FrankWouts
Everything posted by FrankWouts
  1. And finally the deck planking has finished this weekend. Now first some heavier and lighter sanding and some WOP on the deck… And then up to chapter 5!!! Frank.
  2. Hi Fred, Any updates on rigging your Winnie? I wonder (haven't read back for a while, sorry), which rope and blocks, brands, sizes) you use for rigging your lovely cannons? Thanks, Frank,
  3. And replanked and first light sanding again… Let’s see if I can finish this before this Sunday evening, or else end of next week! Frank.
  4. Little setback, two planks weren’t satisfactory and had to be removed and replaced…. Almost made it planking the deck this holidays… Frank.
  5. Looking awesome and great progress! Do you really work with only one hand? Even more respect for your progress and beautiful build! Frank.
  6. Hi all, Planking on, only twelve rows deck planking to go…still 5 days holiday left, so little more than two rows a day would finish the deck these holidays. I see now my little plank with bricks, the stove platform has curled a little, probably due to the moist black paint I put on. I have to see if my stove will be straight up later on…Otherwise I’ll replace it with fun to make dark redbrown clay bricks and a new black frame. Frank.
  7. Looking good and very good progress Steve, harsh and long work sanding inboard…but very important for later to get it right like you did. Very well done! Frank.
  8. Welcome to the group Allen, I'll be following your build. Have fun and lots of succes on your first scratch build of HMS Winchelsea! Frank.
  9. I'm afraid I did indeed bend it Chuck, ooops...it would be a lot easier to have used the sheet and cutting it, that's right! Cost me a lot of sweat above the traveling iron and multiple watersoaked planks thrown in the dustbin. Frank.
  10. The sassafras you used for the stem looks awesome to my eye. Have you tried milling some planks of it? How do they bend, cut and sand? If that's all okay I would go for the fine grained sassafras, not the more heavily grained and dark walnut ! It would combine beautiful and fine with the boxwood parts from Chuck and the ornaments for sure! Frank.
  11. Can’t help you with the different woods you mention, but for the looks, my taste would dictate me to use the same wood as the one you made the keel and bow wood of. For the gaps you describe along the curve of the rabbit at the bow, I would just fill them with some extra strip of the same with and sand/check/sand/check, etcetera…until it fits in the curve of the already constructed bow wood. The rabbit may not be of a constant width at the bow, but when you’ll be finally planking the hull, when you leave a very, very light tension on the planks so that they push very light against the curve of your already constructed bow wood, my guess is that you will be allright. Frank.
  12. After the jigsaw first comes the pencil drawing. Cost me a whole Saturday afternoon and Sunday morning to get it right. But ready to start planking the last four belts of the deck now. Frank.
  13. Hi Steve, there should be several 3/16" lasercut fairing caps in the package you received from Chuck! If not send him a message. Look at Chuck's build on page 7, post #207, it's described there were to place the 3/16"wide fairing caps to help with the inboard fairing. Frank.
  14. Yes, I think your build will be like that, for sure with such a clean lasercut you won't have to adjust and clean up so much. That laser and its settings seem to cut at an exact 90 degrees angle judging from your photographs. Or did you have to correct some joins that weren't exactly in a straight 90 degree angle? Cannot wait to see more of it! Frank.
  15. Wow! That's looking suberb with superclean cust and crisp fitting! Keep going, I'm curious how your build will progress if this is already so beautiful and clean! And very good pictures by the way! Frank.
  16. Checking the flow of the bow of the middle section of the jigsaw part of the deck planking. Just gave it a little fine sanding thusfar. Next step is to measure the equal distances with the template at each section line and lining off with the rest of the planking at both sides with narrow tape. Frank.
  17. Looking good Steve, well done! Maybe only thing is to replace the two lower planks at each side that should touch the edges of the counter planks seamlesly. Piece of cake to replace them I think. Bevel the end of the planks to match the angle of the sides of the counter planks. These tiny gaps you still have there might be visible underneath the nice print and fancy plank that covers the edge, my guess the tiny gap might still be visible. Frank.
  18. Thanks you all, For all your tips and comments and the likes. Well, I'll first try to use some WOP and see how it looks, the overwhelming majority thinks I shouldn't paint the pear, which would be ashame I think too. @Ronald: I've not yet test fitted the whole stand, I'm still fine-tuning the two conformal placeholders with the hull... Once it all fits smoothly, I'll try the WOP and see how it combines. Thanks, Frank.
  19. This is how I would continue with your counter / bottom planking and second lower wale plank: paint the edge black and glue and clamp it on. Only sand the aft edge of the lower wale plank flush with the counter planks. Maybe first sand the two lower planks that already touch the counter planks a little flatter in a parallel line with the hollow bended edge of the lower counter plank. The side of the lower longitudal plank that touches the lower wale plank could have been beveled more and more in a bigger angle when moving aft, so that the edge between these two planks would heve become sharper moving backwards to the counter.... But just glueing the second lower wale plank on top will be fine I think after just a little sanding the planks to simulate this 'sharper edge when moving more and more aft '... I hope I'm not writing jibberish to you here... Ofcourse there's a little twist in the lower wale plank you have to bring in with a drop of water and your little travel iron. Frank.
  20. Hi Steve, Yes, that's what I did, and paint the sides black like the rest of the sides of the wale planks. What's the alternative? Sand it flush along the green line you've drawn? I think that would look awful sideways, there would be a step / bend in the bottom wale planking line! I guess that's not what they used to do in reality at the ship wharf in good old Engeland too. Everyone seems to have the tendancy to sand everything flush, but please suppress that tendancy here. Just make all planking edges of the counter, wales and bottom planking come together at that one edged point where the step / bend is in your green line: don't sand this point round or flush! That's exactly the reason everyone shouldn't sand that pointy edge at the first counter planking flush or rounded, but leave it 'pointy'! It looks in the photo as if the lowest counter plank's edge has been sanded straight, but it was in fact sanded round together with the other counter planks at the sides until the 'pointy' edge at the bend in your green line. But when gluing and clamping the wale planks like you see happening at the left side on the picture, it made it flat again. Just let all edge planks of counter, wale and bottom plannking come together in that one edge point, with the angles as on the drawings and the counter picture everyone uses to make it fit more or less nicely... The highest bottom plank and the lowest wale plank are tightly against each other from bow to stern / counter, but have an ever increasing angle with each other towards the counter/stern. Hope this helps!? Frank.
