Posts posted by Cabbie
Howdy Scott keeps looking better as it goes.
Fully masted, rigged and with sails she will be majestic to look at.
Marvelous thanks Toni that makes it much clearer.
Chris
- EJ_L, Overworked724 and Saburo
- 3
17 minutes ago, modeller_masa said:
Hello mm thank you and good to meet you.
Yes when you look at the pics the bottom of the garboard is lower than the stern post.
It must be exactly as you have put in in the red line, instructions. That makes it a lot clearer thank you.
I did same thing like the mortise on stem. I hope it is correct.
Yes if you mean removing the deadwood so that the face of the garboard is in line with the stern post.
Also are you reading that the Garboard plank is an even taper from stern to stem,
or do you think it is mainly parallel and just widens at the stern and tapers at the bow?
BTW I hope all is well up there and you are coping with covid 19 ok.
Hooroo Chris
- modeller_masa, EJ_L and Saburo
- 3
Good evening to all
Working my way through this model and finding it very enjoyable.
But can someone explain to me how and why the garboard plank has the hook down up to the stern post?
Not registering in my brain.
thanks Chris
- EJ_L, KTO, modeller_masa and 2 others
- 5
Hello Ji Yes there seems to be a lot of adjusting, fiddling to get things sitting right with
some of these kits.
Do a test nail into ply and see if it splits or not. The deck needs to be held down somehow.
Some people use a heap of elastic bands, I have glued a timber strip between the bulkheads at the top of
the b'head and used clamps to hold deck down. Probably won't hurt to nail into the b'heads.
And i have used screws at times to hold things in place whilst the glue dries.
Make sure your keel is straight and every thing is squared up before putting deck on.
Hooroo Chris
Still can't see why they want them, card details name and address seems to be good enough anywhere else.
They will have my money, why does a Spanish bureaucracy need passport/id numbers.
Maybe in your case collecting an insurance payout is fair enough, but i would be sending a small
amount of money in. Wouldn't be getting mine anyway, not going to buy anymore AL kits.
Hooroo Chris
Hello Neddie just came across your log, your boat is looking very good indeed.
I think the first lesson to be learnt is "keep going", paying off for you.
As far as tools goes i use one of these.
Couldn't do without it, no quite PC for some but with the disposable blades, which last a fair while,
it makes a lot of things easier to do. I adjust the blade by tapping with a hammer down near the blade.
Cheers Chris
G'day Pete and welcome to MSW.
It looks like you are off to a strong start. yes the planking is certainly a tricky part of
model boat building. I am waiting on this kit myself and am very interested in seeing what you do.
I know very little about ship boats in general and know nothing of the kit.
If you want something to help build up your skills have a look at this,
https://thenrg.org/the-nrg-store.php#!/Half-Hull-Planking-Kit/c/41410202/offset=0&sort=normal
I just started this one.
Thanks for the link to the other log as well.
Hooroo Chris
Just looking through the new site and in order to create an account or use the instant checkout
you have to give them your Id or Passport number.
To me that sounds a bit strange.
https://artesanialatina.net/en/autenticacion?back=my-account
Mine was done this way as well, but it was mostly flat. Hard to say what is needed until you start to fair the hull.
What you could do is screw it on dry and then see if there is enough material available for you to sand it flat.
If not, then glue it on and fill with car filling bog or builders bog. it was placed centrally and flush with the bulkheads at the top.
Cheers Chris
Nice diagram Craig but I haven't got a clue what you are suggesting.
BUT no need to explain, you don't have enough time for me.
On the first image they don't show the line on the other side of the sail.
If it was done as in the Mermaid drawing there would need to
worry about it for tacking?
Chris
On 6/28/2020 at 11:11 AM, Jim Lad said:
It will be good to see a model of her carrying her boats - I don't think I've ever seen a cutter model with boats on deck.
John
Thanks John looks like its a 2 part challenge now, making them and then attaching to the deck.
BTW i am enjoying looking at these images on the new 4k computer screen, rally brings out the detail.
And did you see this topic, should be easy for a man of your talents.
Hooroo Chris
Thanks Craig for all of your help I was thinking the same
myself about the breadth of the boats and thinking that meant whale boats.
Cheers Chris
- mtaylor and iMustBeCrazy
- 2
5 minutes ago, iMustBeCrazy said:
I assume you mean me, I've been called a lot of names before but that's a first
Not they, that was written by the man himself. It seems that boat naming conventions can be a bit loose.
He gives 1st cutter, 2nd cutter, Jolly (or is it Joley) and cutter in frames. So you have to build four then take one apart.
Sorry about that sir, from now on you can call yourself Craig,
The cutters are meant to be whaleboats as per this which is taken from
"Mitchell Library, State Library of New South Wales
Phillip Parker King letter book relating to survey voyages around New South Wales, 1817-1823
MLMSS 4429""In addition to these Boongaree a native having volunteered to go with me I have with the Governors permission accepted his services, he formerly was with Captn Flinders
I have 2 Whale Boats, a Jolly Boat
and[Page 15]
and a Whale Boat in frame, in case any accident should happen to the Vessel"
Sorry for one more question i just don't know enough, but one must strike whilst the iron is hot.
Do those measurements look to be for one type of boat or the other?
Thanks Chris
Thanks John
It appears i have a little bit of freedom in regards to the whale boats,
just have to work out how to hold them to the deck. The jolly boat will be shortened from what i have now
back to 12 ft.
But I think madness has set in, thinking I am going to make them, but a challenge has been issued and must be honored.
Thanks Roger PP King use the Mermaid for survey voyages around Australia, i don't
know why he the boats that he had, perhaps it what was on the Mermaid when it was bought.
Thanks Chris
Thanks Craig
What do you think, should the jolly boat be shorter? And the breadth of the whaleboats narrower?
I have seen other sites say a whaleboat is generally 28 ft long 6ft wide.
Also they must in a cradle of sorts to sit on the deck?
Going by ratios from that last drawing to model it looks like my whaleboats could be a bit longer.
Sorry for all the questions Cheers Chris
Hello to all
Some help needed please on the deck and ship boats positioning for my Mermaid
PP King said in his journal that he had 2 whaleboats and a Jolly boat, i have done some cardboard shapes to represent the boats.
Where would the Whaleboats be placed, supported on the deck close to where I have them and would the Jolly boat
be hung off Davits at the stern?
And how about the size of the boats that i have, look about right?
All advice greatly appreciated. Thanks Chris
Looking good Jeff, now something a bit more relaxing for a while, always good.
Chris
- Edwardkenway and Keith Black
- 2
Hello Jii Welcome to MSW
Yes it can be a tricky business, model ship building, but very enjoyable.
Whilst looking at kits look here https://thenrg.org/half-hull-planking-kit.php
A lot of beginners get stuck with the fairing and planking, and learn the correct technique first up.
It comes with a very detailed set of instructions.
I am on to my 3rd model so far and as yet have not done one in the correct traditional method.
I have ordered one and will arrive soon I hope, and will do before I start the ship boats for my Mermaid.
And maybe get yourself a little fun build to do as well.
Hooroo Chris
HM Cutter Mermaid 1817 by JamesBhm - Modellers Shipyard - Scale 1:48 - first build
Go easy on yourself James, they look darn good to me as well.
Good to have some one showing me what to do again, except mine keep getting side tracked.
