yancovitch
Everything posted by yancovitch
  1. will an acrylic primer work...or should it be oil based?....thanks....
  2. hmmmmmm....i find that acrylic paint doesn't stick to the lead sculptures....will oil base work...?...if so....which can i use.....?.....
  3. haha....i was thinking the same thing just yesterday.....also would the passage ways need to be hatched over.....and wondered how long the armsor levers were, or whatever they were called...
  4. looks fine....thanks for reminding me about the treenails ......oh.....i wish i had temporarily reinforced the tops of the stern framing...even wrapping some masking tape around them....they're easy to damage and as i'm not as neat a worker, the tops on mine are somewhat rounded and will have to be built up when the time comes....
  5. wow....thanks for that!.........saved me from having to take out the apples, oranges and bananas.......the level of my math ...looks like i was right.... they should be larger.....now to figure out how to do it without wrecking the cannon.....guess i'll hold the cannon in a rubber vise, and drill, increasing the size in small increments....should be safe enough, and remain relatively centered.........
  6. hmmmm....i picked up a few cannons from the syrene ship model co....and the nozzle hole is about 1mm in dia......is that about right, or should it be enlarged?.............
  7. omg....haha, i guess it was worth posting my fumblings here after all, if it even helped one person....oh, i think you could just use a piece of the nylon tubing that comes with the ca, or purchase it separately.....as long as it has a tiny opening......my wife just happens to work in a dental office..............just used vallejo model color yellow ochre, covered with a light coat of minwax ipswich pine stain......still have some finishing work to do on them, like opening some blocked holes.....i may loose a bit of detail, but not much.... how about another flub....first effort on tiled floor.....made them horizontal instead of 45 degrees......second effort....didn't notice that the bass strips i used, were a bit too fat...i scrapped that................... so i cut off the triangular ends of the first effort and used them to build up the main section in the right locations....somehow it worked ok, but if you look in a certain light, you'll see that the four corners reflect differently........but of course only i will know that
  8. ok we'll see if this works....applies gap ca via a dental etch syringe to give more depth.....will shrink, and will give another coat, mainly on the larger areas......maybe it will flake off ....we shall see......
  9. well i figure i'll just end up painting it traditional....otherwise it just wouldn't look like the confed.....still waiting for some swiss pear from the lumberyard for the stem and rudder etc......they said it was too cold to go out to the shed to cut the logs.........amazing....way up here in burns lake bc, it's only hovering around 0,,,,,,hope i wasn't too dynamic with the red......and i hope the slightly raised stern isn't too offensive to chuck, and those highly qualified here, and hope it won't void the warranty......i hadn't planned to do it
  10. ok......still deciding whether or not to keep it natural, aside from the stern galleries........... lucked out on the inner bulwarks....everything fit reasonably well, aside from the fact i had to raise the quarter deck clamp near the stern too accommodate the slightly higher galleries used four pieces of thin laminated pearwood to make the cove oh....i made a scraper for the double cove out of a xacto blade...for the 1/16th square strips....but....on the roof of the quarter galleries, i think i will sand them down and re-scrape the shape......cause i think they're too deep in contrast with the etched brass.... i may try to apply some ca with a pin or whatever to the small flat ornaments and try to give them some dimension, or find some other way.......will see what happens.....cheers...
  11. i agree with augie......i ended up placing the sills on the stern, in not quite the right place.......good show......
  12. looked up the byrnes table saw, and it looks fantastic....never heard of it......good for you!...
  13. thanks trussben......it's starting to take shape in spite of my flubs ...feeling much more positive now......
  14. ha!...another boo boo.....realized i used 1/16 instead of 1/32 plank for the black strake, so i made a little tool to sand it down to 1/32.......had to cut the sanding sheet on the tool, a little narrower than the plank i was sanding, so i wouldn't sand into the wales............ by the way, mabe 20 or more years ago i purchased 1/2 doz. metal carbide sanding sheets from sandvik, which were unbelievable helpful....haven't seen them since, and i'm still using them.....didn't sell enough i guess............ hmmm....am amazed how well chuck designed the pieces for the stern galleries....considering the multitude of angles and shapes........somehow, i ended up building them a little higher than on the plans, another fubb.....guess i didn't get the sills in just the right place..an error yes, but in a way, it feels better visually......forgive me chuck:) really enjoying this kit fumbles or not........
  15. oh, i just thought i'd add that what i wanted to do and didn't, is to epoxy or whatever the inside of the hull before sanding the planking, to avoid sanding too much where the ribs are, which in this case might not have been as important, since the ribs were quite close together. but if i had used the basswood, it might have been more effective.....is why i waited for installing the deck till after the planking............. also, i just had an idea after the fact..........before starting, since i noticed the pearwood had some variation in color and grain....i think now that it would have been a good idea to lay out all the planking, and applied a thin coat of rub on polyurethane, which would have shown all the variation in color etc, and made it easy to choose which planks to use where..........after planking, being so thin, it would be easily sanded off...and this is mainly for hardwood planking..i don't know how absorbent basswood would be.......................anyways....food for though for the next modeler who starts this project.......then again, maybe everyone does this
  16. oh augie..me thinks i'll be sticking with the urethane satin, so i can't stain now, unless it's a stained urethane....i didn't oil because it would have come out too dark and all the grain would have been more exaggerated, which i was trying to avoid...on the wales etc i was thinking of a darker stained urethane instead of black but i don't know yet.....
  17. yea rusty, but after maybe 20 models built......you think i might have learned something??? :D ......maybe now you see my problem :) .............but really, there's no problem anymore....now that i've accepted and embraced my limitations, i can just sit back and enjoy the build,.............................vic
  18. thanks for the heads up.......hmmmm....if i don't beat myself ....nothin happens....nothin ..........inertia is my bigest hurdle........another hmmmmm.....no color wales etc......hmmmmm have to think about that one.......
  19. hi....this is not a real build log, but rather a once in awhile ''where i'm at build'' along with sharing some experiences along the way and seeking some advice..............hmmmmm....maybe that's a build log..... i wasn't going to bother posting on this forum since i couldn't come close to competing with the exceptional builds here of the confederacy, since i'm a 30% impatient-30% trial- and 30% error builder....and as i've discovered.....no....i can't change, no matter hard i try...even at my age.........but.....somehow the models come out looking ok......... so this is a ''don't do this at home'' kind of post....or bare my butt log........for example......i have the ship on my lap.....lean over to sand a plank on the belt sander, and gouge a chunk out of the the planking below the wales near the bow....ha!...and you know what, to top it off??...i panick!!.....and grab the sanding block and try to sand down the gouge, and of course i end up with paper thin planks.....so.....i have to cut out and replace maybe 5 planks at different lengths so they would blend in better and not stand out like a square patch.....and that wasn't easy....if i slipped and cut into a neighbouring plank, i'd have to cut that one out too.......so there.....this is the me i have to deal with, and i thought people here, wouldn't mind getting a laugh at this, or experience an i've done that too .........oh.....i oversanded a bit on another section too, but i just reinforced the back with 5 min epoxy instead of re-planking.....see how much fun this will be?....i have to say how nice that chuck designed so many bulkheads, which reduces this kind of thing from happening....for others, that is used swiss pear, which is a wonderful wood to work with, though it does have a bit of mottling in the grain, which is why i decided to use the rub on satin urethane instead of the tung oil, which i would have really prefered, but didn't use, as it would bring out the grain more......have only applied a quick rub on with urethane, to check apperance.....will use bass on the deck...... i purchased a few cannons from syrene ship model cause the ones in the kit were ...hmmmmm........ anyways, i'll mold and cast them, and paint the number required instead of purchasing all brass.....they do seem a bit slim though, and i wonder if the nozzle hole should be widened somewhat.......and of course, i found a better ships wheel...... anyways, until next time, and we'll see what other foibles i can come up with..... oh....i do have to say that this is a super kit, and so much fun!.....and so much work has gone into the plans and manual...never seen anything like it....and in english!!!...a first for me.......now i can find out what everything is called...ha!......cheers, vic
