steamschooner
1 Follower
About steamschooner
  • Birthday 10/14/1952
  • Gender
  • Location
    Western Washington
  • Interests
    West coast steamschooners, Tugs, local craft, turn of century vessels
4,654 profile views
  1. Paul, Was the grey ropes from Ropes of scale a special order? As I do not see it listed on their website. Steve
  2. Paul, Wapama is looking really good. I have a question about the color of the cabins and upper hull. It might be my monitor or my old eyes but it looks like the cabins are painted the lt gray hull color. I know white will reflect surrounding colors. So are the cabins and upper hull painted white and I am just seeing the lt gray being picked up by the white surfaces. Steve
  3. I have a book called, "Pacific Schooner Wawona" by Harriet Tracy DeLong. Published by Documentary Book Publishers Corporation Bellevue Washington 1985.
    It has a good many photos of the Wawona that might be helpful in building this vessel.
  4. Paul, I have been following along with your build and you are doing a super great job. Not knowing the level of detail you plan I am reluctant to point out a detail as I don't want to sound like I am critizing your build. The bitts that you show in this lastest post had hardwood corners rabbited in. In some cases were capped as well. The post with all the Wapama photos shows the corners having hardwood inserts. Also looks like metal corners were added to protect bitts from chain damage. Here is a shot of what I did on the Willapa. Keep the great work coming. Steve
  5. Paul, As my user name states I have a great interest in west coast steam schooners. Had a two part article in the NRG , fall of 04 and spring of 05 I believe. It is on my build of the steam schooner Willapa built in Raymond Washington in 1908. She was close to the same size as the Wapama. I have collected many photos and drawings pertaining to west coast schooners. If I can be of help let me know. I will certainly be following your build loc. Steve
  6. Eric, Good progress on your project. Looking at the first photo I see two built in roller chocks. One on each side of the stem. There is a gap in the cap rail? for a line to drop though and two rollers per chock. Looks like they are still there in the later photo. You may have already noted them so I hope I am not repeating known details. Steve
  7. Wheelhouse looks great I really like the color of the wood. Did you have to use your big match for decking strips? Looking great Valeriy
  8. I thought I would show my method of making some handwheels for my project. I start by making some rings of 28 ga brass wire. OD of ring is the size needed for the handwheel I need. I had some P.E. handwheels from a watertight door set. I than drill a center hole for the wheel shaft. The rings and P.E. hw were tinned on one side. I used a jig to center both parts tinned sides facing each other. They were than soldered together in the jig. Once removed from jig they were trimmed up and cleaned up.Only needed a few of difference sizes. Ah the joys of sratchbuilding Steve
  9. More outstanding metal work to inspire the rest of us. Great job Valeriy! Steve
  10. Eric, West Coast steamschooners used painted canvas as a deck covering. Many ships did I believe. Tar paper covered decks I would think would be a mess on hot days as the tar melts and is tracked all over the place. Course it may have been a different type of tar paper than we use today. Just my 2 cents worth. Steve
