I am about to work on the mast and sails and the kit instructions call for brushing diluted wood sealer over the sailcloth. I did not purchase the Midwest paint kit and could not find water based sanding sealer at my LHS. Can anyone give me a substitute product or guide me through creating the sails for this kit?
Pete
Pete,
Try a mix of water and white glue at 50-50.  Test it.  You might have to go down on the glue.  If use this, form the sail and then let the cloth dry.  It can add a nice billow. :)
I've also seen hairspray, starch, and matte finish (diluted) polyeurtothane varnish used.
Oh... and did I mention test... test.. test before putting anything on the sail? :)
It actually will do both.
I'm toying with the idea of displaying the daysailer with the sails down as opposed to removed. Like when you would be docked at a marina for a beer. Is there a term for this? Where does the jib get stored?
Pete
The term is furled -- it's a good way to display sails.  If the boat's owner is only temporarily tied up, the jib might just be lowered to the deck.  If you go for furled sails, you'll only need sails about 2/3 or so of the full size; full-sized sails on models don't roll up as compactly as the real thing.
Pete,
Mark is giving good advice Pete. I scratch built a crabbing skiff and used water/white glue mix. it worked well. to also stop the fraying you can use two way tape along the perimeter which works well. heres a picture of my KRUSTY CRABB
Thank You all...
Mario
:piratetongueor4:  :piratetongueor4:
"Each of us is a mixture of some good and some not so good qualities. In considering one's fellow man it's important to remember the good things ... We should refrain from making judgments just because a fella happens to be a dirty, rotten SOB(biscuit) ;) "
My Builds....
BETTEAU WAR OF 1812     BOUNTY LAUNCH(bashed)    CHESAPEAKE BAY FLATTIE
THE SEA of GALILEE BOAT   VICTORIAN STEAM LAUNCH(bashed)    HOWARD CHAPELLE's CRABBING SKIFF
LADY KATHRINE 1812 SCHOONER
I decided to give the sails a try. Got a little heavy handed penciling in the seams and had to wash them back a bit. What is two-way tape? Do you mean Double sided?
