SawdustDave
Everything posted by SawdustDave
  1. Nice job on the ball racks Jon. Are you going to add wire frame around the balls?
  2. Thanks for your comments Pat. I did use your approach when doing the starboard side.... every Tenth ratline .... the ones that extend out to the one shroud secured by block and tackle rigging. And yes, it did work quite well. Dave
  3. Absolutely right about that Tom. Been fighting this annoying issue for over ten years. Such a simple solution, huh? Dave
  4. TECHNIQUE TIP..... Once in a blue moon, looking for a better solution to an issue, I might come across some little technique worth passing along to my modeling friends. This particular one has to do with keeping the shrouds in true alignment as I work my way up with tying in the ratlines. Don't know about everyone else, but I don't always manage to maintain perfect spacing between the shrouds around mid-way. We've all seen it.... the tendency to allow those outside shrouds to CREEP INWARD. Took a couple of shots to show my very simple and effective solution..... Note the slit in my pattern paper about every third or fourth course of ratlines. I simply pull the end of the line into the slits and touch it with a small dab of CA, thus locking the outside shroud in place so I don't have to be concerned with "Inward Creeping" as I work my way up. Note, I have used tick marks on the pattern paper to indicate the spacing of all the middle shrouds. Back to a few hundred more clove hitches.......
  5. You are welcome to come visit us in NC..... got plenty to do.... clove hitch, clove hitch, etc. etc.
  6. PROGRESS..... Sometimes one step aft, two steps fore! Happy to be back to where I was when my "fore progress" was interrupted. Too many improvements to be of interest, so we will just move on from here. Note, the production of rings and hearts to be used in the rigging of the Fore and Mizzen masts. Also note that the addition of the starboard side futtock shrouds and ratlines. Now ready to rotate the model and resume the exciting process of tying the port side clove hitches, etc. etc.....
  7. From one having taken several road trips with model ships, I know the relief of a safe arrival very well Ken. Congratulations. Your son will enjoy your legacy long after you are gone. Dave
  8. Re-do’s not all bad. Per usual, ripping out and doing again generally results in considerable improvements. Pretty sure it will be true in this particular case.
  9. ALWAYS SURE my friend..... sometimes just WRONG. (and must pay the price)
  10. A little setback.... typical of me. Had shrouds rigged to both sides of the Main mast.... rigged ratlines to the starboard side. Then decided the upper deadeyes were too low..... ALL 18 OF THEM! Yes I did completely remove everything. Back to shroud #1.
  11. Glad you pointed that out Ken. Sure would love to sit down with you for some serious “brain pickin” at this point. Thanks a bunch. Dave
  12. Just finished rigging the shrouds and deadeyes for the Main Mast, and trying to decide whether to move on to the next mast or..... RATLINES!!! I really do dread the looming prospects of endless clove hitch tying (don't we all).... so, at this point, my inclination is to work on the ratlines for each set of shrouds as I go, thus breaking up the formidable task into smaller exercises. Of course, this would include rigging the Futtock shrouds and Staves etc. Also beginning to look at the rigging of the Bowsprit.
  13. MAIN MAST ALIGNMENT..... This photo was taken to visually check the vertical alignment of the Main Mast after rigging the first two shrouds. Seen here, I used a plank laying across the lower rails with a framing square to check for perfect alignment. I also used a plank laying across the fighting top to physically measure the distance of each side down to the channels. Note....I will also be using a temporary stay line tied off to the bowsprit to physically hold the rake at 3.5 degrees as I proceed with rigging the remaining shrouds. It's nice to see this phase finally begin, but I'm not real excited about it being one step closer to tying all those rat lines ..... (clove hitch, clove hitch, clove hitch, etc, etc...)
  14. BELAYING PINS.... Before setting the three mast assemblies, I spent the last two days spinning tooth picks into belaying pins surrounding the fife rails. Needed about 80 of these little guys.... only ten to go and I should be done with all belaying pins.
  15. I do appreciate the offer of assistance when needed. Good to know you’ve got my six. creating collars this morning and returning to numerous fixture details omitted in the course of building the spar deck.... like the cannon ball racks on some of the companionway coamings. Still much to do before I actually place the masts and begin adding string. Cheers
  16. Hi Tom: I have finally reached a point in my build where I need to spend more time researching and studying your work for personal guidance. The mast assemblies are finally done and I am getting ready to begin adding strings. At this point, my feeble efforts to make sense of the horrible Instruction Manual from Model Shipways is actually embarrassing for me. I honestly don't know what I would do without the amazing logs provided by you and Ken. I catch myself looking at your logs as if I have never built a model ship before. I think I was completely spoiled by the instruction script of Chuck as I scratch built three of his models. So, I just wanted to say "hi" and a sincere "thanks". I really look forward to the many hours I will be spending on your log in the weeks and months to come. Dave
  17. TURNING TOPGALLANT MASTS.... With the outstanding build logs from a number of MSW fellow builders, I haven't found many things to share lately. Most everything I've done lately has been my feeble attempt to emulate details found in their log postings. I did, however, while turning the very delicate Topgallant Masts, wonder if my technique might be of interest to others faced with the challenge of getting very thin tapering at the end of a dowel. Here goes.... The hardwood block of wood seen here has a small hole drilled through at the exact height of the center of my lathe chuck. This allows me to move the block back and forth on the lathe bed while applying pressure with course sanding paper and files. Pretty simple and very effective technique.
  18. RETIREMENT!? I do wish you the best in that my friend. It is a big adjustment in your live. I retired three times before I got it right, What is your next model?
  19. Thanks guys. The photo with the hugely oversized flag was taken using a flag which is now mounted over my wife’s brother’s grave stone. Today is a very special day of memory and paying respect to our fallen warriors. Cheers
  20. Very outstanding job Vic. Absolutely beautiful work. Be proud of her. She’s still my all time favorite model. Dave
  21. Hammock crane netting completed.... Masts are now ready for paint.... Now working on the fighting tops. Needless to say I am pretty excited about finally getting to this point in progress.
  22. MEMORIAL DAY.... Being a veteran, I decided this would be my special Memorial Day statement.
  23. Thanks Tom. I agree....Well worth the effort. Jesse - I know exactly what you're going through. I really struggled with the soldering technique as well. Gave up on using the electric iron and went to using open flame from the little BERNZOMATIC butane system. Creating a jig to hold the parts together was easy. Sanding the surface of each part and getting the area covered with the right amount of flux is the secret. Also.... applying the flame AWAY from the joint, allowing the wire to heat up and suck the solder into the joint is key. You'll be amazed at how quickly you will pick up the technique with a little patience and practice. BTW.... Club meeting in Fayetteville tonight. Hope you can make it.
  24. Back to work.... Fifty of these two piece hammock crane stanchions were formed from steel wire. Each being silver soldered at the joint, and snipped to size. The post was filed to a point, and each stanchion tip was flattened and notched for the rope to be attached, as seen in the second shot. Upper and lower ropes attached nice and tight....and, finally, the slow process of tacking the netting to the ropes.
