Rick -
Others can provide better examples of tools for carving the rabbet - I used a small v-blade that worked adequately, though not ideal.  You definitely would be better off on this build by carving the rabbet prior to installing frames - the rabbet is pretty much aligned with the base of the frames, and for some sections will be very difficult to carve with the frame in place.  Carefully measuring (and double checking) the edges before beginning carving will also aid in aligning frames when you install them.
Edited by trippwj
Link to comment
Share on other sites
Rick -
Wayne
Thank you for your input.
Link to comment
My sketch shows that the angle of the rabbet changes as Maurys mentioned ( I also noticed rabbet cut information on drawings) . As this is the case , since the frames are not in place, do I need to make paper templates  of frames to  rest along keel to help verify angle of rabbet cut that will receive plank?
Thank you all for your input.
Rick
Link to comment
Having just finished cleaning up and organizing frames I'm currently working on cutting rabbet .
As part of this work I have glued two frames and dry fit them in place . The are helping me visualize how the rabbet needs to be cut.
Interesting how fragile these frames seem as they now stand but the laying on of timber such as beams and planking will make for a sturdy craft.
Regards
Rick
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
