Everything posted by FrankWouts
Wonderful and amazing beautiful work Glenn! No flaws visible to my eye! Frank.
- 840 replies
- winchelsea
- Syren Ship Model Company
It’s the same with me Jim, the turtle feeling… Check my startdate…I spent over a full week practicing scraping the different fancy molding strips and making the profile on redundant old hobby knives with the 0.15mm thick diamond cutter disks. But it’s like you say, quality over speed. And now I’ve got the hang of things I learned here like sideways bending, scraping, I can put them to work in future builds, hopefully with a little more speed…but with the same quality…at least… Nice progress on your build, you’re going slow but steady, and that’s a good thing! It will be longer in your living room and beyond perhaps in your family than the time you build it, so slow and steady isn’t a problem when contemplating like that. Frank.
You're welcome anytime Jim! Thanks, though I'm relatively new to building wooden ships, but trying to learn and adapt fast as the firebrigade...unfortunately that slows me down compared to more experienced builders...a lot...I have the same fears like you, sanding off too much or making unrecoverable errors... I started a wooden ship 30 years ago, kept it all that time and wanted to finish it recently, Corel's Victory, but noticed I was too far off on various points, so maybe sometime I'll start another someday, maybe Amati's coming new one in 1:64 scale...if it ever comes into production.. Frank.
Good morning, A small update on my quarter galleries. I build the roof and made some of the fancy moldings. Scraping the boxwood strips into fancy moldings has now improved enough to be acceptable in my opinion, after hours of practicing on small scrap redundant strips of yellow cedar this weekend. Making the scraping tool was done with a 0.15mm diamond motor tool cutting/grinding disc. Scraping the boxwood strips appeared to much easier, more straight and precise however! Boxwood was chosen for a reason to make the fancy moldings I assume…(!) I changed the cerulean blue on vertical pilars adding more white and a tiny drop of yellow to match the printed artwork better. Here and there an tiny drop of glue still has to be removed, tiny strip of artwork cut away on edges and some careful fine sanding where the fancy moldings meet at the corners I see on my pictures now. Pictures are very unforgiving and a good help being critical on one’s own work. The roof and windows are not yet glued on, as per instructions. Frank.
Very nice progress Archie! Did you taper the upper and front stem parts gradually from front to end? It's not easy to see on your pictures for me, but it looks a bit as a rounded taper to my eye, specially on the third and last picture where they're glued on, tapered and in whipe-on-poly WOP. I think it should be taperd just a little more and in a straight line from front to back. I love your working space: very light and with fresh air! Much better than my dusty attic! Frank.
*************** Chapter 3 *************** Hi all, just a small update of my start of chapter three. Please ring the alarm if you see any anomalies that should be corrected. My planking ends rather high at the top of the transom, compared to e.g. Rustyj’s. Even little higher than Chuck’s. I hope this will not become a problem… Frank.
Very consistent progress and beautiful work Gary! Success with your move: keep calm and model on! Frank.
- 389 replies
- winchelsea
