mkmossop
Posts posted by mkmossop
Ok well I figured I'd just start and wing it.
I filed all the bulkheads down to where I thought they should be roughly. I'm applying the planks now and fine tuning the filing as I go.
The little red and black file is great for this. It's a Japanese finger file I got at a store called Lee Valley Tools. They have all sorts of cool tools there you wouldn't find elsewhere.
Anyway so far it hasn't been pretty but it's going ok. The only problem I see so far is that the bottom plank is not close to touching the last bulkhead at the bow. If I were to nail it to the bulkhead it would completely warp the shape of the hull. I figure it's not a huge deal though as long as the shape is smooth?
I also have never tapered planks so I will have to figure that out. On my last model I didn't taper them, rather just changed their orientation at the bottom. I found a youtube video explaining how to calculate the amount of taper at each bulkhead, so I will post my progress on that soon.
Edit: Also for the life of me I could not figure out what level to start the lower plank at. I looked at a couple other builds I found here and on other forums and both had nine planks at the max width, so that's what I did. I hope that's right. If anyone can help me on that please do.
Just starting a new build after a few years off.
It's only my second build. I just started building the hull and I'm already stuck and need help lol.
My work so far is attached. And I've also attached a picture of the instructions. If I'm correct, pieces 14 and 15 should NOT be glued on to the frame? The frame will be removed later after the planking, but I believe these pieces should be staying on the boat. I don't read Italian and the English version isn't totally clear to me.
Secondly if someone could help me with tapering the frame that would be great. I don't remember how I did it on my last build.
Do you generally taper each piece of the frame (in the picture pieces 2 - 9) at the same angle, then nail the planks down?
Or does it require more precision and you file each piece at different angles, testing the fit of each plank as you go?
Hopefully this question makes sense 😅.
On 6/23/2020 at 7:41 AM, Louie da fly said:
Hi mkmossop,
I just came across this log after a reorganisation in the MSW site. That's a very cool Santa Maria. Did you ever finish it? If so, any chance of some photos?
Hey my friend... yes I did finish it finally.
I completely forgot that I never finished this build log. I just came on this site to ask some questions about my new model build and saw your question now 😅.
I will post some detailed pictures of it in a few days. For now here's just a couple as I just put it up in my new apartment behind my couch.
I'm very happy with how it came out considering it's my first one. I spent many many hours on it figuring it all out.
- Prowler901, Knocklouder, Altduck and 1 other
- 3
- 1
So the hairspray worked pretty well... here are a couple pics.
I'm really annoyed I didn't ask about this before... inserting a wire would have solved all this and I would be able to rig the lines tight. I'm considering trying to unfold the bottoms of the sails and add in a wire, but I'll lose it if I mess something up and have to redo them, so I probably won't. Hopefully I can figure something up to get the lines tighter.
Ah damn... should have thought of the wire... too late for that now. I think the hairspray will work to maintain the sail shape, however I don't know how I'll get the rigging taught.
Which one is the sheet line? On the main sail I have the clew line, then one line going back and one going forward. They are semi balanced, but couldn't get them all taught at the same time. I would need the sail to be more rigid.
I didn't find much in a search here, but I'm pretty sure I read somewhere a while ago that hair spray works well to puff out sails? I was thinking of trying some on mine later tonight.
I have an issue though which I'm not sure the hair spray will fix. The rigging on my sails is loose because of the lack of rigidity in the sails. I'm hoping the stiffening them with the hairspray will help, but I'm not sure. I think the edges of the sails need to be rigid to pull the rigging tight. I guess glue would work, but would probably show.
How do people usually fix this? Just leave the rigging loose? I could pull it tight but then the sails would be pulled way way back and would look silly. I worked hard to keep the rest of the rigging (on masts etc) tight since I think it looks much better. Here are a couple pics of the loose sail rigs.
Ok cool thanks for your input.
Hmm ok I'll look into those threads. I tried sewing some last night with some regular sized sewing thread and didn't think it looked too great, but maybe it would look better with thinner thread.
So from your post I take it most people here sew on the bolt rope?
From what I can tell it's actually glued on pretty well, but extra reinforcement would be bad. I just used regular wood glue.
Hey thanks for your help .
So I notice that in your picture that although the yard is tapered, the sail is tight against the yard the whole way. I was thinking that you would want to have the sail horizontal the whole way across, and since my yards are tapered, the sail wouldn't be totally flush. Does that make sense?
Also here's a picture of my main yard (couldn't take a good one without other stuff in the way). It's two yards stuck together, so as you can see the right side is much higher than the left. Here I would assume there would have to be space between the sail and the yard or else it would look funny. Would it be correct to attach the sail as the red line is drawn?
The diagram below shows robands made in one piece. The roband is doubled and the loop passed through the sail from back to front and then the ends lead as shown in the diagram and are finished with a square knot at the top of the yard.
Not sure I can figure out how to tie that from the diagram, but I'll give it a try. Thanks for your help.
I cant imagine a need for all those eye splices between the spar and the sail, certainly not in a ship model where they will only serve to create a huge gap between the sail and the spar, and/or bizarre lumps. I believe there should be two robands in each cloth of the sail and if you are using thick thread you are going to wind up with a yard that looks ribbed. Err on the side of very thin robands. On an actual ship the line used for robands would not be thicker than your finger. If you use heavier stuff than that you will have the wrong look. You don't mention what ship you are building or what scale. On a model of such a scale that the yard is 12" wide or more you would have to show details- again, in my opinion. On a smaller scale ship you don't even- in my opinion- need to actually have the robands pierce the sail, they can simply be a turn around the yard and when you glue the sail over them they will look legit. On a really small model you can simply spiral a single piece of thread from yardarm to yardarm, spacing the turns appropriately and glue the sail on over it.
This is my model here:
http://modelshipworld.com/index.php/topic/3445-santa-maria-by-mkmossop-amati/
So are the robands too thick on the second picture I posted above? From what you said those look about right, or maybe a little too thick.
Are there any threads here where I can see how you did your robands?
I'm looking for some help in making some robands to attach my sails to the yard. I'm not sure if "roband" is the right term since Google doesn't really give any results for it, but it was used in a model ship building book that I have.
This is the only decent picture I could find of a roband:
Just curious about what type of knot people use to tie these, and what size rope? Is it more common to just use a simple loop like this?
Thanks!
I got rid of the blue lines and ironed out the creases and folded down the edges.
Looking for some opinions... should I sew down the folded edges, or just glue them down? I think if I sew them it may look too "busy", and there may be loose thread ends showing. If I glue them it'd look pretty much like it does now, but cleaner. Also I need to glue and sew ropes around the edges... anyone have any tips for that?
So after struggling with the ratlines for a while I finally got them done. I shortened the distance between the deadeyes a lot, and used very thin thread for the ratlines, which helped me keep the shrouds straight. I know the ratlines are a bit far apart, but I like the look better like that and that's also how the model is on the box cover.
I've also been doing a lot of work on the sails. This is a picture of the original sails that came with the kit, where I painted the emblem on.
The problem was I couldn't sew over the stitch lines while keeping them totally covered up... the brown stitch lines would show beneath the thread which I thought looked really bad. After trying a bunch of times to get it right I decided to order some new sail material and trace all the stuff by hand with an erasable marker.
I was planning on taking them to a professional tailor to get the stitches on perfectly straight, but I was able to do a pretty good job myself I think. Because the material is so thin they're a bit crinkled because the fabric gets pulled up while sewing. I'm gonna pull the stitching and iron them to get some of the crinkles out. Also the blue erasable marker is still there, so I need to wash that off. I'll post the finished product once I wash and straighten them and sew the edges down.
So after trying a bunch on my own to sew the sails and not being happy with my work, I took them to a (supposed) professional, and this is what I got back. I'm not happy at all with what she did. I said specifically that I wanted the dotted brown lines to be covered perfectly with the thread, which she didn't do at all. Is this a decent job or are my standards too high?
When I did it myself I had a very tough time to cover the lines perfectly, so I know how hard it is, but I assumed a professional would be able to get it perfect. I think it looks sort of OK from a distance, but up close looks like crap.
If it's really so difficult to cover the dotted lines perfectly then maybe I just won't sew them. I may try to contact another seamstress first though.
That's interesting about the boltrope. I was going to glue it on and then also sew around it because I thought that was accurate, and that's what I see on model ships... but maybe I won't do that now.
I think sewing through the sail can look really good, even though it probably is way out of scale.
New Bedford Whale Boat 1860 by mkmossop - Amati
in - Kit build logs for subjects built from 1851 - 1900
Posted · Edited by mkmossop
added picture
Ok well I read up a bit on tapering and then did my best. Winged it a bit but it seems to have turned out ok for my first time.
The last two planks aren't as tapered as the rest of them unfortunately, but overall I think it doesn't look too bad.
I'm a little concerned about light coming through small cracks between some of the planks, however I figure I can fill the outside of the cracks with glue and that'll take care of it.
Also they were a little uneven before, but are evening out with the supports I'm adding now. And will even out even more with the additional supports to come.
