Posts posted by Jonesey
I certainly will mate
It was so hot in Portsmouth last Saturday (for England!) I couldn't stay below decks for too long it was just stifling - God knows what it would have been like in the heat of battle with cannons blazing
Have you taken a look at any of those moulded bits yet? They're tricky buggers to remove from the backing card and even trickier cleaning them up
And there are loads of them 😂
Before you close the hull up with the planking, have you given any thought about how the masts are seated?
As far as I can see, they simply sit on top of the lower deck which doesn't fill me with the greatest of confidence about heir stability and was thinking about making something up for them to sit in
- egkb, RichardG and GrandpaPhil
- 3
Off to Portsmouth today to take a look at the real thing
I'll post some pictures when I get back
Progress report:
All frames new glued, along with the 2 strengthening beams and the lower deck
Couple of pictures below
I made up a very simple jig for cutting the deck planks. I secured my steel ruler at right angles with a fairly heavy duty clamp. This enabled me to mount another clamp at the desired length (72.6mm) and also provided some much needed stability
It won't be long before I turn my attention to the hull planking 😬, but before I start planking I'd like to know what anyone has done regarding securing the masts?
As far as I can see, the Corel kit doesn't address this and the bottoms of the masts will simply rest on a quite narrow bit of keel.
- BLACK VIKING and GrandpaPhil
- 2
2 more frames glues in tonight. Started amidships, now working fore & aft, squaring as I go and dry fitting the upper deck for my own peace of mind 😊
What do you use to scrape your decks DA?
Well I bit the bullet and widened all my bulkhead slots so the beams now fit reasonably snugly.
Now that the dry fit looks good I'm going to start gluing the bulkheads in. Squaring each one off as I go with reference to the keel, the beams (26) and the 2 levels of decking.
Wish me luck!
Quick question for you DA
When you came to fit the 2 long beams that run front to back, did you narrow the beam or widen the slots?
Mine are a good 3/32 too wide currently
I'm just getting back to work on the Vic after 4 years in a state of hiatus
Thanks
- EJ_L and Old Collingwood
- 2
Well, doesn't life get in the way sometimes.
Four long years during which we had to have our cat of 17 years put down. We eventually replaced him with a very adorable, precocious young lady.
I lost my father who sadly could not be replaced
We became grandparents for the first time and number 2 is on the way
I've changed my job
And to cap it off we had an extension built which put the dockyard totally out of commission for a year
Other than that it's been extremely dull 😂
So I'm back and raring to go on the Victory once again.
I made my first big mistake yesterday and managed to break bulkhead 14 so had to fashion a new one
I've also built a much better keel jig following ideas i saw on another Victory thread
As ever, I'm going to kick off with a question
Parts 26 do not fit into the bulkhead slots by quite some margin
There seems to be 2 options - widen the bh slots or narrow the width of the 2 pieces in question
Any thoughts?
Thanks
Shape of Rabbet on False Keel
in Click Here for Topics dedicated to planking!!!!
Thank you.
That makes sense!
