue in place with the upper edges of the three layers flush. Even that need not be exact, as the combination will have to be sanded later.
The combined effect looks good, though only a small advance in the past 24 hours:
Wales2.thumb.jpeg.9ae20d25a909c3d00a01058d371938ec.jpegWales3.thumb.jpeg.304ccd0fb516cd423a19c4099776eef6.jpeg
While waiting for the inwales to dry in their new curves, I made a start on the display stand. When building my banks dory, I wanted an unobtrusive stand that would not draw the eye away from the model. What I ended with was a fully functional stand that is downright ugly. Not a problem with a model that hardly needs a stand at all but a lesson for the future.
The pram has a long daggerboard, which necessitates a tall stand that cannot be hidden. The model should turn out to be a pretty thing but without much point except its prettiness, so the very visible stand needs to complement, not detract from, the appearance. The kit stand comprises two shaped cradles elevated on dowels, rising from a simple baseboard -- simple, cheap (as it should be in a beginner's kit) but not attractive. The cradles are necessary and I will use the kit ones. The instructions do suggest replacing the dowels with clear acrylic rod. $10 to Amazon is bringing me enough for a dozen pram models. I also have the good fortune to be within easy reach of a specialty timber importer, where they put the offcuts from orders of exotic lumber into bins that locals can rummage through. $5 bought me more than enough jatoba to make a good, thick plinth (with a nice, rich colour) on which to mount the kit's baseboard. (For $35, I could have had genuine ebony but that would be hard to justify!)  So, today, I put a 45° bevel around the kit-supplied base. Tomorrow, I'll paint that and run the edges of the plinth past a suitable router blade to give them some interest. If all goes well, I'll glue the painted basswood to the jatoba and add the acrylic at the weekend.
Trevor
Wether they are called inwales or inhales (forgive my sarcasm, couldn't help meself :) ), it sounds extremely intricate. Is the build on a Dory aways that involved?
And I thought I had caught and corrected all of the gasps! I could ask why the MSW auto spelling-corrector doesn't use a custom dictionary with common shipbuilding terms included, but it doesn't. Every "inwale" I typed became "inhale" until bludgeoned into accepting that I did intend the "w".
I don't know whether the pram is really so very involved. It can't be as complex as a rigged model of a three-master and I doubt that it is as demanding as a plank-on-frame model with an exposed frame. It doesn't even have hood ends fit into rabbets. The only thing that makes it complex is the desire (in a large-scale;e model of a small, open boat) to replicate every piece of wood in the full-size prototype. That and my intention to give mine a clear finish, hence to build without using fillers.
Wait until the build progresses to the metalwork. Then you can watch my fumbled attempts to meet challenges far outside my comfort zone!
Trevor
Which you are doing a fine job at by the way.
Steps 16 & 17, quarter knees, Step 20, transoms completion, and Step 26, rubbing strakes: All completed
Display stand (Step 40) advanced; spar-shaping jig (part of Step 42) assembled
Today's principal task was adding the four "quarter knees", which lock the sheerline assembly (inwale, top of sheerstrake and rubbing strake, combined) to each of the transoms. The long arm of each knee, which fits on the inboard face of the inwale) only needed removal of char. The curved face needed that, edge softening and some rounding of the toes into nicer shapes. It was the short arms of the knees which needed work. The ones faying on the stern transom had to be bevelled to an angle that was off-perpendicular in two dimensions. The forward ones were simpler.
Seen from inside the boat, the knees are angled upwards across the transoms, as they are at right angles to the sheerstrakes, which are slightly flared. I followed a recommendation from a previous build log and marked where the knees should lie, as any asymmetry is liable to stand out like a sore thumb. At the bow, however, I already had asymmetry which had to be concealed a little. Not a big problem, however, and the knees were readily glued in place.
One point to consider, however: Under Step 53, a length of line has to be fed through a hole in each stern quarter knee (the line forming the mainsheet horse, though it is curiously called a "traveller" in the instructions). I don't think that the instructions say anything about those holes, except that the line must be passed through them. I decided to drill them while the knees were still in their sheet, which gave better control. The instructions call for the mainsheet horse to be made of 0.7mm line. That seems a bit small to me and I may use larger, so I drilled 1.4mm holes (having a drill bit of that size to hand). That will be small enough that a figure-of-8 stopper knot tied in 0.7mm line won't slip through, while making it easier to pass 1.0mm.
With the knees in place, the whole sheerstrake structure could be sanded to its proper form: Ends of everything sanded flush with transoms, then the ends of the rubbing strakes rounded off, the top surface of the inwale, sheerstrake, rubbing strake and quarter knees sanded flush (and perpendicular to the sheerstrake), finally the upper and lower angles of the rubbing strake rounded a little. (I have left softening the inboard angles of the inwale until the rowlock structure is in place.)
While I was at it, I cut off the extended parts of the transoms (which had served to hold the boat on its building board), sanded the transom tops down to their laser-cut marks, rounded everything off and finally filed the sculling notch in the stern transom. The instructions call for the latter step to be done with a 3/8" round file. As has been noted before on MSW, that should probably read 3/16. No matter: I had neither size but worked the notch anyway with both a small round file and a larger half-round. The end result of that effort is falling far short of perfection but at least is looking increasingly boat-like:
Sheerline2.thumb.jpeg.f8ba380ae3d0558d7f8a256fc1fb1839.jpegSheerline3.thumb.jpeg.387adbea8501269210085457df31e0a9.jpeg
While all that was in progress, I put together the kit's jig for shaping round spars from square lumber -- mostly just because that let me consign the remnant of one basswood sheet to the scrap pile. The jig accommodates five spar supports but the kit only provides four. The easy solution, having bought the combo set of three kits, was to pirate a fifth support from the lobster-sloop kit.
A word of warning for anyone assembling one of these jigs: The supports are very slightly too big for the slots they have to go into. However, it is not the charred sides that need to be sanded. Those can be left full-thickness, for a tight fit, while the other faces are sanded. (I did take the char off surfaces that the spars will lie on, to avoid staining wood that I want to keep.)
I also primed the kit's display-stand base, while shaping the plinth that it will go on:
Just a simple ogive, in keeping with the clean lines of the pram. The jatoba is a much redder shade than appears in this image and will be richer still once oiled.
Next up: Framing the upper parts of the hull, supporting the thwarts and stern sheets.
Trevor
That looks a lot like the stand I made today for the Endeavour. It is red oak coated with a red oak stain, which turned it a nice deep golden brown (more golden that the image is presenting). I finished off by sealing it with a Minwax finishing wax. It still needs another polish. Great minds and all that.......
Completed internal structure, all Steps through to 22.
The pram has five pieces on each side that the instructions call "seat and thwart frames" but which fill similar functions to the futtocks and hanging knees of wooden ships. They support the two thwarts and a large after seat (the "sternsheets"). The instructions detail where the ten items should be placed, even including a paper template, but only their longitudinal positions and their orientations. As others have noted before on MSW, the booklet is entirely silent on the heights at which the thwarts and sternsheets should be, hence the heights at which the pieces should go in. I suspect that it says nothing because those heights are largely determined by the already-present structure -- though it would help if that had been explained.
The after edge of the sternsheets rests on the top edge of the lower transom (where it provides a shelf abutting the upper transom). The plans of the full-size pram indicate that the sternsheets should extend forwards parallel to the underside of the skeg, which follows the baseline of the design. Meanwhile, the upper surface of the midships thwart has to be flush with the top of the daggerboard case. One of the supports of the forward thwart is notched to fit under and around the inwale, thus defining the height of that thwart.
Seeing all that, the obvious thing was to start by dry-fitting the midships thwart, mark the positions of its two supporting pieces each side, and continue form there. Unfortunately ...
With the inwales in place, the hull is now too narrow for the full length of the midship thwart to pass! (Considering that the instructions call for the inwales to be fitted at Step 15 but the thwart not to be finally placed until Step 34, one might have hoped for some sort of warning.) Still, not a big deal: Mark the thwart for the available width, cut off the ends, surely the flare of the sides will make the maximum that can pass the inwales more than the minimum required for the thwart when in position? WRONG!!! Now I will have to make a new thwart from basswood stock and, once made, it will have to be passed below the inwales diagonally, then jiggled into position. That's not a job I want to do twice, so I will assemble the thing once and be done. The instructions want the final fitting of the thwarts and sternsheets to be delayed, so that the hull can be painted first and the three seats then given a contrasting colour. As I'm planning on the same clear finish on both, that's not a problem for me and I can go ahead and glue all three in place.
However, there are also battens supporting floorboards, which would be hard to fit once the thwarts and sternsheets were in place. So the only option for me was to re-arrange the whole sequence of the completion of the pram's interior.
1: Before the floorboard battens can go in, the position of the timbers supporting the forward end of the sternsheets must be determined (as the battens run to those timbers but not beyond). So the first step was to dry-fit the sternsheets. They comprise two pieces. The after one has to be bevelled to match the rake of the transom, so that it sits securely on the existing shelf -- securely but also neatly, as the junction will be prominent in the finished model. That done, it became evident that the sides of the piece needed a lot of shaping. (My guess is that the kit provides for models that have been allowed to flare out wider than the moulds.  A sensible precaution in a beginner's kit.) That done, the forward piece could be shaped and the process repeated, until the two pieces sat with their edges against the sheerstrake, forming a more-or-less level surface. The fore-and-aft positions of the two supports could then be marked on the planking, tucked comfortably back from the extreme forward edge.
With the sternsheets removed again, check measurements ensured that both marks were even, lengthwise. A bit of fiddling produced a satisfying height (very close to the inwale) and the draughting compass ensured that both sides had marks an equal distance below the inwale.
2: It was then necessary to shape the two pieces provided, until they fit into the places required. That was no small task, in part because each piece was so small but more because they were not even close to the right shape. The interior of the hull naturally has steps between the strakes (as their bevelling cannot come to a feather edge) but the laser cutting made no provision for those steps -- perhaps could not, as they are so small. I did not take photos of the first four pairs of pieces but they last, smallest and most difficult (the after pair under the forward thwart) looked like:
The upper one as it came from the sheet (aside from removal of char), the lower shaped to fit.
3: Once the pair under the forward end of the sternsheets was close enough to a good fit, I tidied them up with the usual edge softening etc.. and glued them in place. That was when I discovered how far each would move under my thumb, as I held it in place for the glue to set. Oh well, they will largely be hidden by the sternsheets!
4: It was then time to think about the floorboard battens -- "cleats", a the instructions term them. They are made from 3/32 by 1/8 stock and require bending to fit the interior of the hull. (Previous build logs have noted that trouble follows if the bending is ignored.) The instructions say something vague about shaping them in your fingers. I gave them the usual boiling-water treatment, then curved them over the exterior of the hull and left them to dry overnight:
The same stock is needed (and needed straight) for other parts of the model, hence the untroubled forward projections.
5: The battens sit on the outer edges of the bottom planks, with secondary ones along the inner edges abreast the daggerboard case. As the bottom is flat (athwartships), no bevelling is necessary. I just cut off the required lengths, tidied them up and glued them in place -- with the same shifting under thumb pressure. No images of that stage but my words will be easier to understand with the photo of the finished work:
6: Next up was figuring the locations of the four supports for the midships thwart, using the old, cut-off thwart as a guide. I figured that it will be easier to sand off too high a piece than to add above a low one, so erred on the side of going high. That aside, it was just a long, fiddly repetition of the pair under the sternsheets.
7: Before tackling the forward thwart, I glued in the mast step -- which could just as well have been done when it was first made.
8: The forward supports for the forward thwart are notched to fit around the inwale, which made them easier to work with. However, the thwart is notched to fit around the supports, so it was critical that they be equally distant from the bow.
9: The final pair of supports, besides being tiny, had no well-determined height. The plans show the thwart slightly angled, sloping down towards the stern. In the end, I placed the supports such that the thwart will just clear the heads of the "frame" that bears the mast step.
All in all, a long and trying process, leading to an ugly mess. Still, I don't think it will detract from the finished model, as most will be half-hidden.
Tomorrow, I will get busy fitting the sternsheets and thwarts (Step 34 in the instructions).
Trevor
I find it quite frustrating trying to hold mini pieces like that securely enough to be able to sand them properly. You had several to do I see, a true test of patience, Trevor. I don't think it turned out all that bad, it looks nice and neat to me.
Thank you, Mark!
I my mind's eye, everything will fall perfectly into place. Somewhere deep in my belly, I expect to mess up and ruin the hours already committed to the model. Reality always seems to turn out roughly in the middle.
I expect that experienced model builders will tell me that that is how this hobby always goes.
Got the forward thwart and the sternsheets in today.
The thwart needed a lot of sanding, filing and checking -- as in: sand a bit, check the fit, sand a bit more, check the fit, file a notch a little, check the fit, increase the bevel, check the fit ... and on and on. When all was done, the underside (placed back into the gap in its sheet, to show how much I had removed) looked like:
It would not have needed so much work but I had put the supports (the ones that fit in those notches -- offering no wiggle-room) too far forward, where the pram's hull is narrower. Indeed, the thwart is so far forward that it will almost obstruct the mast:
was aware of a possible problem and did check that the thwart would not be too close. Not sure what went wrong but I was so concerned to have the two supports equally far back from the bow that maybe I just didn't pay enough attention to other dimensions of their positioning. At worst, I will have to file a groove for the mast in the forward edge of the thwart.
Once everything was shaped and in place (with some filing of the after pair of supports for this thwart), I discovered that I had given it too steep a slope (downwards towards the stern). Not a problem for my model but not something to be copied by anybody who may follow this build log in future. Anyway, it looks nice enough:
The sternsheets had to be assembled from their two (already part-shaped) pieces, with a pair of cleats to hold those together. No cleats are provided in the kit but there is more than enough scrap to cut up.
Before assembly, I rounded off the forward edge of the forward piece -- not the usual softening of angles but more like a half-round section. Did the same on the two edges of the forward thwart too. I figure that the model sailors would prefer not to have any sharp edges against the backs of their knees!
The instructions call for a narrow gap between the two main pieces of these sternsheets (with softening of the four angles running along that gap). I don't know why that is needed but I left it anyway, with a business card inserted to ensure an even width. Then, to prevent everything moving around, I taped the two pieces to my cutting board, while using the board's markings to line both of them up -- so ensuring that the elegant curve in the front of the sternsheets would be centred relative to the transom (and hence the whole boat):
When the glue had set, that needed only some more sanding and bevelling of the sides until it fit snugly into place.
However, I then found that one of its supports was so far forward that it supported nothing.  I thought that I had marked for the two of them to be safely back under the sternsheets but one support proved to be optimally placed, right by the forward edge of the sternsheets, while the other was too far forward. Further examination showed that the pencil mark was opposite the other support but the troublesome one had shifted before its glue set. So: Out with the isopropanol, off with the tiny piece, clean up the mess and re-glue. After that, the sternsheets themselves went win without problems:
In the end, quite a pretty outcome:
As I wrote in my last update, I need to make a new midship thwart. The kit part is 3/32 basswood and the only stock I have is 1/32. I may have to laminate but I would prefer to pick up some 1/4 inch in Halifax next week, then sand down. So I can't finish the pram's interior yet. Plenty of other tasks to push ahead in the interim!
Trevor
Nice job! I hadn't realized that the mast isn't supported by the thwart on this vessel. If you're concerned at all about the angled thwart, it would not be difficult to make a new one from scrap wood or a bit of basswood in the right thickness.
Thanks JacquesC!
I agree that it looks odd for the mast to be so close to the forward thwart and not pass through it. I'd not expect that in a traditional working boat. Then again, the plywood pram that was my own first (full-size) boat had a mast supported only by the step and the standing rigging. Come to that, so did the two racing boats that followed: an International Enterprise and then a Unicorn catamaran. It wasn't so uncommon for late- 20th Century recreational boats.
True, but I don't want to go through the pain of re-creating the two supports (to fit higher in the hull), then shaping a replacement thwart. I'll just learn to live with what I have!
Managed to get the last locally-available sheet of 1/4 inch basswood today, so I sawed off a suitable length and got busy with chisel and sandpaper until I had a 3/32 thwart substitute. Not too concerned about remaining irregularities, as they would be on the underside and not visible. It was probably the messiest job I have yet got into with these models:
But it was done.
Using the too-short original thwart as a guide, I was able to measure the length needed to fit the width of the hull at the required position. Then, like an idiot, laid out those measurements on the wrong side of the replacement piece and shaped that. Stupid of me. But the newly created surface turned out regular enough to be going on with.
The required length did not want to go into the hull, between the inwales, but it could (just) be done by jiggling a bit. Fortunately, my measurements proved accurate enough and I did not need much checking, removal and further trimming before it was ready for gluing in place.
This midships thwart has two small standing knees to further stiffen the structure of the boat:
Thwart9.thumb.jpeg.2747ebc43926d18e4d922a42ce620eaf.jpegThwart8.thumb.jpeg.584f9c0fb691c74f2256d955253c1e1e.jpeg
Looks good to be, except that the new thwart emphasizes the excess slope in the forward thwart. Something for people who build this kit to guard against.
With those in, the interior is complete -- save for the floorboards, which have to wait until the bottom planking has been given its final finish. There are still pads to go on the sheer line for the rowlocks, a pad on the transom for one of the rudder hangings and slits to be created in the inwales for the chainplates. Then it will be time for a final clean-up before oiling the wood of the hull. But enough for one evening.
Trevor
That just looks so very nice, Trevor. Nice job on those thwarts (I thought they were called seats......... 😉)
Thank you for your kind words, Mark!
Curiously, Smythe included "seat" in his "Sailor's Word Book" but only as a name applied to some oddly shaped mountains, such as Arthur's Seat, outside Edinburgh. But he defined "thwart" as a "seat" for oarsmen! Then again, Smythe seems to have been amused by nautical terminology, rather than being a careful lexicographer.
To me, a "thwart" is something that you sit on which spans a boat athwartships (meaning side-to-side). Something that you sit on which runs fore-and-aft is likely to be a "side seat" (unless it is a side deck, with the distinction sometimes unclear), while I would not use either term for the seats that surround a cockpit nor for something running along the centreline of a boat -- like the centreplate-trunk's cap that I sit on to row my own plaything. But that's just me.
While I have my copy of Smythe off the shelf, I see that he defined "stern sheets" as the whole area of a boat abaft the aftermost thwart, which area he says is "furnished with seats for passengers" ("seats" again!). The pram's instructions use "sternsheets" for the seat itself but I'd trust Smythe on that one: As an Admiral in Victoria's navy, he had been seated in the stern sheets of many boats.
Trevor
Today, I finished the fixed wooden structure of the pram (if the floorboards can be ignored for now). That's steps 23, 24, 25 and 33 of the instructions (though I still have to work on 27, the daggerboard, and 28, the rudder).
Step 23 has been sending shivers up my spine since I first read the instructions. It involves creating a slot through each inwale, adjacent to the sheerstrakes but without piercing those critical pieces -- each slit later taking a chainplate for securing the lower end of a shroud. The instructions say that this operation should begin one foot (1 inch at scale) abaft the hole in the mast step. It does not say whether that is abaft the centre of the hole or its after edge, nor whether the measurement should be along the centreline (probably) or perhaps following the sheer line. I figured that the really key thing is that both chainplates should be equidistant from the centre of the bow transom, lest the whole rig look askew when the model is finished. It is also necessary to place the slots clear of where the rowlocks for the forward thwart will go. In practice, all that lot fell into place quite easily and I could mark the spots.
Next, we are told to drill through the inwale, parallel to the sheerstrake but without cutting into it, using a #72 bit. An internet search turned up an extensive table of drill sizes, which stated that a #72 has a diameter of 25 thou, meaning 0.635mm. The bits that came with my kit are metric. The 0.7mm proved detectably larger than the saw blade to be used in the next task, so I drilled with the 0.6mm instead. Rather to my surprise, the hole appeared where it was required, without harm to anything else.
Then we are told to insert a #15 saw blade into the drilled hole, enlarging it into a rectangular slit (before reversing the saw and tidying the other edge of the slit). The #15 in this case is an Exacto #15 blade (which my local Great Hobbies conveniently had in stock -- none being provided amongst the tools that came with the model). The #15 did not want to go into a 0.6mm hole until that had been expanded a bit with a knife blade but then worked like a charm:
(Confession of guilt: That's a posed photo, after the slit was cut.) The instructions call for the slot to be made "scale 2" long" but, as has been noted before on MSW, the supplied chainplate is only about 1/16 inch wide (meaning 3/4 inch full-size), so a slit of around 1.5mm would be enough.
That job done (and feeling a glow of quiet pride at having achieved the seemingly impossible!), nothing could go wrong.
Step 25 calls for creating four pads, from the remaining stock left over after creating the floorboard battens, those pads serving reinforce the holes for the rowlocks. (I know that I've seen identical pads on a full-size lapstrake boat somewhere but I can't think where!) Each of the four pads involves marking off three 1/4-inch lengths of the stock, finding the centre point of the central third, drilling a hole there (with a #55 bit, according to the instructions, I used 1.6mm to aid fitting the rowlocks), before shaving the outer thirds into long bevels, then cutting the pad free:
I was unhappy with one if the drilled holes, so made a fifth pad and discarded the bad one:
The four that I kept were glued to the top of inwale and sheerstrake (not the rubbing strake). The instructions say 1' 6" aft of each forward thwart frame. I made it 1.75-inches at scale instead, as a foot or so of space from an oarsman's backside would make for very cramped rowing.
For Step 24, anther piece of the left-over floorboard-batten stock needs to have one face bevelled to match the rake of the transom (using the bevelling guide one last time). A half-inch length of that gets tidied up and then glued at the very bottom of the transom (immediately above the ends of the bottom planks), its bevelled lower face parallel to the waterline, while its upper face is perpendicular to the transom. That will support the lower rudder hangings in line with the upper ones, despite the step between the lower and upper transom pieces.
With that, all of the wooden structure permanently part of the hull was finished, so I left the glue to set for a few hours while working on a quite other project.
When building the Model Shipway's banks dory, I painted it in the expected colours for such a boat. But I wanted the thwarts to look more like bare wood, so I tried soaking them in tung oil, then drying. That worked quite well, though the oiled basswood dried to a tone little different from the buff paint of the dory's hull. Oiling did produce a nice satin finish (reminiscent of a golden varnish) without raising the grain or otherwise calling for sanding after its application, hence it could be done in the nooks and crannies of a boat's interior. With that experience, I decided to oil the pram throughout.
After a final sanding and clean-up, I just brushed on the tung oil, applying all that the wood wanted to soak up. Did the interior first, let that dry for a bit, then the exterior. I'm happy with the outcome, at least as it is now:
Hull2.thumb.jpeg.9dc077004f3cc076478aa81f90b703cc.jpegHull3.thumb.jpeg.6af86a987a5580d1aff8cc6cefacaa8c.jpeg
Time will tell whether the wood darkens too much or even that the oil dissolves the glue!
Daggerboard, rudder, tiller and floorboards still to go, before I have to learn some basic metalwork techniques -- and that at a miniature scale. And the rig to follow, of course.
Trevor
Edited by Kenchington
Yes, I like that natural look as well, Trevor. As you know, the first coat of any oil on "new wood" does tend to soak in quite quickly and not really give a true example of the final look. Once this dries completely you will have a better idea as to the necessity of adding another coat or not. She looks good on that stand too.
Thank you, Mark!
I'm reluctant to try a second oiling. I find that the first one tends to seal the pores in the wood, even if it is less than a thorough soaking. Then any extra oil sits on the surface. Not a problem if you can polish the piece but that wouldn't be an option with the interior of the pram.
As for the stand: I've never been good with spray cans. The white on the flat of the kit's baseboard went on too thick and now has picked up marks, while the primer still shows around the edges. Too late to separate it from the hardwood plinth, so I'll have to mask that and try again. I won't spray in the house and, even with spring coming on, it's hard to find an hour when the outside temperature is up and the humidity down!
Trevor
Steps 27 (Daggerboard), 28 (Rudder, round 1) and a beginning on Step 34 (Floorboards)
{The instructions skip from Step 28 to Step 31 with no #29, nor #30. To compensate, there are two Step 34s!}
The pram has a long, narrow daggerboard that would be a swine to sail with. I had a boat with a similar configuration once, though it was a metal plate rather than wooden board, on a boat that the previous owner had converted for sailing from a trap skiff. With a traditional rig that would not function as hard up on the wind as modern racing sails, there was often a temptation to luff up too close. Then the rig lost power, the boat lost speed, the daggerplate failed to generate enough side force, the boat made excessive leeway ... and the water flow over the high aspect-ratio plate stalled, just like the flow over a plane's wings when flying too slow at too high an angle of attack. Result was a complete failure of the dagger-late to provide any lift and the boat just went sideways! A low aspect-ratio centreboard would have been much better.
On the other hand, the narrow daggerboard does make construction of a watertight case relatively easy. And that case is needed so that the board can be withdrawn, simply by lifting it clear, when not needed or when approaching shore.
For the model, the kit provides the board in one, easy piece. However, it is laser-cut on the same sheet as the components of its case and thus is as thick as the case opening is narrow. To get it to slide through the case, the board has to be sanded thinner. The instructions say to go on sanding until the board is a loose fit, so allowing for a future coat of paint. As mine will be oiled, that was less of a concern.
Once down to size, the instructions call for the trailing edge (along as much of the length of the board as will protrude below the keel plank) to be tapered. There is no suggestion that the leading edge should be anything but blunt. That, however, would encourage stalling. Ideally, the daggerboard would have an aerofoil section but that's hardly practical in a pram (though fast catamarans and foil-borne boats do have that refinement). I compromised, rounded off the leading edge and extensively tapered the trailing one, while leaving most of the board flat.
With the board itself shaped, a cap has to be added at the top, to prevent the board simply dropping through its case, while forming a handle for lifting and a cover to stop water sloshing up through the case. I glued a piece of scrap onto each side, then whittled two other pieces to fit in the narrow gaps (forward and aft) between the side pieces. Another time, I would probably put on one side piece and add larger end pieces, then sand those flush with the board and add the second side piece. Whichever way it is done, the cap can be trimmed for length and width, sanded flush on top, the edges softened and bevels worked on the underside to give a finger grip when lifting the board.
Nothing very difficult in any of that.
The rudder is also provided as one piece. Step 28 only covers its initial shaping, probably because the instructions expect it to be painted before its metal fittings are added. But the shape is complex and should be much more developed than the ugly version presented in the instructions.
In profile, the leading edge of the rudder is straight from above the transom to the bottom tip of the skeg. It then angles back like a swept wing, before transforming into a curved trailing edge. That leads to another angle back up to the transom, then straight once more to the rudderhead. All that needed char removal, of course, but so did two tiny notches, one each side of the rudderhead, where the tiller will fit. I thought I was doing OK until the thinnest piece of wood snapped off. I will wait to see how the tiller goes before attempting a repair.
Aside from char removal, the instructions call for three areas to be shaped. They want the straight leading edge below the lower pintle to be sanded to a half-round section (which I did) and the curved trailing edge to be broadly tapered on both sides. The "swept wing" leading edge is to be left square, according to the book. However, I went much further, shaping the whole of the rudder that will be below keel-plank level, into something approaching an aerofoil section.
Finally, the instructions also call, very unclearly, for some shaping near where the pintles will fit. As I don't intend to paint, I have deferred that until I better understand the size and fit of the pintle straps.
The end result of those various tasks looks like:
Today's remaining effort went on the floorboards. There are 6 that span the supporting battens (previously placed on the bottom planks) abaft the daggerboard case, four more forward of that and two pairs of little ones on each side of the case. The laser-cut pieces are generously sized -- so long, indeed, that they sit on the garboards rather than the battens. I tried sanding them until they were just clear of the planking, while their outer ends formed a neat curve. I tried and tried but the more I tried the bigger mess I made. So I just set the draughting compass to the width across the battens where each board will go, added an arbitrary 5mm and cut the board square at that length. (The floorboards are so thin that they could be cut with a craft knife.)
The space available for these floorboards depends on just where the various frames ended up. The six from daggerboard case to sternsheets were too wide to fit my pram and so had to be narrowed a bit.
Those who paint their model prams are encouraged to leave the floorboards as bare wood, giving a pleasing contrast. To get something of the same with mine, I am finishing the floorboards with the clear satin acrylic provided with the kit. When I did that with the oars for my dory model, they came out very pale. I'm hoping that the effect with the pram will be something like scrubbed pine, whereas the oiled wood looks more like varnished pine. The acrylic is drying now, so I'm not certain how it will turn out. I'll rub down the raised grain tomorrow, put on a second coat, then glue them in place on their battens.
And that will bring the build up to completion of the instructions' Step 34 -- both of them. After that, the really tricky tasks will begin.
Trevor
Not much to report today and that not good. I did get the floorboards in, though the result is not pretty:
I should have been much more careful about matching the lengths of adjacent boards, cutting them diagonally of necessary, so that their corners aligned -- maybe something for those thinking of building this kit to consider. Also, there are supposed to be narrow gaps between the boards. There were, at least forward of the thwart, when I shaped them. Maybe the basswood expanded when painted with water-based acrylic. However it happened, I had to squeeze in th forward boards and sand the edges of the after ones before they would go in at all.
On the positive side, I got to try CA glue. I hate the hardware-store version and always get into trouble with it. But I figured that gluing painted wood to oiled wood probably needed something other than white glue. As it was out of sight, under the boards, I gave hobby-shop CA a try and it worked well. Gives me more confidence moving forward with some of the trickier challenges to come!
Trevor
To be honest, Trevor, those floor planks look quite good. They look natural in a haphazard, random kind of way. I guess the look you were going for was nice and neat with straight lines?
Nice and neat, as I would want it in a full-size boat. Ideally, I would have the edges of the boards follow the smooth curve defined by the intersection of horizontals drawn across the floorboard battens and the curved faces of the garboards. Next best would be a straight (but angled) cut across each board, approximating to that curve, followed by cuts at right angles to the length of each board but forming a regular series.
But at full-size, I could get into the boat with a tape measure, place each board, measure, cut, place again and repeat until satisfied -- then nail or glue the first board, double check the next one and so on. It's much more difficult with bits of 1:12 basswood flipping about inside a scale hull. I could (and should) have persevered anyway but I didn't.
Not worth ripping them out and starting over though. Just something for others to learn from my mistake.
Next will be the tiller and that will give me scope to draw eyes away from the floorboards!
I am sure it will be the finest tiller, sir :)
Thank you for the vote of confidence, Mark! Mine is likely to be the most unique tiller, to date, for any build of this pram kit. Whether it merits more than uniqueness, time will tell.
No progress on it today, however. (Not because of anything to do with models: I had to instal a new kitchen stove and advance work on a little table I have been building.) Still, that gives me a chance to explore some of the issues that have led others to grief over this step in the kit's construction.
The pram has a tiller/rudder arrangement that, in the full-size prototype, is really very clever. When all is in place, the rudderhead is firmly locked inside the end of the tiller. Yet at the extreme end there is a (probably bronze) bolt, hooked into a slot in the rudder. Raise the forward end of the tiller and the bolt can drop out of the slot, allowing the tiller to be unshipped in seconds, after which the rudder can be lifted inboard too -- a very useful feature when bringing the boat to shore.
Another, and very necessary, feature is a tiller extension, allowing the helmsman to steer while sitting on the windward side of the boat, where her (or his) weight will counterbalance the heeling effect of the wind in the sail. When a gust hits, the helmsman will need to throw his (or her) weight to windward, while putting the helm down, so that the boat can luff up towards the wind -- spilling some of it from the sail. Without either an extension or the arms of an orangutang, it's not possible to do both at the same time, so our intrepid sailor would likely to be in for a swim.
Unfortunately, re-creating all of that at 1:12 scale is challenging. According to the instructions, the completed tiller, with its extension, should look like:
That's the tiller itself made of three pieces, with the slot at the left to fit around the rudderhead, and the extension pivoting on a brass rivet. There's a cross-piece handle of brass at the end of the extension and a larger brass rivet to hook onto the rudder. The instructions say that all three pieces of brass should be cut from the 1/16-inch rod supplied with the kit. Previous build-logs seem agreed that only the one at the rudder end of  the tiller should be in 1/16, those at either end of the extension being in 1/32 (also supplied with the kit).
So that's what it is supposed to look like. But what it looks like is downright ugly. Maybe it's a practical object, though its ergonomics are poor, but it's just a steering stick, not worthy to be called a "helm". More on that theme in a moment.
Meanwhile, the parts the assembly is to be made from are tiny:
That shows the main tiller piece (released from a 3/32-inch sheet), the two side pieces (still in their 3/64 sheet) and the tiller extension (with a spare, as the first attempt is almost certain to go wrong!), laid out over a 1-inch grid. Three of the five holes needed for the brass bits are laser-cut. The other two have to be drilled -- one of them side-on through the 3/64-inch thickness of the extension. {Note that the instructions call for a 1/16 rod to be passed through a hole drilled in a 3/64 piece of (soft and friable) basswood. Since 1/16 is 4/64, that was never much of an option! Even passing 1/32 brass through 3/64 basswood can't be easy.}
The ends of the brass piece that hooks to the rudder, and also those of the pivot for the tiller extension, have to be tapped with a hammer until they mushroom into neat heads. That much is explained in Step 35 of the instructions, along with the rest of the tiller construction. OK, maybe. But many of us coming new to building wooden ship and boat models may have some experience of woodworking but often little of metalwork. I knew the word "anneal" and knew that it had something to do with metal, but I did not know what it meant, nor why it was needed. The kit instructions do explain annealing (though only briefly) but they do so under Step 38, which explains construction of the rudder gudgeons. When I first read through the booklet, I thought that annealing was something only applicable to the rudder hangings. From previous build-logs, I don't think that I'm the only one to make that mistake. It was only when I read of the frustrations of hammering hard brass rod, inserted in a miniature tiller, that the truth slowly dawned: The rudder's metalwork needs to be annealed too!
It's really no wonder that constructing the tiller has caused more angst than most other steps with this pram kit.
MSW comes to the rescue, however, and not only on the annealing issue:  Amidst the build-logs on this site, one part of the solution is offered: Don't make the tiller out of basswood but replicate the parts in something tougher! Obvious once it has been suggested.
Taking that route then opens other possibilities. For one, our little pram would readily be sailed single-handed, when the solo sailor would want to sit astride the midships thwart. (Sitting in the sternsheets would mean that his (or her) body weight would cause the stern to squat, ruining the balance of the boat.) To get the end of the tiller into a comfortable place for the helmsman to hold, while sat on the thwart, its main piece should reach about 3.5 inches forwards from the rudder, not the 2.5 of the kit-supplied piece. That's the ergonomic problem addressed.
As to aesthetics: I'm going to resist the temptation to get lyrical about the ethos of going to sea in small sailing boats. Suffice to say that on any sailing vessel the helm, be it tiller or wheel, is the point where a human hand connects with the boat (or ship) and guides her in the dance with wind and water. It is the point of command, not just of an officer commanding a helmsman, but of a human will commanding the vessel. Not for nothing are ship's wheels decorated with polished brass, while tillers are adorned with turks heads (which only pretend to be there as hand-grips!) or even carvings. In that vein, our little pram deserves better than the boring, straight stick provided in the kit. It deserves side pieces that merge into the central piece, not ones hacked off with simple bevels. It deserves a tiller that, although necessarily square in section at the rudderhead, transforms into a rounded section. It deserves at least a ball at the end, even if 1:12 turks heads would be a bit much. And maybe a splash of colour -- a contrasting wood, certainly, maybe the tiller's tip dipped in white paint or even gold.
So that's the plan: A longer, more elegant, more robust tiller and matching extension, constructed from a colourful hardwood, with freshly annealed brass. And I haven't entirely given up on the idea of a turks head grip too.
Trevor
Trevor, I am finding that replacing some of the kit provided material (in my case it is very unstable plywood) is saving me a lot of frustration. O look forward to seeing your rudder solution, sir and the wood you finally choose to make it from. The tiller on my build will be getting a make over too, obviously nothing as complex as your setup but it will enhance the final appearance in my opinion. What is a turk's head grip?
