Garward
Everything posted by Garward
  1. Small nails Good way of receiving small nails with a diameter of 0,5 mm with a hat with a diameter of 0,8 mm - use of contact legs from become useless printed-circuit board microprocessor. By means of a gas torch and a knife of a leg are disconnected from a payment, and then by means of a torch are blackened.
  2. It is a little history - the picture from NMM: brigs http://collections.rmg.co.uk/collections.html#!csearch;authority=subject-90308;collectionReference=subject-90308
  3. DECK, SPAR, RIGGING The secondary covering of the hull is executed by Ramin and Sapelli levels without any complications. Practically all other details from a kit.
  4. Continuation Before installation on a mast of a ring 20% selenious acid are blackened.
  5. 14.2.2 . Metal details mast The brass tube is pierced to thickness of a wall of 0,8 mm then are cut, cut, adjusted to diameter of a mast in the corresponding place of a ring which then are soldered by the PSR 40 argentiferous solder.
