Everything posted by Chuck
Thank You very much, and happy Thanksgiving. I rigged the Burton Pendants and started the shrouds. The Burton Pendants (.035 dark brown) are served the entire length with a 1/4" single block seized on it end. It hangs down from the trees a bit more than we are used to with a typical frigate. Then a tackle was set up to the pendant. The tackle is only shown on a few contemporary models and I thought it was interesting so I decided to show it. This particular version is based on the cutter model in the London Science museum and Peterson's book. The Shrouds are pretty standard, I used .045 dark brown rope. The forward shroud is served its entire length. The serving was all done on the "Serv-o-matic". The remainder of the shrouds will only have the portion around the mast head served down to just below the cheeks. Below you can see my shroud gang taking shape with this first pair of shrouds done. The deadeyes were turned in and set-up with the usual methods. I dont particularly care for this aspect of rigging. Especially getting that first seizing done just above the deadeye. Its an awkward one as its oriented differently but it is important because it creates that shape of the shroud doubling you strive for. The lanyard was rigged with .018 light brown rope and not glued permanently. This was done once again so I can easily re-tension the shrouds after all the standing rigging is completed. Now to finish up the three remaining pairs.
- 1,051 replies
- cheerful
- Syren Ship Model Company
Cherry and Maple sheets and milled strips are now available. I know this because I am building his site for him.....I bartered for wood. He isnt the kind of guy to build his own so I am taking care of it for him and you probably notice the similarity to my own. Anyway....as he gives me new updated wood info and availability I will add them to the WPS website and let you guys know. I hope you give them a try. Chuck
Thank You guys. The thimbles are made from thin wall brass tube. In this case 1.5 mm brass tube. I tap them with a blunt point as shown in this image. Not to hard. The brass is soft and the thimbles will tear. They will also stretch larger in dia. and become thinner than you cut the original length. Here are some close ups of my thimbles thus far in use on the model. Also note the thimble not yet punched to flare its ends in that first photo. See how much longer and smaller it is. Hooks are shaped from 26 gauge black wire. Chuck
- 1,051 replies
- cheerful
Finished rigging the gaff today. Nothing unusual or interesting about doing this. It was fun and I basically created the gaff just like the boom. One interesting feature to point out might be how the blocks are hooked to thimbles/bullseyes on the gaff. The blocks were not just seized to the gaff. This follows a method I saw on another cutter from the time period. Just seemed more interesting than doing it the other way. It has gotten harder to photograph now. Its a much bigger subject to get in frame. Next up will be the pendant tackles and shrouds....none of the falls or loose ends have been glued to their belaying points yet. You can see them left a bit long on deck. They are just made fast to each belying point and can be undone easily. I did this just in case they have to be retensioned after the shrouds and stays are completed. Some lines have a tendency to go slack as rigging progresses. Chuck
- 1,051 replies
- cheerful
MS Fair American rigging plan leaves alot to be desired.
Chuck replied to JPAM's topic in Masting, rigging and sails
Check out the gallery which has many photos of that contemporary model. http://modelshipworld.com/index.php/gallery/album/448-fair-american-rogers-collection-annapolis/ -
They are in central New Jersey. They dont have a physical store. He is a member of the a tree commission or conservany or something and gets a lot of his wood from those operations. For example, after Hurricane Sandy he collected a ton of Dogwood, Cherry, and Pear and apple...from fallen trees. Also has dealings with the local tree farmers and orchards. Chuck
Pat That looks fantastic. It must be bitter sweet after working on her for so long. That is a fine looking model.
- 517 replies
- Endeavour
- Artesania Latina
Please welcome and thank Wood Project Source for becoming a sponsor of Model Ship World. WPS supplies milled wood sheets and strips along with carving blocks for many hobbies. Their specialty is Alaskan Yellow Cedar Sheets and Carving Blocks. Other species like Yellow Heart, Purple heart, Butternut, Applewood, Dogwood and Mahogany are soon to follow. They also carry the staples for our hobby like Boxwood, Swiss Pear and others. They are just finishing up their new website so please have some patience with them as they continue adding more wood species and products to their online store. They have many more than I listed. I have personally bought from them many times as they are close by and I gotten to know the owner. I have bought some Yellow Cedar and Boxwood from them and will say that I am very happy with the quality of the wood. They have fantastic prices and they are the lowest I have seen for some wood sheets. Please join me in welcoming them as a sponsor of MSW. Visit their site and check them out. I am grateful they decided to become a sponsor and didnt hesitate after I asked them about it. www.woodprojectsource.com
Thank you so much guys....
- 1,051 replies
- cheerful
Heres a close up of my planking experiment with Yellow cedar. Very tight almost inconceivable grain. holds a sharp edge and no need to stain it. There are two 1/32" sheets below it that I will cut a few carving blanks from and give it a try. I just have to find some time to do so. I applied one coat of WOP. The seams were simulated with a #2 pencil. I like it. I havent tried making frames but it is certainly a great replacement for planking....either for boxwood or even holly. It will darken over time. ALSO....its about half the price of Boxwood and Holly (give or take). A bit more than Cherry or Maple but I think its a much better wood. It really does cut like butter with a #11 blade. Hopefully the same will be true when I carve it. Chuck
I am going to try and carve one of the blanks from Yellow Cedar. Its beautiful stuff and I just got some from my supplier. In case you want to try it check out his site. He also mills boxwood and a whhole bunch of other stuff. His prices are fantastic. So far I am more than happy with the quality and respoinsiveness of this guy. Hopefully once he gets his site up and running it will be even easier to place an order.n As far as I know, he is the only supplier of milled yellow cedar on the web. http://www.woodprojectsource.com/ Right now he doesnt have any items listed on his site as in stock because he is just finishing it up. It should be real soon because he never had a website before and I convinced him to build one. But you can contact him at any time because he is open for business. But thanks to some prodding from me he is starting off by adding the woods we prefer. But he mostly caters to local wood carvers which apparantly there are a lot of. Here is an example in Yellow Cedar of a carving and my test build of the barge. Compare with teh cherry version behind it. I really like it for what we do. Its softer than box but harder than basswood yet the color is beautiful and since I took this photo the color has deepened and it looks almost identical to boxwood although a bit more yellowish....but not an obnoxious yellow at all. Chuck
It looks pretty good. But dont forget to bevel the edges of each strake so they fit really snug up against the strakes already on the hull. You can just knock of the corner of the back edge for the most part.
- 129 replies
- finished
- model shipways
In this instance its Windsor and Newton Galleria acrylic paint. Yes it is thinned down quite a bit and put on in many layers like watercolor. The color is Crimson straight out of the tube. I have used dozens of coats of very thin washes until it becomes opaque. That helps me keep the paint very flat and without paint brush stokes using a round brush. Chuck
- 1,051 replies
- cheerful
Michael, I am using Grumbacher acrylic paints in a tube. Specifically Mars Black. I finished the boom today and its all rigged. It was shaped the same way as the mast. I started with square stock and used the 7/10/7 ratio to convert to an octagon. Then I used my drill to round it off and put the taper on it. The jaws were added after I flattened the sides to accept them. The blocks were prepared in advance, meaning some were added to the boom ahead of time. Other blocks were secured to the mast and horse for sheets. Then it was just a matter of rigging it in place. I have only tightened the ropes around the cleats without any glue. I will leave it this way until after the standing rigging is completed in case I have to re-tension the lines. But from the way it looks I think it will be OK. For the trucks on the jaws to secure the boom to the mast, I used what I found in the shop. I had some boxwood beads laying around that were the perfect size....I might even have enough left over to give the remainder to Mike for his model. Here are some pics. Next up will be the gaff.
- 1,051 replies
- cheerful
I have a couple of those...just havent tried them yet. I am still hoping we will get some folks that will try shaping these pieces with a rotaary tool....it would be nice to have a comparison. Also You guys are free to carve any design and start a log here as long as it is for ship model related items. Carving with any tool is very different when you are working at these scales and it is a very different experience than carving full size or even double the size of these blanks. I know we have a lot of traditional wood carvers out there and once you try carving something as small as these you will see how differently you must approach it. So feel free to carve anything you like....just no folk art old men with a cane....that stuff is not relevant to carving items meant for a ship model at 3/16" or even a 1/4" scale. But if you have a trailboard or another design you want to carve for your ship model...feel free to start a log and get some input from the others. I am very happy to see more logs being started...thanks for the interest. I am also thinking about starting another area on sculpting using polymer clay for those who wish to try that medium to make more complex designs or even the same ones we are doing here. Just have to find the time to start that one up. And I will do so if you guys think there is sufficient interest in it. I am trying to develop this area more so it covers many aspects for creating the decorative elements for a ship model.....whether they are carved or sculpted. Chuck
I plan to...hopefully the gaff and boom will be rigged by then.
- 452 replies
- cheerful
Mike That is looking very nice. Cant wait to see it in person. Chuck
- 452 replies
- cheerful
Make a card template or paper version first. Then after it fits....trace it onto a strip or sheet and cut it out.
- 129 replies
- finished
- model shipways
Thats looking great....the garboard ends just a hair past the scarf joint. I hope this picture helps.
- 129 replies
- finished
- model shipways
