Posts posted by robert22564
Good luck with it Rich. you can sort it and be back on track in no time
My first line working to the stern I kept my tiles butted up tight on the vertical.
My second line I kept my tiles butted up tight on the horizontal.
Third line back to butting up on the vertical, the line should then follow the curvature of the hull as shown.
And then as Shipyard Sid always advises I filled in the gaps.
I've planked the inner Bulwarks just to get a little break from the copper plating as you can see.
I've also cleaned up and re-painted the waterline on the port side and now it's back to copper plating the hull.
I'll try to be a little more informative this time around instead of just showing pictures.
I'm not saying this is how it should be done, I'm just showing the way I did it "remember I'm a novice and this is my first ship build".
Starting from the keel I've done 21 tiles on the Horizontal and formed a pyramid formation 18 tiles high.
- zoly99sask, Philg88, mdkboggle and 1 other
- 4
I'm relativity new at this game as you all know, reading this thread has me very concerned, I've just recently purchased Caldercrafts/Jotika's Victory and i didn't do an inventory check neither, I hope and pray I don't have the issues of missing parts like some of you on here.
I was strongly leaning towards putting Agamemnon on the shelf as a next build but this thread has clearly put me off of that.
Hi Tim, I'm also building HMS Victory as a first build.........I think I'm slightly in front of you and if that is the case then keep an eye on my log because if a mistake is going to be made you bet your bottom dollar I'll make it.
Good luck with your build.
Robert.
- mdkboggle, diablo0007 and Shipyard sid
- 3
Glenn, David & Philip, thank you for your kind comments.
I think I'll do the inner gunport walls and have a break from copper tilling for a while, I'm seeing double at the moment.
Hello John, thanks for visiting my log and "of Course" your kind words
Hello Robert.
Well, well, well... How did I miss your site? You are doing a beautiful job on Victory and the copper plating looks so neat and crisp. I began at the waterline like most but it seem that your idea has merit. From what I have seen by reviewing your site you are building one fine looking model. The finish, in particular, looks terrific as the very neat gun port linings. All in all, your build is to be much admired. I look forward to your progress.
Best,
Jerry
Hello Jerry, I must admit, reading a compliment like that does give one a boost, I thank you for that
Have a wonderful day Jerry.
Robert.
Very nice Jerry, She looks a beauty.
Very impressed with your Deck planking Philip. lovely crisp and clean....it would make my day if I could end up with results like that
Keep up the impressive work.
Robert.
I was planning to make my own plates but your sterling work has me pondering - I don't think there should be too much of an issue using 1:72 parts on a 1:75 build but did these come with the kit or are they the Amati ones from CMB?
Cheers,
Philip
Hello Phil. I'm using the plates that was supplied with the kit but i'm quite sure the ones from cmb are exactly the same, well I hope so because I'll be needing a few more.
- zoly99sask and maddog33
- 2
Thanks for your kind words of encouragement guys and for the PM's "you know who you are"
It's looking like I've sorted the problem, I was using scissors to cut the plates which made them curl and to be quite frank, the measuring was pretty sloppy on my part.
I've re-Done some of the infill plates with a small steel rule and sharp scalpel, the results are much much better, cleaner looking lines
I'll post a pic later this evening.
Now I'm happy to proceed.
So the copper plating begins, I've decided to use a medium super glue gel for this task as it gives me some control on the quantity needed, I'm not really that confident on how this is going to go, so the plan is to take my time, do the best I can and pray
I know quite a few of you have decided to start on the waterline but I've elected to stick with what the instructions say and start at the keel.
If it does start to go tits up and get a bit scrappy i'll copper leaf the entire hull when finished, this should hide any imperfections and give a uniform look when complete.
We'll see how it goes, I'll update regularly on here my progress, fingers crossed
HALF MOON By Jerry - FINISHED - Corel Scale - 1:50
Well done Jerry, She's a beaut.
