HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 66 donations so far out of 49,000 members - Can we at least get100? C'mon guys!) ×
Looking for opinions about Billing Boats kits?  I bought a Bluenose II kit for $50 online.  I was not happy to see so many plastic parts such as blocks and deadeyes.  But was pleased at seeing some really nice brass pieces.  The instructions are not too good.  But on their website there is some good additional info.  In the box there was a sheet of thin wood about 32" x 8".  No idea what it is for.
I bought another Bluenose II by Artesania Latina.  $30.  Has parts missing that 'should' be easy to fabricate.  Is AL a good brand?
Any comments greatly appreciated!
I just finished a AL Bluenose II.  The kit was great.  Only one pain.  It was short about 2 dozen deadeyes.  I was able to get these from my LHS, but any larger issues would probably be better off suited to the manufacturer
Carl
Completed builds: AL Bluenose II 1:75  Gallery
                              Amati Hannah SIB 1:300  Gallery
Current Build: Bluenose II - SIB - unknown scale
In my humble opinion, both of these companies are good;  however, if you want a model that represents the real McCoy, neither of them are suitable unless you spend alot of time scratchbuilding.  AL is full of exotic woods that will make a beautiful model, but not very accurate.  My (30-40 yr. old) Billings kit of the Cutty Sark came with a set of G. Campbells plans, and the keel and bulkheads were spot on.  The rest of the kit is not being used and I am scratching the whole ship off of the good frame and plans.  I always will recommend Model Shipways kits by Model Expo, but even these vary as well. The good thing is that they will replace any part free of charge, no questions asked.
AL and Billings are almost mirror images of each other. The failings of one is the strength of the other.
Accuracy: Billings are often more accurate, AL usually quite inaccurate. Also, many AL ships are vessels which never existed. They are products of the designer's imagination.
Quality of wood: AL supplies excellent wood, the wood in Billings is terrible. AL boats look good if left unpainted, whereas Billings definitely need paint or stain.
Fittings: AL fittings are cast metal which may be a little coarse, but looks nice. Good use of Photoetched parts. Billings fittings are plastic, they feel cheap, but looks OK when painted.
Instructions and plans: nearly indecipherable in AL, decipherable in Billings but too sketchy.
Regards, Keith
I bought an AL Bluenose that was listed as incomplete.  The keel and bulkheads gone.  But for $29, I got all the rest.  I was impressed with the quality of the small parts.  No plastic. All wood and brass.  The instructions are a delight compared to Billing and MS.  The scale is different from the Billing I am working on, but almost imperceptible to me.  1/64 compared to 1/75.  I may use AL parts on the Billing or maybe hope I can find another AL that is incomplete.  "All" I need are the bulkheads and keel!
Roger,
Do the plans show the keel and bulkheads at full scale?  If so, you can some plywood from a craft store and make new ones.
Has AL possibly changed their instructions over the years?  The kit I bought was made in 1985 and the instructions are clear and easy to understand.
I thought of making the keel and bulkheads, but in the plans I got, there are no scale drawings.
have built a few billings kits over the years and normally replace the plastic parts with scratchbuilt wooden fittings where applicable. In the case of the cutty sark i replaced the billings dolly winches and ships wheel with sergal fittings.
Keith
