Rick01
Posts posted by Rick01
Looking good Vossie - I knocked the bulkhead extensions off at this stage then planked the inner side of the gunwales which smoothed out some minor ripples at the forward gun ports. Obviously all the planking was curved to shape first and gun ports were planked over then re-opened once planking was dry.
Rick
- vossiewulf and Canute
2
I did have problems with a slight bowing at the gun ports however once I'd started to plank this area the planking did pull it all back into line.
Rick
- mtaylor, Canute and vossiewulf
3
"I'm good with this, although I look forward to doing a ship where the keel is correctly left off until after planking as cutting those rabbets will be trivial in comparison to this little bit of micro-surgery."
I've seen a couple of builds where instructions recommend fitting keel before planking - the builder has ignored this, cut the rabbet, planked first and second layer then cut a groove to take the full keel. Worked very well as long as they had a very steady hand for the last operation.
Rick
- Canute, mtaylor and vossiewulf
3
Just before you do you'll need to decide if you're going to paint the bulwarks and facia or leave plain timber. If the latter then it would be easier to put a veneer planking on the inner face of the facia before fitting.
Rick
- Canute, vossiewulf and mtaylor
3
That's the same way I handled it. Bulwarks first soaking them at the prow to ensure that they bend without breaking at the first cannon port (mine did anyway :-( ). They will almost certainly need trimming at the stern to match the angle of the elbows, then as you say fit the stern fascia. This will only need the final planking in due course.
Rick
3
Doesn't matter how well I check my work I always seem to find one little thing that got missed/misaligned! At least it wasn't at a point where nothing could be done.
Rick
- vossiewulf, Canute and mtaylor
3
I actually thought that you'd realised that the deadeye would also require a bit of work! Maybe a request to Chuck for a "one off" would be the way to go. As for the boom/bowsprit I'm afraid I can't answer that one, hopefully Druxey or Chuck will see this and be able to answer, I'd also be interested in the reasoning behind it.
Rick
I'm going to enjoy watching you make the corresponding 5 holed deadeye when you start rigging the ship.
Rick
3
Yep, I was aware of that ship too but not that people wanted to defend its honor
We Australians get a little upset at times when our own history gets forgotten. The original release of this ship did in fact claim it was the real "Lady Nelson" - pretty obviously not when you count the masts!!
As to the planking, your idea looks fine, I did go about it a slightly different way in that my second planking was done using .06 thick planking - somewhat easier to manipulate.
Rick
- vossiewulf, mtaylor and Canute
3
Vossiewulf - there is another reason why a few of us don't really like the name on this cutter. There actually was a "Lady Nelson" used in the exploration of Australia but rigged as a brig rather than a cutter see https://en.wikipedia.org/wiki/HMS_Lady_Nelson_(1798)wikipedia I know but in this instance basically accurate.
Rick
- vossiewulf, Borborygm, mtaylor and 1 other
4
I fitted the gunwales first then soaked and bent the transom into the approximate curve needed. Once I was satisfied with it I then started carefully shaving the "legs" until everything went together neatly. By the way the gunwales have a tendency to break at the bow gun ports if you're not super careful when fitting ( not that I'd expect anything other than care going on your build so far).
Rick
3
One specific error in Petersson is the anchor cable on the windlass. The cable on one side is correctly led over the drum whilst the other one goes under. So turning the windlass will be lowering one anchor whilst raising the other ! This error has been replicated by the manufacturer of the model of HM Cutter Mermaid .
Rick
I also reversed the companionway so the doors are facing aft - seems to me that less water would be hitting it in heavy seas/storms than in its shown position of doors opening forward. The belfry seems to be an item that doesn't have any specific position on cutters, I've seen them built onto the companionway top and on the windlass so that item is open for you to decide.
Rick
3
Hi - Tony has it. The companionway is the boxy looking structure aft of the last grating. I re-made mine using planking as I personally think it looks better than slab sides. As for the gratings I fit a bit of matt black card into the grating at the scale we're working at it does the job nicely.
Rick
Pretty much how I understood it. However the kit only provides for two blocks so I'm puzzled over how one belays what is "in effect" a running hoist broken only by the loop and toggle for fixing the flag.
I'm to far on with the kit to now go back and provide some belaying pin racks at the stern.
Rick
I'm at the stage of rigging my cutter "Lady Nelson" and am puzzling over the flag hoist. Both the plans and Petersson agree that a block is roved to the tip of the gaff but then differ in that Petersson has the "loose" ends run down to a belaying pin whilst the kit indicates a continuous loop running through a second block fixed to a ring bolt by the rudder. Using this latter system, once the flag is hoist how does it then remain hoist? I'm assuming that the apparent continuous loop does in fact have a loop and toggle clipped together when no flag attached, otherwise fixed to the flag appropriately.
(Hope this makes sense).
Rick
When you do get to the rigging you'll find that you need a few more belaying points than the kit allows. I've 8 ring bolts around the mast I should have remade the belaying pin rack (can't think of the correct word!) as the pins are to close together - would have been better split in two and set between two cannon positions.
Rck
3
Fillers then deck - I'm building this model and that (to me) is much the better way.
Rick
" I will try my best to make a perfect Lady Nelson, but know I will never get there."
As this kit is actually generic in that there was no cutter "Lady Nelson" as long as you follow the general layout etc. for an 18th century cutter you will have produced your own "perfect" model. Lennarth Petersson's "Rigging Period Fore_and-aft Craft will give you a reasonable rigging plan (better than the stripped down version supplied) and a look here at contemporary cutter models will also provide some illumination.
Rick
Lady Nelson by vossiewulf - Amati/Victory Models - 1:64
I was actually in two minds about posting as I know you like to work these things out yourself. However you had already mentioned ironing out ripples so I went ahead with my own experience in this area.
Rick
