Always a pleasure to follow your build log, Garward.
I wonder if I would ever be able to work with metal, especially with such tiny pieces.
Thank you - spasiba
Thanks for a response! It isn't so difficult to do small metal (and not only) details if there is a desire it to do, at you everything will turn out.
Best regards,
Garward
Is under construction Montanes
Ready models Golden Star Corsair San Francisco II
Bronze 24-pdr canone Le Fleuron
Bronze 24-pdr canone Le Fleuron (second version)
2 . Deck details
Details are made of a pear (except a cloth of lattices).
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
2.1 . Belltower
Best regards,
Garward
2.2 . Kabestan
It is made by means of a milling cutter of MF 70 and a delitelny head of Proxxon.
Best regards,
Garward
Continuation
Best regards,
Garward
2.3 . Superstructures aft
Cabins for navigators and boxes for storage of flags, fouls and a compass.
Best regards,
Garward
Best regards,
Garward
Continuation
Best regards,
Garward
Garward,
It's great to see all these details back again. Some of them I could hardley remember.
Carl
Garward,
Thanks for the comment!
Best regards,
Garward
Hi Garward,
I'm pleased to see your Montanes log up and running again, excellent modifications there, she looks remarkable :)
Thank you very much, Aldo!
Best regards,
Garward
Continuation
Cabins for officials
On drawings and drawings from a set (see a photo) and on a site http://www.todoababor.es/vida_barcos/nav_74can.html
aft Montanes is shown a certain construction under the name "Camarotes de oficiales" that is translated as "cabins for officials". This construction on the deck of the 74th gun ship a little foreign matter that pushed me to the next searches – and that this such actually especially as on the vast majority of other models of battle ships and frigates of that period it is absent (except as on Superb). By means of modellers with Marine et Modelisme d’Arsenal and MSW it was succeeded to find out that this shoddy easily removable construction which was sometimes erected in a peace time for creation of additional conveniences to officials (to officers, officials) and to certain "worthy" passengers (a certain similarity of private life and fresh air far from close and musty lower decks). This room had the sizes from 4 foots 8 to 10 inches in height and contained four, six or eight bedrooms: two for guests or officials, and others for officers also it was equipped two-story two foots to 30 inches with beds, desks and cases. Before operations this construction was cleaned from the deck to exempt a place from unnecessary hindrances. As Gerard Delacroix kindly reported, in France this construction was called "transportation", he gave the reference to a photo of this construction (see below) on one of old French models.
Thus, on the basis of received information it is a construction it would be possible and not to build, but remembering that Montanes as a part of the Spanish squadron within 8 years served on Philippines (Manila, Kavita) where such construction is very pertinent, I decided it to construct, but made also removable - is established on 4 probes on corners in openings in the deck.
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
Best regards,
Garward
Continuation
As soon as saw and I got IMG_3556_1 of a rack shown on a photo (diameter of openings of 1 mm) - didn't keep and right there I changed a protection on "transportation".
Best regards,
Garward
2.4. Transom
Pink and yellow pear, interline interval ebony fine line, linseed oil; molding from a zinc alloy is covered with enamel paint for the Revell No. 94 models (gilding imitation).
Best regards,
Garward
3 . GUNS
Guns of the first and the second (except for 8 guns) batteries are imitated by semi-trunks. The trunks of 12-pound tools of a main deck enclosed in a whale I designated scandalous hack-work of OcCre (a photo 1228): guns of galleons of the 16th eyelid are offered to be established by the linear ship of construction of 1794. Naturally, these trunks were replaced. Also cast gun carriages are replaced.
Best regards,
Garward
3.1 . Cheeks of gun carriages
Pear, overall dimensions of 18х8 mm, linseed oil and bituminous varnish.
Best regards,
Garward
Continuation
Best regards,
Garward
3.2 . Axes
Axes from a pear, cylindrical parts are made by means of a self-made mill.
Best regards,
Garward
Continuation
Best regards,
Garward
3.3 . Other wooden details
Best regards,
Garward
3.4 . Metal details
Loops of pins are made of a brass foil 0,3 mm thick by means of two drills:  the drill diameter equal to diameter of a pin (1,5 mm) serves as a punch, and a drill diameter equal to diameter of a pin + of 2 thickness of a foil (2,1 mm), clamped in a vice, forms a matrix.
All brass details are blackened in 20% solution of selenious acid.
Best regards,
Garward
3.5,  Assembly
Assembly was carried out by means of the simple adaptation, glue - ZP-30 cyanogen.
Best regards,
Garward
Continuation
Best regards,
Garward
3.6 . Ready guns
Each gun consists of 35 details: 11 wooden and 24 metal
Best regards,
Garward
