A friend of mine purchased this kit several years ago, I think he cut the tape, looked in the box, closed the box, and put it on the top shelf in his closet, never to be seen again. So when he heard I had started the Latham, he asked if I wanted it. After a crisp $50 bill, it was headed for it's new home. While waiting for parts for my Benjamin Latham, I figured this might be a good build to switch to for now. I inspected the parts against the parts list, and it seems everything is there, and in good condition.
I also broke down and ordered a Dremel 4000 6/50, which will be here tomorrow.
Edited by Brian Parsons
Brian Parsons
Current Build: Rattlesnake
Side/Next Build: Benjamin Latham
Brian,
I have had the MS RATTLESNAKE kit for years, sitting patiently in the closet. I look forward to your build.
Chuck Seiler
San Diego Ship Modelers Guild
Current Build:: Colonial Schooner SULTANA (scratch from Model Expo Plans), Hanseatic Cog Wutender Hund, Pinas Cross Section
Completed:  Missouri Riverboat FAR WEST (1876) Scratch, 1776 Gunboat PHILADELPHIA (Scratch), John Smith Shallop
Brian,
Welcome aboard the Rattlesnake group.  You will find a large number of us are building this ship.  Some of us are very experienced and some of us are using this ship as our first build.  You will have a great number of logs to consult as you build and have questions.
Brain,  Always good to see more rattlesnake builds, as Scott said are numders are growing, the build logs offer  allot of good insight,  enjoy your build
Build log:  Rattlesnake by MOG
Current Build:   Not a ship
Completed Builds:   Mississippi River Boat OcCre 1:80
                                Bluenose, Model Shipways 1:48
                                Rattlesnake, Model Shipways 1:64
                                     Dumas # 1233  PT Boat,  Wood, 1:30
                                 1914-1918 US Army Mule drawn Ambulance 1:16
 I started my Rattlesnake build today. I figured I'd start with the longboat. I've seen a few posts about it not being the greatest, but to me it's good practice. I aligned the lifts per the instructions, which throws a few of the lines off. I think if I had to do it over, I would adjust the boats lines a bit.
Woohoo, a new toy!
Here are the 9 very thin pieces going together.
Bottom side.
Here is the rough shape after playing with a Dremel for the first time.
Inside view. If you notice towards the stern, I did burn through the hull a bit. I added some glue and sawdust, but I think I'm going to skim a coat of filler inside and out. Then I should be able to get rid of some tool marks and get a little better shape.
Brian Parsons
Brian
The shape looks good, If you want to practice , you might try planking the hull, I always  double hull , really gives a nice effect , and will cover any flaws on the sold hull  , have a look at my longboat in my log rattlesnake by mog, the longboat is a standout feature of the build,  take your time with it as  you want it to be special. Also you want it to keep to the overall style  you want to present for the whole ship.  The Dremel is good for rough shaping but the high speed can get away from you really fast, I use it Sparingly to get shapes started, then is allot of hand sanding , for me building is  a slow thing, never a race,
anyway  these are just my thoughts, as I've said many times on the site it's your build do it your way,  build to please the builder.
Mog,
Your longboat is fantastic. I might just try something like it on mine. I still need to use some filler it get the line better. While shaping the underside of the bow, i took a bit much off. Now it doesn't match the keel stem line.  :o
Brian Parsons
I skimmed the long boat with filler today. It has to setup for 24 hours before I can really sand it. So I started to work on the center keel. Who ever was running the laser must have had a few too many cocktails. It starts off pretty good at the stern but gets progressively worse towards the bow. I spent a lot of time making the bulkhead slots wide enough to fit the actual bulkhead. Some were close, others not so much. I also added a few shims in the middle of the center keel to push everything forward to match the plans better.
A bit of carving for the figurehead. I'm pretty happy with the end result.
I had to carve out the inside of the bow keel stem to get everything to line up. It wasn't perfect and left a small gap in the front. But a little filler and nobody will know the difference.  :P
Brian Parsons
Making good progress.  I noticed that you have an older version of the ship.  Can't speak to the accuracy of the laser cutting program.  I think any of us who have baught the kit can tell you that you will run into mutliple engineering issues.  I can only suggest that you review our logs to see what we came across so you have a heads up.  Again, since your kit is older I can't say you'll have the same issues us newer kit builders had.
Edited by scott larkins
So with several bulkheads not matching the plans, I decided to wing it. I centered all the bulkheads and matched the main deck line. I measured from there and marked the reference line. Every bulkhead slot had to be adjusted from one side or another, and the depth as well. Several hours later, they all went in and matched perfectly with the reference line, rabbet, and bearding line. Well, with the exception of 1... Bulkhead "I" went past the rabbet by about 1/4". I sanded it until it lined up with the rabbet. I will have to shape it to match the profile of the other bulkheads when fairing the frame, but I "think" it will be ok.
As you can see, I did not bevel any of the bulkheads. However, I did not glue bulkhead "A" or "M" yet. I have been wondering if those should be beveled or not, or do it all during fairing? Anyway here are a few shots of where I'm at.
Brian Parsons
Brian,
A word of warning for you here.  You might want to tape those pieces of wood back in the forecastle and poop deck bulkheads.  Lots of other Rattlesnake people have accidently snapped those frail second level cross-over pieces.  I kept mine in until I had to remove them.  And then I still ended up snapping one in the forecastle.  Twice.  Nothing is more frustrating then trying to be careful and suddently hearing that "SNAP".  Oh that words that have left all of our mouths.  Anyways, think about that.  Also, as I was given the advice, you may also want to glue some very thin wood under those cross-over pieces to help support them.  I used 1/32 thin bass wood sheeting I got at the hobby store.
It looks like it is coming along quite well with a lovely line.  I think when you fair the bulkheads all will be right with the world.
I suppose that I need to just "get over it" but I can't figure out why, if you go to the trouble to laser cut a piece, can't it be done to the right size and shape?  I guess it is a challenge to make it all work together when things aren't "quite right" but, to me its frustrating.
In any event, your frame and bulkheads look nice and I'm sure the lines of the ship will reflect your efforts.  I can't wait to see the next steps.
Scott, thanks for the tip. I was thinking about running some supports under the rails, but wasn't sure if they would get in the way of other things.
Popjack, I was wondering the same thing. There were several pieces that weren't even close to what the plans show. I suppose this might not be a big deal for those that have been doing this for awhile. But for a rookie like me, it is a bit to overcome.
I decided to reinforce the hull since the bulkheads are so flimsy. I just used a bit of 3/8 square stock I picked up.
Started fairing the frame. Got it pretty close, and then added shims on a few bulkhead sides, and a couple on the deck rails.
So for the stern filler block. The kit came with a piece of 1"x1"x6" block. The plans show 1 1/8"x 5/8"x 3". The math didn't add up, but I made an attempt at it. And I hated it. So I decided to make a new one. I combined a 1/4" and a 3/8" strip and made my own to match the plans. I left some meat on the sides so it can be shaped more after I get the lower ones made and installed.
I'll fair the frame some more tomorrow once the shims have dried over night. One side is a little better than the other right now, so I may need to add more shims to the other. Kind of a slow process, but I want it to be right before doing anything else.
Brian Parsons
Double and triple check that bulkhead fairing.  Make sure to run on of the actual plank pieces over several bulkheads at once making sure you get contact and bending where appropriate.  If not it will come back to haunt you.
I hated that transom block too but not as much as the blocks below it.  Carving those two pieces out of a solid block of wood should be cruel and unusal punishment regulatted by the Geneiva Convention.  LOL
I used the same blocks to support by bulkheads.  Really makes a difference.  Again, take your time with the bulkhead fairing.  The Rattlesnake is my rookie build too and I got a bunch of reminders to triple check that fairing.  Continue the good work.
Greetings again. So after a few days of shimming and sanding, I believe the fairing is complete. I moved on to making the filler blocks. The bow filler was pretty easy to make.I used the blocks that were provided with the kit. I measured the hull line and bearding line from the plans, then scribed the bulkhead line with the block against the keel and bulkhead A. A few minutes with the Dremel drum sander and the shape block was complete. I made the stern filler blocks from two pieces of 1/4" sheets to make up 1/2". This is probably not necessary, but I figured the less sanding here, the better.  Using the same method as the bow, I made the ones for the stern. With the roughed in shape I decided to go ahead and glue them in place.  After it dried for a day, I shaped them with some 100 grit paper. They look good to my untrained eye, but I'm not sure if they are correct. The bend of the planks are not a 90 degree angle, but it is a drastic bend. Any advise here would be greatly appreciated! I also added the transom framing and covered the mast slots. My next step is to install the waterways. Based off the plans, the stanchions appear to all be 1/6". In reality however, they are not. After adding 1/32" shims on several, and on one 1/16" they are much wider the they should be. So here is my question. Should I try to get the all down to 1/16" now, or move on to something else? They are very fragile, so I was thinking that it might be better to have the sides planked first?
Brian Parsons
All nice work.  From other posts I read while I was doing the stern blocks was mostly about those two lower blocks.  Make sure the angle is good for when you are bending the strakes the come into the beard line smoothly.
It's been awhile since my last update, but I haven't made a whole lot of progress lately. That being said, here is what I've done this week.
Sanded the stern filler blocks some more. I've tested with a plank at several points and I think it's about right now (crosses fingers)
Added the gun deck waterways. I fit and shaped the covering boards on the poop deck, but didn't glue them in since the transom wasn't installed yet.
Painted the figurehead with gold, then rubbed on some black to antique it a bit.
And here is what I've been spending too much time on. I cut off the top edge of the carving and shaped it some. The "Rattlesnake" lettering is done with dry transfer decals, each one cut and placed individually..... The lettering is kinda crooked, and it looks like the actual word is rattling...haha. If anyone noticed I'll tell them it was by design, but we all know better. :P
Brian Parsons
I haven't had a whole lot of time lately, but I'm slowing plugging away. My next step was to do the cannon and oar port framing. I decided to make one of the cannons and a small deck platform for reference. I still need to add a few more details to the cannon, but it works for now.
Here are several shots (probably too many) of the gunport/oar framing. I did make a "jig" for the gunport openings like previous folks here have. However, I found it was easier for me to install the bottom rail, then used the "jig" just to get the correct height. Then I used a divider to get my spacing off the plans.
Next step is to add the breast beams to the forecastle and quarter deck. And then it's planking time.... :o
Brian Parsons
So instead of starting planking, I decided to get sidetracked and build the cabin access doors. I used the 1" strip wood that came with the kit.
Lifted the pattern from the plans and cut them out.
I used a micro burr in the Dremel and got the shapes roughed in. The basswood is so soft that it furs up a lot. I rolled up some small strips of 220 sandpaper and got them a bit better.
Here they are primed. They still needed work, so spent a bit of time with some 600 grit paper.
Time for the windowpanes.
Cut some posts out of 1/16" square stock.
Basic layout here. I haven't decided exactly how I want them to sit. Laying flat on the table here, the posts protrude a bit. I could flip them over, and flush mount everything. I could also recess the posts. Or I could do a combination of flush mount the doors, then recess everything else? I guess I'll dink with it some more tomorrow. :P
Brian Parsons
I like that carving work.  I take it you are going to deck up to this bulkhead and not just past it and under it.  I, myslef, have not decided.  I'm wondering if I deck under the bulkhead if it wil mess up the lines.
I think I'm going to run the deck to the top of that bulkhead. It's hard to tell from the plans, but it appears that the deck runs under the doors. Since the doors and windows are going to be offset, I think it will look better.
Brian Parsons
Hi Brian -- That's a nice build you've got going there.  The care you've taken on fairing the bulkheads and shaping the filler blocks will pay off as your planking progresses enough for you to see the pretty lines.  I like the detail you're adding to the bulkhead doors, too.  Very nice.
In one of your photos, Ben Langkford's name was visible on the plans.  So even though your kit might be old, the plans are reliable and have enough detail that you can get lots from them.  I built the Mamoli kit, and ended up tossing about 3 of the bulkheads because they were so far off.
keep at it.
Martin
Current Build:  HMS FLY 1776
Previous Builds:  Rattlesnake 1781
                        Prince de Neufchatel
Thanks, they are still a bit rough looking at the moment. Once I added some color, I seen a few more flaws, more sanding to come...lol  I believe there were 3 bulkheads in this kit what were way off also. I should have thrown them out, but wasn't sure if I was up for making new ones. In hindsight, I don't think it would be too difficult to make a better set. Time to buy a scroll saw, the wife is going to love that idea! :P
Brian Parsons
