bluenose2
  • Gender
  • Location
    Canada
2,780 profile views
  1. So further to this topic. The pen starts at it's lowest setting 5000 rpm. Then 10,000 and 18,000 rpm. The optional micro drill bit set has 10 bits ranging from 0.3 to 1.2 mm's. I find it also works well on resin figures. No it does not have collets but I can use the 2.34 mm Dremel and others in this unit. So far So good.
  2. Hello Les here. I have a new tool to me in my must have tool box. It is the DSPIAE Electric sanding pen. It is a rechargeable mini Dremel like tool. I have used it to drill very small holes and do close grinding. For close in work it kills the Dremel or other similar tools I have. It isn't as powerful as a rotary tool but it fits very well in the hand. You can purchase a tungsten drill bit set separate. The drill was $39.97 Can and the drill bit set was $10.97 here in Edmonton. Please check it out. And no this is not a commercial. Check out their web site to find a distributor near you.
  3. Hello Les here. As a painter I get what your talking about. Dap. This product is not rated for this application. If you must, use a solvent based product that is used for exterior siding. Mulco is one. Just be aware that you can't cut the tip fine enough to apply to a very small bead. I would Google " marine caulking" and see what comes up.
  4. After some thought I'm going to rig all the same colours. While a ship at sea or under retrofit would replace lines as required I think it would be a bit much and look like a hodgepodge due to it's small size. Thnx for the input.
  5. Hello Les here. I am currently building the Corel version of this ship. I have purchased the book Endeavour, by Karl Heinz Marquardt. I believe this to be the best reference book out there. I have made many revisions based on the material. I have built the masts and yards based on this book. Now my dilemma is that the mast and rigging plans don't necessarily agree with each other. So what next? The build plan shows the places where you belay or rig the ship but the book does not. I feel your pain.
  6. thx for the info. I'm still on the fence on this one. I like to show my models with a slightly lived in stance.
  7. Hello Les here. Is it acceptable to use two different colours of rigging line for the running rigging. Both would be tan but not the same.
  8. Hi Les back. Whenever I use epoxy I wear gloves to limit the contact to my skin. I make sure that I have my vent fan on to evacuate the fumes.
  9. Hi Les here. I use Lepage 5 minute epoxy. It's available here in Canada. So far so good. I would be interested in a side by side review.
  10. Fascinating. I am building the Endeavour and the Beagle. Would these ships have been fitted with these devices?
  11. Thank you for your responses. I can only imagine a ship rolling out of a yard fresh as a daisy. What would it have looked and smelled like? My new build on the Beagle has made me think if I should make it pristine or like a ship that has done a few years at sea. I don't build any of my models overly weathered as this, only in my opinion shows disrespect for the craft. As this will be my final build, I agree whole heartedly that the final planking of especially walnut may add some limited interest for those who don't know anything about how ships were built in this era but thats not the point. I would like to get this one right so I can look at it and say it's as close as I could get it. Luckily a have a wood supply store in my city so I can get what you have recommended.
  12. I have a question. I am working on my next build the Beagle. I would like to do something different. I believe that ships of this era where planked primarily with oak not walnut as supplied by the kit suppliers. I have some old growth in my stock and would consider milling it for planking etc. Would this be a good idea and how would I finish all the components? Thnx Les.
  13. So I think this is what I'm going to try. Take a small sharp blade and very carefully scrape the joint so I don't feel any sharp edge on the joint. Then flood in some Varathane to seal the crack. Then I will see if I can polish and buff the repair. I will use some Novis polishing compound used for Plexiglass scratch repairs and see if this works. If that isn't satisfactory I will mask out and spray new clear coat just like an auto body shop would do for a repair.
  14. The model stays in my basement, were humidity is around 32% and around 18 Celcius.
  15. As this is a static kit I can't get into the back side. I checked for movement between bulkheads but there isn't any. I suspect it is a shrinkage issue as all planks were soaked to get them to conform to the contour of the barrel back hull.
