Hi members,
I have a question regarding this particular cyllindrical black structure with, what appears to be a couple of reinforcing metal rings, indicated by a red arrow, on the attached illustration.
This is a painting od the HMS Royal Katherine of 1664 by an unknown (to me) artist.
I have never seen anything like this before.
Does anyone have a clue?
Regards,
Thomas
Hi Dziadeczek- Szacun ziomalu :)
It looks like a barrel and could serve as seat of easy and other purposes.
Fot. 1,2 Carrck
Drwg. Peter von Danzig plans ( sailor throws the lead )
Fot. My model of Peter von Danzig
Tadeusz
Pozdrowienia z Gdańska Panie Tomku
I think Tadeusz may have your answer.  A various times they also hung barrels off the chainplates to soak the salted meat to get the salt or soaking peas and/or beans out before cooking.  I've also seen accounts where a barrel was set up by a scupper to catch rainwater, but that doesn't appear to be the case here since it's sunny.
  • 5 weeks later...
It is most possible that it is a toilet.  At this period the roundhouses for petty officers,  as later fitted to the beakhead bulkhead,  were not yet built;  and I have read of similar things being fitted to the sides of ships,  accessible from the gun-deck,  for the use of the middle ranking members of the crew.
Mark P
Edited by Mark P
Previously built models (long ago, aged 18-25ish) POB construction. 32 gun frigate, scratch-built sailing model, Underhill plans.
2 masted topsail schooner, Underhill plans.
Started at around that time, but unfinished: 74 gun ship 'Bellona' NMM plans. POB
On the drawing board: POF model of Royal Caroline 1749, part-planked with interior details. My own plans, based on Admiralty draughts and archival research.
Always on the go: Research into Royal Navy sailing warship design, construction and use, from Tudor times to 1790.
Member of NRG, SNR, NRS, SMS
In the original post, the 'roundhouse' is unlikely to be a toilet as it is positioned immediately above a gun port!
I've read elsewhere that this could possibly be a steeping tub: where salt pork or beef was desalinated (to a degree!) by immersion in fresh water.
