Morning All,
An update will come later on today. I have tomorrow off from work (best thing about working 9 day fortnights) so I will be up early to get as much done as possible before having to tidy up the flat for our friends who are staying on Saturday night. The progress this weekend will slow as I'm in London on Saturday during the day, and I'll more than likely be sleeping off a hang over on Sunday. Made some progress last night, but I'm not entirely happy with my efforts with the decking, so I'm not sure what to do?!
BigCreekDad,
I funnily enough had a very similar experience with the Admiral when we moved in together.
I wrapped up my record player (combi turntable and speakers, nothing flash) in about an inch thick of bubblewrap all the around it before the move in to the new flat, and as the box was light weight and one of those things we could chuck in a cupboard until we needed it, I gave it to Lucy to carry from the van to the house. But a few weeks later I tried to turn it on (had been to a garage sale and bought a mint condition copy of Rumours by Fleetwood Mac for 50 pence - normally it goes for £25.00+) and found the box was dented and she later confessed to dropping it on to the lounge floor and shoving it away in to the cupboard before I would notice! Oh well!!
Cheers,
Jonny
Caldercraft HM Cutter Sherbourne Kit Bash - Scale 1:64 - http://modelshipworld.com/index.php/topic/10547-hm-cutter-sherbourne-by-jonnyamy-caldercraft-kit-bash-scale-164/#entry317289
!!!ON HOLD!!! Mantura/Sergal HMS President - Scale 1:60 - http://modelshipworld.com/index.php/topic/5589-hms-president-by-jonnyamy-circa-1760-sergal-160/
In the Pipeline:
18th Century Longboat - Scale 1;48 - - http://modelshipworld.com/index.php/topic/11273-18th-century-longboat-model-shipways-by-jonnyamy/
Completed Builds:
40 Foot Gaff Cutter - Solid Hull Concept Model
Caldercrafter HM Mortar Vessel Convulsion - Scale 1:64 - http://modelshipworld.com/index.php/topic/8593-hm-mortor-vessel-convulsion-by-jonnyamy/
SCRATCH BUILD - Vagabond 19 foot Sloop - Scale 1:20 - http://modelshipworld.com/index.php/topic/10172-vagabond-19-6-keel-sloop-pob-scale-120-by-jonnyamy-small/#entry302726
Morning All,
Update on convulsion for the previous 5 or 6 days...
So, when a few things have progressed on the convulsion build in the last few days. As I explained previously, I had Friday off from work, and I thought I would spend most of my day working on Convulsion, but I ended up Christmas Shopping and tidying up the flat for our guests to stay over on Saturday night (which they didn't :o  - very annoying). So progress was slow on Friday, but I did manage to paint and fit the Spirketting Boards along the inside of the Bulwalks. This spurred me on to try dry fitting the Carronades amd Mortar, but I was surprised with how soft the White Metal castings were, and how easily they bent (and bent back in to position). I'm glad I dry fitted the guns, as I found that the carridges required some modifications to the pre-drilled holes. Using a Pin Vice and a 1.5mm DIA drill bit, I made the holes fo the supporting post and the elevating screw larger, allowing for tight but accurate fit.
I practiced the art of compromise successfully once the Admiral came home from work on Friday night, as she wanted to go out and get Cocktails at a very pricey hotel bar near by, and of course I couldn't say no when I was told we were going! I'll admit to being under the thumb with her, its much easier to just say "yes Dear"!!! So all progress on Convulsion had to stop for the day.
Saturday, a glorious day, was spent in London along the South Bank, in Covent Garden, and Liester Square, the Admiral and some friends. I had the privilage of seeing the replica of the Golden Hinde captained by Sir Francis Drake in 1577 - 1580, which has circumnavigated the globe on several occasions. I could not believe how small it was, even at 102ft in length, she still looked very cramped and looked like she would be a handful to sail even in shelter waters. After the Golden Hinde, we ensued trying the local beers at several pubs along the South Bank. Needless to say, Sunday was forecast as write-off.
So once I was feeling better on Sunday afternoon, I decided to cut the topsides to the correct profile, and cut the walnut planks to stern profile. I also dry fitted the Transom, and planked and painted it to match the spirketing at deck level.
Then I decided to fit the Main Wales, and the Gunwales, but I found the plans called for two set of Gunwales above the Main Wale, but I found that Caldercraft had only supoplied 3 No. of the 1.5mm Square Walnut Strips for the Gunwales, so I had to compromise, and fit only the Gunwales along the top of the Bulwalks. Crisis averted, I decided now spray paint the model (minor F*** up happened here with the masking).
The Minor F*** up:
So after I sprayed the whole model black as a base colour, I flipped the model over to check my masking had not let any paint seep through.... And it did, the rudder post hole let a direct spray of black paint bounce around inside the masking and stain the planking round the stern and some staining around the mortar bed.... A lot of swearing proceeded and I gave up for the night! Apart from sanding out the stain is there any way I can get these out? I'm rather kicking myself I didn't mask this area a lot better, but I thought I had done a decent enough job on masking. I need some advice from my fellow modellers?!
Lastly, I woke this morning around 5 am and decided I would test the Yellow paint I bought on friday, and apart from being quite thin, I'm fairly happy with the colour. What do you guys think?
Cheers,
Jonny
In the Pipeline:
Completed Builds:
Jonny,
Yellow is a bit translucent, so an undercoat of white or pale gray would be in order. If you're doing much more yellow on the boat, carefully mask it.  And paint the edges of the tape with the base color to keep the paint from bleeding under it.
Ken
Started: MS Bounty Longboat,
Ken,
Thanks for the tip, I'll do that tonight once I get home from work. The yellow is only going to be on the bacnd between the gunwale and mainwale, but I have some white left over from President, so I'll paint the band white tonight. I was thinking about taking the yellow down to the waterline, but I am not sure. Here is a picture of HMS Pickle (chosen because of the similarity of size of the ships), and the yellow occre has been taken down to the waterline, but I'm not sure about that on Convulsion.
My reckoning is that a ship of this size would have minimal (if any) decoration, so I think a Yellow Occre band between the wales and black down to the waterline probably would give an accurate representation of a ship of this size?!
Cheers,
Jonny
In the Pipeline:
Completed Builds:
Ken,
Just a quick update on the paint scheme....
The white coat on topsides worked really well, thanks for that tip, it was really helpful and one that I had completely overlooked on Sunday.
The paint is still a bit thin, so I might have to switch it up for some of the paint I used on President, but I wasn't too keen on the colours provided with the kit, so I might mess around tonight with colours. Next step will be marking the water line, sanding the hull down for additional grip for the paint, and masking that out for spraying maybe tonight or tomorrow morning.
Also I fitted the Port side bulwalk last night, so I will start building up the bulwalks shortly, and then it is time for deck fittings.
I will hopefully provide some photos tomorrow, or thursday with the finished paint scheme?
Cheers,
Jonny
In the Pipeline:
Completed Builds:
Also, I may start taking the photos on my digital camera rather than my iPhone, as I think I'll be able to get clearer photos of my progress. But I need to make sure I can get my PC at work to read my digital camera, as my laptop at home is pre-historic and takes an age to start up let alone do anything.
Cheers,
Jonny
In the Pipeline:
Completed Builds:
Quick update on progress,
I tried sanding out the black stains from the spray painting fiasco, and I found that it is going to be harder then I expected. Unfortunately I had to give up early last night as I'm on antibiotics for a problem with my back, and over the last 3 days have started to give me severe stomach cramps, so I hit the hay fairly early last night as lying down was the only relief to the pain.
So hopefully tonight I will be fighting fit, and I will be able to sand the stains out, and finish off the deck planking. I also spray painted the Caprails last night, so tonight I may spray the rest of the assmeblies to go in between the Gunwale and Caprail.
Cheers,
Jonny
In the Pipeline:
Completed Builds:
Morning Chaps,
Just a quick update to say not much has happened this week due to various reasons (mostly the Admiral's doing), but I will make sure I get the deck planking finished tonight, and start building up the deck fittings. The first activity after completing the deck planking, will be adding the cap rails, then spray painting the waterline / under water profile, then it will be adding the rudder and tiller, then build up the Elm Tree Pumps, Grating / Hatches, and the Companion Ways.
So come Monday/Tuesday, I should have a decent update for you all! Sorry about the slow progress recently.
Cheers
Jonny
In the Pipeline:
Completed Builds:
Hello everyone,
Just a quick update today, as I'll be uploading a load of photos tomorrow. But I got the caprails and stanchions in place, painted the waterline/under water profile, and that just needs a quick tidy up. So good progress was made this weekend, but not as much progress was made as I wanted. Tonight I will finish off the deck planking (I've been putting it off for a few days now), and I will be hopefully be able to start putting the Compainionways and Grating together.
Cheers
Jonny
In the Pipeline:
Completed Builds:
Good morning All,
Well todays picture day, and I can confirm I have plenty of photos for you!
So progress on Convulsion has been varied over the last week or so, as I've had periods where I have made little or no progress, and then there have been periods where I have blasted through the construction. So first of all, I'd like to say thanks to everyone who has given me great advice with colour schemes and painting. But the first observation I must make is that spray paint out of the "rattly" can is just too unreliable, and the paint is far too thin for a decent coverage of paint. So next pay day, I will buy myself an early Christmas present, and buy a starter airbrush kit. I might even bug the "Admiral" enough that she will buy it for me?!
So this is what I have worked on over the last week or so...
First I sanded down the black undercoat on the underside of the hull and marked the waterline 6mm under the wales as described in the instruction manual. Masked out the whole vessel and sprayed the under water profile white, handy that I had brought some 6mm wide Tamiya masking tape from my local hobby shop! But... like the black spray paint, I found it was very watery, and it gave a very uneven coating of white. So had to leave it to dry and touch up the lighter areas with the spare white paint I had from President. Overall the finish is much better now, but with the Tamiya paints I am using, I find they are very watery, so some touching up on the waterline is required where the white has run over the line, and the counter painting of black has run in to the white (none of the local model shops around sell or can supply Admiralty paints, so the Tamiya paints will have to do)! Very annoying!
Does anyone have an idea of how I can thicken these paints up? I thought about maybe adding a bit of PVA glue to them, but I'm concerned that might take an age for the paint to dry?!
So my next venture was cutting out and cleaning the Capping Rails - easy enough. They were then spray painted black with 2 coats of Matt Black. Again easy enough... but then came cutting and painting the uprights and bollards. I built a cutting jig to the uprights, cut them to 10mm in length, and put them aside. I decided to cut 24 instead of the required 22, just in case there was a problem with any of them, which proved to be a bloody good idea!! Cutting out and cleaning up the bollards was easy enough, and once I had checked and double checked all the numbers and locations of them all, I decided to paint them.
Plan A - Spray painting them outside the front door in the dwindelling light was a very bad idea, as each tiny piece was blown from one end of the box lid I use for painting to the other.
Plan B - Spray painting the pieces pinned down to the cardboard box lid... to avoid damage to the members, I pinned them down with 2 alternating pins set apart diagonally from each other pushed in to the cardboard, not the thin pieces of wood. This method resulted in a messier version of Plan A.
Plan C (after a lot of thought and a suggestion from the Admiral) - pouring paint in to plastic shot glasses from our house warming party a few months back! Eureka! This worked all the pieces were evenly coated and all the excess paint was recycled and poured back in to the paint pot!
The next challenge was fitting the caprails, uprights, and bollards to the hull! Damn this was easier said than done!! After a lot of swearing, a mini tantrum, and cigarette and a beer to calm my nerves, I finally got both sides on. I groaned at the fact that I had completely forgotten to install the bollards (used to tie the vessel to the dock when not at anchor, along with many other uses), but this was quite possibly the easiest part of the build, as I chamfered the bottom face of each bollard to fit in the holes prior to installation! With a pair of fine nose tweasers and superglue all the bollards were in place with no stress at all!!
As you can see from the photos, I still have not finished decking the bow, but I honestly lost the will to live after installing the caprails and uprights, so it's still on the to-do list!
So last night I started on Deck fittings, building up the Mortar, the Elm Tree Pumps, and one of the 4 Carronades. Everything has been dry fitted at this moment in time as I still have to finish of the decking and I still need to build all the grating, hatches, companionways and fit all the brass eyelets on to the deck.
The Elm Tree Pumps:
The Mortar & Mortar Bed:
Carronade No. 1 (name pending):
As I am finishing work early tonight for a consultation with a doctor & surgeon about a problem with my back, so I will hopefully beable to get a lot done tonight after the Doctor tells the Admiral to take me to the glue factory!
Cheers
Jonny
In the Pipeline:
Completed Builds:
Can anyone see the photo's?
I'm not sure if they've been uploaded or not....
In the Pipeline:
Completed Builds:
Discreet lack of the old photos there Jonny  :D  and you had gotten me all excited to be looking at them too  :P
Eamonn
Happened me a few weeks ago too (I had just forgotten to post them up, only remembered 20 mins later)
E
Current Build   :  HM Schooner Ballahoo
In the Pipeline :  HM Cutter Sherbourne, HM Mortar Convulsion, Emma C Berry & C18th English Longboat.. Eventually That Is..🙄
********** See Post above ***********
Waterline:
Caprails:
Elm Tree Pumps:
Carronade No. 1:
Sorry about this guys!
Cheers
Jonny
In the Pipeline:
Completed Builds:
Eamonn,
I know where I went wrong with the last post....
As I had a large number of photos to add to the post, I went through inputting them in to the text, but as I was doing so I deleted the photo from the attachments folder below (as a self checking exercise), so the pathway to the photographs was lost.... All in all, a silly mistake!!
Cheers
In the Pipeline:
Completed Builds:
Jonny,
Looks good to me. White is always a tough color to get good coverage. And in acrylics, even tougher. Maybe you should tell folks you're going for a "weathered" look. :rolleyes: I'd like to do a bomb vessel at some point, so your log is much appreciated. Thanks for sharing. :dancetl6:
Ken
Ken,
You're right, I am going for a "weathered" look ;)
Thanks for the kind words. I chose Convulsion over Granado purely over size, but I'd love to build another Bomb Vessel myself, and I'm currently weighing up whether to get Granado or HMS Snake next! I just have to persuade the Admiral that we need to expand the "fleet". I think we would need a bigger house though! In all honesty, I'd love it if she took up the hobby as well, but I know she likes doing her own thing!
I'd also love to build a scratch model in the Admiralty Styling, and Royal Shipyard of Plymouth (a US company) make some fantastic looking kits of Rattlesnake, Fubbs, Halifax, and Kingfisher, but their kits are so extensive and detailed, I think it's just a dream I have to build myself up to!
http://www.royalshipyard.com/Home.aspx
Cheers
Jonny
In the Pipeline:
Completed Builds:
Morning all,
Just a quick update for today - Not a lot was done last night, but I got a few little bits done. For example, I managed to fit all the brass eyelets to the Mortar Bed covers, and I painted the largest Mortar covers red as well. I also managed to build and fit one of the grated areas (on the quarter deck -  not that Convulsion has one). Tonight should see further priogress with the decking (still on my to-do list) and building of more hatches and the companion-ways (fingers crossed)!!
Also, had a Surgical Consult yesterday about an issue with my back, and I require an operation on lower back that's scheduled in for early in the New Year, so come January I'll have a cheeky 2 or 3 weeks off from work! Can't wait!
Cheers,
Jonny
In the Pipeline:
Completed Builds:
Keep on truckin' with the bomb vessel.
And good luck with the back issue. I fully comprehend your problem. My years in Phantoms have given me similar problems of a non surgical repair nature.
Ken
Cheers Ken, I will do!
Yes I have a surgery date and it's been approved by the Surgeon, and my work have given me the go-ahead, so finally I'll be sorted!
I've had a number of back issues in the past - I used to yacht race on a semi professional level, and I had to give it up for a few years because I managed to slip a disc, lifting an outboard motor out of my own boat, so I'm very pleased to get surgical assistance with this issue!
In the Pipeline:
Completed Builds:
We had similar issues and causes Jonny.. I too sailed professionally and had to pack it all in for the same reason, but mine was untreatable (at least at the time) I was 21 and retired  :P  :P
Eamonn
Unfortunately, I gave up the Semi-Pro to Pro level sailing when I turned 17 (by that time I'd been on the yacht racing scene for 6 years - started off with my father on a friends yacht and that's where I found my true passion) when I was offered an apprenticeship in Petrochemical Engineering (to which I then specialised in Civil & Structural Engineering).
After that I have raced at a club level on various boats, X332's, Swan 36's, Swan 38's, 1 Tonners, 1/4 Tonners, 3/4 Tonners, J/109, J/105, Dufour 34's, Farr 40's, and many more.
When I turned 18, I went in to a joint venture with my grandparents, and bought a Hunter Sonata for £4000, kept it on the Hamble for a season, configured it for single handed sailing, and with a decent breeze, she was a stiff little boat that was a quick as sh** off a shovel! But after the first season of sailing her every weekend, I winter-ized the boat, and popped a disk lifting the outboard out the engine well in the cockpit. Which meant the boat was sold (not my decision), and that's when the problems arose!
In the Pipeline:
Completed Builds:
Just a heads up Gents,
I should be able to give you a solid update on progress tomorrow night! I have a day off tomorrow, so I can get some serious work done on Convulsion!
Cheers
Jonny
In the Pipeline:
Completed Builds:
Hi everyone, sorry for the very late reply. I've been away with work and on holiday over the last 10 days or so, so unfortunately the build log and Convulsion have fallen by the wayside! But things are getting back to normal now at work and at home, so I'll hopefully get an opportunity to carry on with Convulsion tonight or tomorrow night.
I have started knocking the lower main mast and I've started to tie the ratlines to shrouds on my Loom-a-Line, and I am so impressed with how quickly they can tied on the loom-a-line. But the main balls up on this, is that I cut the shrouds to the length required, but forgot to tie the loop at the end of the shroud (to slip over the mast) and subsequently they are slightly too short. So Idea No 1, is to cut fabricate the Mizzen mast tonight, and clip off one of the shrouds and use it for the mizzen. Idea No 2, is to not use the loom-a-line at all and do it the "traditional" way, but risk the rate lines being rubbish?!
BigCreekDad - that's a beautiful example of Convulsion! Absolutely beautiful!! I hope I can do my kit the same justice you have given yours!
Cheers,
Jonny
In the Pipeline:
Completed Builds:
Hi Jonny
I am very impressed with your Convulsion build to date. Well done. I am champing at the bit so to speak to get started again on my own Convulsion but
It seems that life has other ideas at the moment. I have experienced some health problems of late and what with one thing or another I have been prevented
from getting back to it. But better days ahead.
Keep up the good work, it's a great looking kit and I look forward to seeing your finished model.
regards
Paul
Hi Guys,
Sorry it's a rather late reply, it's been chaos at work recently due to the Christmas Shut Down, conferences, and close out of outstanding work. I also had a lovely relaxing weekend away arranged by the Admiral, which was well needed!
Now - down to brass tax, what we're all here for.... an update on Convulsion.
Like I said, the last few weeks have been manic - I've been left, right and center trying to get everything done in time before Christmas, so Convulsion has fallen by the way side a bit. So this is a brief update to show the progress (if you can call it that) in the last 2 or 3 weeks.
So what's been done on Convulsion, I hear you ask.....
Well I've finished off the deck planking like I said I would since about November time.... It's my least favourite part of the build I must admit. And I've got a lot of the deck fittings glued in place. I am in the process at the moment of clipping down all of the eye bolts to half their original length, and gluing them in place.
Hopefully, by this evening, I will be in a position where I can say I'm done with the eyebolts. I've just got to add them around the base of each mast and in to the bulwalk for the carronade positions.
I've also built up the lower main mast, and started tying ratlines to the shrouds on my Loom-a-Line, but as explained in a previous post, I balls'ed this up by sutting the shrouds too short. so I have remeasured and cut the main shrouds, and they've been left to the side until I have the chain plates and channels glued in place.
So I've decided I will recycle this shroud and use it on the lower mizzen mast as it should fit quite nicely.
To get a feeling of what Convulsion would look like with her spars in place, I took this photo of the uncut lengths of dowel in place. I have subsequently cut the lower mast mast and upper main mast parts to shape and added their fixings.
Lastly, for this post anyway, I decided I would work on something different, and something that would be a little refreshing, so I worked on the Anchors. I found the Anchor Stocks were symmetrical, and that they fitted together very well, but....... the holes cut for the anchors were too big, so I had to pack the holes with 0.5mm THK walnut strips and sand them down slightly to get a tight fit for the anchor.
After that, I had a look online to see how the Anchors were attached to the anchor cable, and I found that a split ring arrangement was used to attach the anchor to the cable. But.... each Iron split ring is bound in rope (either to make it easier to handle, or to stop corrosion happening so quickly), so to replicate this, I bound each ring (made using 1mm brass wire wrapped around the handle of a craft knife) in black thread. This problem with this was that I required about 2.5 meters of thread for each ring and I had to pass the thread through the ring every time, pull it through, check the lay of the thread, and then repeat. Because I have chunky fingers, I found this very difficult, so Lucy suggested I tie a length of wire or wood to the end of the thread for me to get a better grip on! Damn that girl is smart!! All in all, it was very tedious work, but I'm happy with the result!
To finish off the Anchors, I tied on the anchor cable, and used the remaining length of cable to make up strops to hold the anchors on to the bollards, as can be seen in the photos.
So, that's it for now. I'll give another update by the end of the week. I'm home alone tonight so I should make some decent progress!
Cheers,
Jonny
In the Pipeline:
Completed Builds:
Paul,
I'm sorry to hear that you're being held back from Convulsion due to health problems. I've got a few issues myself that I'm having sorted out next year... I'll be out of work for 2 weeks at the end of Jan. for a minor back operation. According to the doctor I'll be on my front or side for the 2 weeks, so I'll be held back on Convulsion then. Keep your chin up, and hope you're not out of it for too long!
John,
I've had plenty of screw ups along the way so far, but I'm working my way through them nicely. I've learnt a lot from this build so far, and I'm very pleased with the outcome at this moment in time. But as I said to the Admiral last night, I'm not even 1/3rd of the way through yet!!! :o
Cheers
Jonny
In the Pipeline:
Completed Builds:
