Everything posted by Sirius
Paul, You're doing an incredible job. I can't imagine how will be your next projects. I really like the finish of the decks planking. It is very real. What wood did you use and what was the process to achieve that aspect? Regards, Manuel
- 708 replies
- victory
- constructo
Thank you Mike. I like your Chili Red color. You can try patenting it
- 143 replies
Mike, You're doing a very good job. What is the reference (manufacturer/code) for the red color in the gun carriages?
- 143 replies
Hi Aqueous, Great work! I am building the same model too and I would like to share with you or someone interested some tips and changes that I have done. I hope it's not too late because your last entry is almost one year ago. At this moment, I have finished the lower and the middle decks with all the decorative elements, the planking of the hull and I am working on the upper deck. I didn't follow the instructions in the same order because the gun carriages, boxes, barrels, etc. are added when the entire structure is complete. I thought that doing so would be difficult to put those elements, specially to attach the gun carriages to the interior hull, so I glued them once that every deck was finished. I also completed the first planking just until the beginning of the deck for having enough space from the outside. I've made some improvements: - Gun and gun carriages were not very realistic so instead of that I have used Amati Wooden gun - The whales and upper bulkwarks termination in the hull is a wallnut plank and thicker than the supplied - Inner gunports planking as you did - Blakened cannonballs in triangular wood trays, not in buckets - Blakened chains instead of brass wire for the chain plates (not yet installed) Here you are a few pics of different phases: Current state: Lower deck: Middle deck: Hope to see your next entries soon.
