Everything posted by Kevin Kenny
Yes Bob, i found a mill end .125” and was able to use it in the Cameron drill press to flatten a small section on the post, then a jeweler friend explained that they use a small diamond head round burr to create a slight curve in the flat section, which i then drilled. I was able to drill 22 holes through the post using oil as a lubricant and the drill is still good. This was a great solution as I have no idea when our airports will reopen. The lead time on ordering the resistance solder is also long. so i am back on schedule. thanks for all the advice.
Help with soldering
Kevin Kenny replied to Kevin Kenny's topic in Metal Work, Soldering and Metal Fittings
I updated it -
Help with soldering
Decided to try to drill post as i have no idea when our airports will reopen. To my surprise i have been able to drill 4 holes in three post. Difficult as the drill bit tends to wonder as i can punch the post. I used a file to score the post. I do not think the drill bit will last too long but it will be much cheaper than buying the resistance soldering unit which is currently unavailable. Keep you fingers crossed. -
Help with soldering
Pat thanks so much for your response. Makes me want to purchase the unit. What do you think i need to buy with the first purchase? I live in Trinidad so its problematic to get stuff. I am also not sure if i can even get to clear the items from the courier service as the country has just implemented a total shut down. The airport is now closed. -
Help with soldering
I need a stronger joint than varnish would give -
Decided to make provision to light the interior, so had to carve access to the cabins. Then painted the stanchions and main post.
Over head sliding lift above the freight holds. Made up soldering brass L beams to make the ibeam, then three pieces of brass c channels to make up the sliding car.
How Realistic Can One Make Sails?
Kevin Kenny replied to Julie Mo's topic in Masting, rigging and sails
They look great. I like how they hold the shape. -
