JSGerson
6 Followers
About JSGerson
  • Birthday 11/04/1946
  • Gender
  • Location
    Aiken, South Carolina
4,708 profile views
  1. Here is a view of the cleat with the topgallant rail, albeit not being used for the cathead, but a clear picture never the less. Jon
  2. At first glance at your next to last photo, (post 985), you almost can't tell if you are looking at a model or the actual ship! Well done!!!! Jon
  3. Peter, other than installing a double linked chain (links with a cross bar) and a cable for two anchors on the gun deck, I haven't spent much time dealing with the anchors. Since my build is based mostly on the 2017 restoration, the last photo I found where the ship had an active anchor was from her tour to the west coast in the thirty's after her 1927 restoration. She sported a double linked chain and a rope cable for the anchors. Since the kit provided three anchors, I figured I'd store the third one on the spar deck. I haven't checked Ken's log for his anchor placement methods yet and probable won't until I get ready to install them. As I have mentioned before, I don't know how accurate my configuration is, but it does allow me to demonstrate the variations. At present, my anchor chain and cable hang anchorless and waiting. I am try not to add items they may get knocked off the model as it is being handled until necessary. I learned this lesson first with gun port covers being knocked off on my Rattlesnake, and second with the rope stanchions on the gun deck being knocked off for installing them too early. So, until I rig all the spar deck guns (and this is taking forever), add all the other furniture to the spar deck, and install the channels, among other things, the anchors will have to wait. Jon
  4. Looking at the actual ship, you are right...of course! My eyesight is not what it use to be...and it was bad then too. I've been wearing glasses since I was seven and should have been wearing them sooner than that. That little detail my fabrication so much easier. Jon
  5. Beautifully done. I assume that since that channel eyebolt is not attached to anything other than the channel, can pull it off, open it up to accept the block double rings, and insert it back into the opening left in the channel? Or do you have a better alternative elegant plan to attached to that triple block to the channel eyebolt? Jon
  6. Peter, have you looked at my log, starting at post 757. It may help you...or not🤓
  7. Just stumbled onto this log and let me also welcome you the black hole of wooden ship model. Once you jump in, it is very hard to climb out. I have been working on my MSW Constitution since 2017 and still have a number of years to go. This is my 2nd fully rigged plank on bulkhead (POB) ship and my 3rd wooden model. My 1st was a solid hull Mamoli kit of the British schooner Evergreen. My 2nd was the POB Mamoli Rattlesnake. Since you are new to this hobby of wooden ships, may I suggest that when you are ready to start the USS Constitution, you invest in the USS Constitution practicum by Robert Hunt at his Lauck Street Shipyard website. He provides step by step instruction invaluable for beginners. But, be aware, his practicum is not perfect and most of us use his instructions just as a guide. We also review the build logs of others for their guidance as well. It is also important to have the proper tools. Do not make the mistake of buying a tool in anticipation of its use. Check with others, to find out if it really worth the money. I have have bought many a tool, only to have it covered in sawdust from lack of use. One tool however. that I highly recommend, is the Jim Byrnes 4" table saw from Byrnes Model Machines. This is a highly sought after precision tool well worth the money. I look forward to your future postings, especially when you start your USS Constitution kit. There is a wealth of information and active builders here on MSW to help you along. Jon
  8. I did you one better. After I made my rudder, I set it aside in a box to be used later when I was ready to add its hinges. Then I used it to help formulate and fabricate the hinge axial, pintles, and gudgeons. When I was ready to install them on the rudder, I couldn't find the rudder. Now a rudder is not an easy thing to lose. Yet after weeks of looking I gave up because I didn't want to waste more time looking and so I fabricated a new one and installed it as you see it today. Then about a week later, the original one reappeared innocently sitting on my workbench just behind the model. I know I checked the workbench thoroughly and it was gone. Now it's back. A total mystery in the saga of ship model builders. Jon
  9. I think you misread my post. I have no intentions of rigging the rudder to be activated by the ship's wheel. Once the rudder is in position in the display case, that's it, I'm done.😁
  10. Very nice looking. From what I can see, the rudder will not move on your model, but then again it doesn't have to. It's a static model. I made mine moveable strictly as a challenge of my skills. Once my model is in its display case, my rudder won't move either. You save a lot of work and got beautiful results. Well done! Jon
  11. My mental concept is to displayed one anchor hanging from a cathead with the double linked chain I bought on the web some years past, one anchor also hanging on the other cathead but with the cable, and the third stored on deck alone. I don't know how accurate that is, but does show off the various possibilities. Jon
  12. Still looking good! Don't forget to make sure the notched masts have at least the preliminary required rakes. Those will be finalized when you permanently install the gun deck mast rings with dry fitted masts. Jon
  13. You are correct, those are the fun things to make. The gun deck has lots of these gem mini-models to fabricate. Too bad very few of them will be visible enough for observers to see and appreciate fully. Jon
