Garwood-
Congratulations on reaching 1,000 posts.  The first regular member to achieve that milestone and our first Captain.
WELL DONE!
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Garwood-
WELL DONE!
Hi, Augie, many thanks for a congratulation! First Captain obliges, I will try to correspond to it  :) .
Best regards,
Garward
Is under construction Montanes
Ready models Golden Star Corsair San Francisco II
Bronze 24-pdr canone Le Fleuron
Bronze 24-pdr canone Le Fleuron (second version)
Congrats Garward on being the first member to make Capt. A rank well deserved. Your work is outstanding !!
Frank
completed build: Delta River Co. Riverboat     HMAT SUPPLY
                         USRC "ALERT"
in progress: Red Dragon  (Chinese junk)
Look at all those stripes, Congrats on making Captain, well deserved. Your advise is always welcomed here.
I also agree that actually making your own tools is very satisfying and can be a big part of this hobby.
Hello (Pryvit) Garward,
Congratulations on reaching a 1000 posts and a salute on your promotion to Captain.
Take care,
Anja
Those we loved but lost are no longer where they were, but are always where we are.
In the gallery: Albatros 1840 - Constructo
Dear colleagues, many thanks for congratulations, I am sincerely touched by your attention !
Best regards,
Garward
15.2  The drum-type grinding machin
To creation of this rig I was jogged by requirement for manufacturing (gauging) of laths and plate plainly-parallel sides for various details with accuracy of 0,05-0,1 mm on a thickness. The range of thickness of laths and preparations, and also ready flat details makes from 0,5 to 25-30 mm. I have applied for the first time the given machine tool to polishing of preparations of details of fodder gallery Montanes.
In the beginning there was an idea to use for these purposes the scribing block, for example DH 40 PROXXON, but after the detailed analysis of possibilities and results of application of various scribing blocks I preferred other production engineering. Plancks or preparations are cut on jig save with the free tolerance (0,5-1 mm) that it is easy to make practically on any applied modeller jig save, and then calibrated on the grinding machine with necessary accuracy. This production engineering provides the big accuracy, than machining of laths on the scribing block, especially for thickness of 1-3 mm.
At designing of the grinding machine I used the materials published on various sites, and also experience of the Polish colleagues on manufacturing and application of similar grinding machines:
The general circuit design of a grinding part of the rig simple enough (see also the reference) and does not demand additional explanatories.
Edited by Garward
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Machine description
Grinding knot (all details are made of a steel):
- Drum: length of a working part of 100 mm, diameter of 49 mm, a groove 3,0х7,0 mm for fastening of the emery paper by a wedging method; diameter of the shaft of the drive of 12 mm;
- Work table: 100х350х10 mm, a working surface it is ground, the back part is fixed in racks on axes in diameter of 6 mm;
- The basis 150х375х10 mm;
- Side posts of the shaft in the thickness of 12 mm, bearings of the drive of the shaft in diameter of 12 mm;
- Cover of side posts in the thickness of 5 mm with an aperture under the vacuum sweeper;
- adjusting screws M 10х1 (one turn – work table moving on 1 mm on length of the screw);
- The positive allowance between a drum and a work table (work piece altitude) is controlled from 0 to 35 mm.
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
The drive
The direct drive through two half-couplings (landing apertures in diameter of 12 and 19 mm) with a silicone crosswise lining (on the basis of successful experience of application of the analogous drive in the circular saw)  is used.
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
The electromotor
Asynchronous three-phase general purpose of type the AИР power of 0,55 KW on 915 turns in a minute. It is connected to a network 220 in by means of working and starting capacitors and the magnetic starter, provides thus shaft power about 350 W. The given electromotor is chosen first of all because of a corrected speed and desire to use the direct drive. The Polish colleagues on the basis of long application of similar grinding machines experimentally installed that speed of twirl of a drum of 900 rpm in diameter about 50 mm is optimum wood for polishing (in particular, pears).
Best regards,
Garward
Continuation
Best regards,
Garward
Abrasive
Mainly on a fabric basis, the grain size can be any
Also it is defined proceeding from polishing problems.
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
The way of fastening of a skin on a drum also is widely used long ago by jamming by a level in many designs, a difference only in the one who than gets jammed: wooden, plastic or metal level or rubber laying etc. Here to couple of examples of other drums. on which the skin is jammed and keeps very much even decently.
Best regards,
Garward
Continuation
Best regards,
Garward
