Something that I have done is to use a satin varnish first, it brings out the colour of the wood more, it can then be lightly sanded and layers of matt applied.  Using only the matt didn't really enhance the wood at all.  Of course its all personal preference.
Cheers,
Jason
In the shipyard:
Thank you Jason, for the moment I've applied a kind of lightly walnut coloured varnish, and I'll see the day after the results..
What proportion of each free end of the yard do you sand down to obtain the required tappering?
The instruction comment for the last 1/3 of each half of the yard but I dont't feel to be in the safe side, that way....
I'm thinking to start sanding from the mark point (that is 40 mm away from the free edge of each 80 mm white 6mm dowel)...
Thank you all.
Cheers
Stergios
Edited by Stergios
I think I've found the answer.
I have to sand the dowel of the yard starting from the octagonal border of its centre (approx. 6mm) and going & tappering gradualy towards both free edges to reach a final diameter of 2,5 mm
In case I'm wrong, please send me your notification....
Stergios - you are correct.  Think I posted a bit about this in my log, you may want to check the size of the PE "end caps" before determining the diameter at the end of the yard.  I'm not sure they are really necessary though.  Sorry, can't really provide much more info, you seem to be on the right track.
Cheers,
Jason
In the shipyard:
Hi Jason and thank you.
I'm trying to read and follow your posts (as Jim's too) in advance.
All I wanted was to make clear the starting point for the tappering.
Thanks.
This is how it is supposed to be using walnut unpainted (but varnished) dowels.
I've a tendency to follow this road...
Edited by Stergios
I used the day before a lightly walnut-coloured varnish and today I've applied a layer of matt varnish without any sanding between the two steps.
I dont like at all some spots of roughness. I sanded the dowel using paper No 400 before the initial varnish.
Edited by Stergios
I've sanded down for a second time those undesirable look-like mast-sections trying to restore a unique and smooth circumference in order to accept again a thin layer of water diluted walnut matt varnish.
Cheers Jason, may I ask you, those structures in the middle of the yard, are custom/hand made by you (using 1x1 mm spare wood)?
I cant' see what Jim has done for the same point....
...end for the rest of the yards material (rings, etc) didi you buy again extra aftermarket fittings?
Thank you for your time to provide support on every issue, again...
The metal parts were all from the kit - I did use some styrene strips to replace the white metal ring around the yard as it seemed a little overscale to me.  (All the rings are to some degree, but I was satisfied using the parts I did)
Cheers,
Jason
In the shipyard:
I have completed the shapping of all the yards of the model.
Now I'm trying to understand the right way to fit and fix the yard's metals and accesories in place. The kit instructions provide little help for this..
My main plan is to accomplish the fitting of all the wooden parts (masts, yards, etc) and then procced to the final fixing of the masts, starting with the gluing of the lower 1/3's (lowermasts) on the deck.
Thanks
Hi guys
how I've told you I'm two steps before the final placement of the lowermasts in the deck.
At this stage I'd like to ask you: did you open in advance 1mm holes to connect (by pinning) the back side of the yards on the masts? If so, did you do it for the topmast and topgallant-mast yards too, in advance?
Is it advisable to create those holes now or (because the respective rigging heights and distances on the masts differ sometimes) at a later (more mature) stage?
Thank you all.
Stergios
Hi
I did pins for all the yards on all of the masts. i suspect it would be easiest to do the pins now before you attach the masts in place but you'll need to be careful with alignment.
Thank you Jim.
Have you used the 1mm brass wire or usual planking nails (without head) for the pinning?
Cheers.
Edited by Stergios
This is a good question for now:
what are you doing to protect your model from the dust, especially after you have glued the masts in the deck?  :(
I have a very high tech solution, I taped two large newspaper sheets together and then draped over the top of the masts like a tent. The air dusters work great as well as Jim points out.
Cheers,
Jason
In the shipyard:
Great looking build Stergios! Can't wait to see it finished.
John   B)
Current Build: MSW 18 Century Longboat 1:48
Next Build:    MSW Bluenose 1:64
Hi everybody, as a question, in brief..: that K (5mm double block): it is a single one in the middle of the last crosstree of the mizen-lowermast or it is a pair of blocks arising from each tressletree?
I was looking all the evening your posts and pics with no clear result.
Thanks for sharing.
Stergios
Edited by Stergios
I used a double block.
Mort
Current Build - Caldercraft Diana
Completed - Artesiana Latina Swift, Harvey, MGS Prince de Neufchatel, Imai USS Susquehanna, Mamoli Constitution, Rattlesnake per Hunt Practium, Caldercraft Snake, Diana, Caldercraft Victory, Kammerlander Duke William
Waiting to be Launched -  Bluejacket Constitution
Proud member of The New Jersey Ship Model Society, Model Shipwrights of Niagara, Model Shipwrights of Western New York and Offshore member of the Society of Model Shipwrights
I think that the best option is to form this kind of loop for the double 55mm block.
It seems more historically accurate, I don't know whether exist any comment for this...
Thanks
Edited by Stergios
