Everything posted by Chuck
Thank Druxey Today I also mass produced a few dozen thimbles in various sizes and thicknesses. I used thin wall brass tube from Albion. They were 1.5mm and 1.2mm and 1.7mm in diameter. I have no idea which will be used where yet but making a bunch now will save me from having to stop while rigging. Blanks of various thickness were cut and then I used the blunt punch shown to shape each end and flare it. Just a few light taps will do it. Then you can blacken them or even paint them whatever your preference is. You can see one blank before I used the punch on it in the lower left hand corner. You can see teh difference between the others pretty clearly. Chuck
- 1,051 replies
- cheerful
- Syren Ship Model Company
Rigging has begun. I still havent made the long guns at the bow but I figured I needed to break the ice and at least add the blocks to the tip of the bowsprit. There are 4 blocks. Two singles and two doubles that are 3/16" long. I am using dark brown for standing rigging and light brown for running rigging. Next up will be the bobstay with tackle and then the bowsprit guys. It has been a long time since I rigged a model. I figured why procrastinate. In some cases, these blocks are hooked to the ringbolts. But I am just seizing them. There are so many different configurations used on Cutters from this time period. And yes...I am using all Syren blocks and rope of course. Its a brutal close up photo but it looks fine in actuality. Onward and upward as they say.
- 1,051 replies
- cheerful
I am willing cut small jobs when the time permits. I would encourage folks to contact me for availability. For example, right now I am swamped and couldnt possibly take a small job for laser cutting and have one such custom job on my to-do list. I just wont get to it til early next month at the soonest. If time isnt a factor then please let me know what you need. Provide me with either a Corel Draw file or a DXF file of the parts. I can talk you about specifics and the need to always have to adjust the drawings after I get them. They will always need to be adjusted for the kerf of the cut depending on what type of wood you choose. If you want the stuff sooner, You can contact National balsa. They have an excellent laser cutting service and I used them all the time before getting my own equipment. But they will only use the woods they have in stock. Basswood, Maple, Cherry and lite ply.....amiong a few other things. See here for the custom laser cutting services at National balsa http://www.nationalbalsa.com/laser_cutting_s/8.htm You would probably have to double your $2000 estimate for getting a laser cutter of your own the needed software and accessories. That is if you want to cut anything thicker than 1/8" basswood with accuracy and a decent cut. Chuck
They were drilled out on a drill press first with a normal bit (round). Then I just took a #11 xacto blade and notched out the corners by eye to square them off. They are 1/16" square. They are not square all the way through. Just deep enough that after painting you would think they were squared up all the way through. They are square only about 3/64" deep into the hole. Thanks for the kind words guys. Chuck
- 1,051 replies
- cheerful
To make the bowsprit....start with a square stick of boxwood 5/16" x 5/16". The inboard section will remain square. The outboard side is rounded off and tapered. There are three square holes on the inboard sides. But these start out as round holes made on the drill press while the entire stick is still square. There is also a sheave on the outboard end. The holes for this simulated sheave are also drilled while the stick is square. Then the outboard end is measured and marked for the 7-10-7 ratios to make it an octagon. From an octagon it is then made round. There are many way to do this. Mini-plan...files...by hand....then rounded off on a lathe or even chocked in your hand drill. Then I made it round...in my hand drill...and taperred it to match the plan while doing so. Once that was done...the simulated sheave on the outboard end was detailed. I used a #11 blade to connect the holes and carve it out a little. Then mini-files were used to round off the simulated sheave. Later I will darken it with pencil. The three inboard holes need to be made square...again there are many way to do this. I decided to just use my #11 blade to carefully square off the corners. The inboard portion will eventually be painted black. The outboard end also has a metal band with four eyes around it. This was made from paper. You could use art tape or even brass if you wanted. Again there are so many choices. It was painted black and weathered so it looked differently than the wood elements painted black. Then it was mounted in the hole at the bow and the fit tweaked. Once it looked good, the bowsprit step was slid onto the inboard end. You wouldnt be able to slide the bowsprit in position if the step was already glued in place. So this is a bit tricky. But soon after I was able to get it all in position and glued securely. Then I touched up the paint and cleaned it up. Next up the long guns can be positioned....but I am unsure of I will add them. They will look very crammed in there. I will have to contemplate that for a bit.
- 1,051 replies
- cheerful
The standard practice is to put your wales in first. Measure off the plans. This establishes the correct run of the planks across the hull. I thought that was your hull. That isnt optimal at all. Then you plank from the wales up......and then from the wales down. Even if its just the first layer of planking for the wales. Best to put the wales in first. Whoever's hull that is will have a funny looking wale at the bow and stern. It doesnt look like the correct run of planking was established. Measure from the shear down to the top of the wales and the bottom of the wales....marke it off on each bulkhead and plank them first. It will save you a lot of trouble....BUT yes....you can spile all of the planking. Absolutely. But its always always good practice to put the wales in first. If you look around this site you will see plenty of hulls where they didnt do that and then when it came time to add the wales as second layer....they did in fact measure from the shear only to discover that the wales will not follow the run of the first planking layer they did at all. Which looks really odd when done. Chuck
That is quite the odd shaped hull at the bow. But yes you can spile all of the planking. Usually it is those under the wales that need it most but looking at your bow shape....I am truly at a loss. So yes probably. I cal tell from teh photos that the bulkheads were not faired nearly enough. That probably contributed to the odd shape. Chuck
Its simple really....you determine the max width for a plank by choosing the scale widths that were actually used on that vessel. Its not a random choice. Should you end up with an odd number of planks after doing so, then just make one belt with one less strake in it. They need not be all the same. But depending on the size of the ship and country of origin....choose the correct width accordingly. It could be eight inches....it could be 10 or 12". It depends on the ship. The period etc. It doesnt have to be equally divided.
Thanks Pat. Yes I agree, I think I am going to go natural. One of the guys in my club said if I was going to the trouble to carve the boxwood rather than use castings I might as well show folks that its a delicate hand carved piece by not covering it up. I agree with him and will now move ahead with the others over pieces when time permits.
- 269 replies
- Queen Anne Barge
US Brig Syren by Gahm - Model Shipways
Chuck replied to Gahm's topic in - Kit build logs for subjects built from 1801 - 1850
Very nicely done. I hope you enjoyed the little mini-kit. Its a rewarding project and you did a marvelous job with it. Chuck -
I know the feeling. I already have two in college. But my oldest got a free ride though. In fact they pay him to go. These kids are too smart to be mine. I dont know what happened there. Maybe I will get lucky again. Probably not. She wants to be a pathologist. How many years is that??? Cha-ching.......a forensic pathologist. Go figure. Chuck
- 1,051 replies
- cheerful
I have been suffering for a lot longer than you think......I really cant believe it though. I am blessed. She is very smart like my boys and is looking at Princeton too!!!! I might have to sell a kidney. I am so very very proud of her. Chuck
- 1,051 replies
- cheerful
No sweaters for me. The agony.....besides my toothache.....its whether to gild or not??? I am leaning towards no gilding. I do like it but its just me. It also shows every last surface pimple and carving screw up. But it is a royal barge. I think I like the way the carvings look with just WOP applied. Which means I must carve another queen Anne cipher. Oh well!! The close-ups are also brutal....the smaller image looks more like the gilded example in reality. It looks rather nasty in that large photo. Chuck
- 269 replies
- Queen Anne Barge
Boxwood carving for the barge in progress. Using a #11 blade. Its half done. Left side shows the laser cut blank while the right side is almost there. The blanks are glued to a piece of scrap with elmers glue. In this case I just used a glue stick. Make sure its really glued down good. Especially the ends of the thin parts that are susceptible to breakage. I sandwich the glued up piece with another scrap sheet and clamp them together so the piece stays flat and doesnt curl up. The blanks are just 1/32" thick and sandwiching keeps them flat so all the surfaces glue up nicely. Leave them overnight to dry really good.....now you are ready to carve. The finished carving is removed from the base by just dumping it face-first into a bath of 90% rubbing alcohol for 5 or 6 hours. They usually just fall right off the base. Let them air dry and you are good to go. When you dont have lots of time to spend on the model its good to keep these carving blanks around the shop. You can easily spend a half hour or 45 minutes doing a little at a time. There are nine such pieces in this kit that will need to be carved. But dont worry .....a resin casting kit will be available for those who dont want to carve them or give this a try. But I urge to to do so...its a lot of fun and addicting. The guys in the club cant get enough of them to play around with. Chuck
- 269 replies
- Queen Anne Barge
Very soon.....had to spend some summer days with the family before they revolted. Beach, taking kids to see Grandma and Grandpa...Visiting Colleges with my daughter. Still have to go to Baltimore at the end of the month to visit John Hopkins and then to UPenn. Sometimes life manages to halt the building. And this Tuesday some root canal for me. Yippie for me. What a tooth ache I have right now. Then its back to Cheerful! Chuck
- 1,051 replies
- cheerful
Frigate Boston by overdale - FINISHED
Chuck replied to overdale's topic in - Build logs for subjects built 1751 - 1800
Wonderful model. It was a pleasure to follow along. -
Today I didnt feel like working. So instead I took a crack at carving the monogram of Queen Anne that will appear on the inside of the flying transom. These will be boxwood in the kit probably but the before and after examples pictures are actually cherry. The blanks like the one on the left are just 1/32" thick. I basically used four easy beginner carving techniques. Lots of stop cuts. But they are at a micro level. Its hardly woodcarving and more like chip carving in my opinion. This is the first wood carved decoration I have made in 25 years. I usually prefer to sculpt as you know. So this was a really fun learning experience. I am far far from being any kind of expert and consider myself an absolute beginner. The whole thing was carved with a number eleven blade in my hobby knife. It is far from anything noteworthy but I am happy with it and excited about doing more carving. Which is the whole point. It was mounted/glued to a thick base for carving as you can see. It worked great. After I was done, I literally soaked it in a cup of 90% rubbing alcohol. 1 hour later this carving literally fell off the baseboard. This was just a test for me and I will be carving another in boxwood for the model. This is the piece I wanted to use as a group tech session here as an intro to carving. Not a class of any kind because I really dont know what I am doing. But just a cheap way for folks to get together and exchange techniques. Learning from each other. This piece and the few others for this kit would make a great tech session build. I am planning on getting my whole club together in my workshop next month. We will all be practicing on this and talking about it as a group......lunch included. I think it will be a blast and I hope other clubs might consider it as well.
- 269 replies
- Queen Anne Barge
Thanks. Unfortunately I wont be going to the Conference this year. My niece is getting married that same Friday night and it looks like a weekend gig. We will be in Philly for the wedding all weekend. I cant wiggle out of this one. I hope I still fit into my leisure suit!!!!
- 269 replies
- Queen Anne Barge
And I almost forgot.....use the paint very thin. Dont use is too thick. I use it the consistency of watercolor. As if I was building up countless layers of thin washes of paint. Slowly working towards an opaque surface. After about the tenth coat I sand with 320 grit paper and apply another ten coats. But I only lightly sand the paint......without removing it using a very light touch. Yes steady control of breathing is very important....a somewhat steady hand also helps. And keep your workstation clean...no dust, absolutely no dust. Use clean fresh water to thin the paint on your pallet. Chuck
- 269 replies
- Queen Anne Barge
