Everything posted by Ronald-V
Very nice build so far! And, nice clean look! Good luck with the carronades :D:D:D
- 53 replies
- pickle
- caldercraft
- 271 replies
- 271 replies
Those are straight from the kit I will keep things pretty standard from the kit with this build. First goal is to finish a ship😂
- 271 replies
- 271 replies
Thanks for your kind words! And have fun with your first build. Just take it slow 😉. And maybe start a build log so we can follow your progress to👍
- 271 replies
Ah tnx! I think I'm going for the dry dock look.
- 271 replies
so they would be blackish green due to the oxidation in the water?
- 271 replies
Tnx Peter! I saw it in your build that you painted the hinges copper. I considered it, but I still doubting if I'm painting it copper. Because the actual copper is aging with time. So there is going to be a colouring difference. I think I'm deciding it at the end of the build. Then I can mix maybe the colour right to match the coppering. Thanks for the compliments and tips!
- 271 replies
The rudder is fixt! The coppering is a bit shiny😁. But that gets old soon. You can also see one of the scuppers that I added.
- 271 replies
Yes it looks pretty strong also...thanks to Caldercraft... they did a very good job with the instructions with this model. Everything seems clear and solid.
- 271 replies
Beam fits like a glove...just dryfitted for now. Needs to run parallel with the keel. Looks like it!
- 271 replies
- 271 replies
- 271 replies
Something weird in the manual. The hawse holes need to be on different places. As you can see also on the photo's. But if you read the instructions... they have to be drilled on the same height...9mm under the capping rails. But if you look at the pictures...the one on port side looks higher then the one starboard.
- 271 replies
- 271 replies
Finished the windlass and pawl bitts. Just gave everything a second layer of paint. Need some wheatering tho. They are dry fitted at the deck with some pins, but not yet fixt with glue. Don't know exactly, maybe for convenience to work on the deck.
- 271 replies
It's now taking shape! Great build Lazy Saint!
- 104 replies
- sherbourne
- caldercraft
- 271 replies
- 271 replies
- 271 replies
