Jsk
Everything posted by Jsk
  1. No problem. I particularly like the spear wielding skeleton as the figurehead of the Revenge. Reminds me of the Reavers from 'Firefly'!
  2. Very late to this post but would the following be of any use? https://www.kallboys.de/mondorfer-bastelboegen?start=60 . I'm not familiar with river barges but the Aalschokker Maria Theresia looks similar to my unpracticed eye.
  3. Thanks, everyone. I've started collecting bits and pieces of card from the kitchen recycling bin but I'm always tempted to try and find the 'perfect' cardboard. Some good suggestions here. The admiral just rolls her eyes! Especially when I remind her that it's still cheaper than golf!
  4. First, I’d like to wish you all a happy New Year. May Dame Fortune grant you peace, contentedness and many, many hours of happy modeling time! Now, a little back story: Kathryn and I have quite a lengthy relationship. Well, frankly I’ve been infatuated with her for years but she doesn’t know I exist. (But the story of my adolescence doesn't need to be retold here!) I started designing a card model of the skipjack Kathryn in 2016 based on the HAER papers available from the US Library of Congress (https://loc.gov/pictures/item/md1454/). I refer you to an old build log I did at PaperModelers.com: https://www.papermodelers.com/forum/design-threads/37710-1-100-scale-chesapeake-skipjack.html. Life happened, other hobbies took priority, and I drifted away from model building. Meanwhile, the unfinished Kathryn sat ignored on the mantel in my ‘man cave’. But I didn’t completely forget about my old flame. One of the competing hobbies is the open source flight simulator ‘Flight Gear’. Being a contrarian, I wanted to use it to simulate sail boats. So I enhanced the basic virtual model of Kathryn, ported her into Flight Gear and started (with the help of the Flight Gear forum members) to tinker with the configuration files in order to ‘sail’ the virtual seas. I called it ‘Float Gear’. I refer you to the Flight Gear forum if you’re interested in that unfinished journey: https://forum.flightgear.org/viewtopic.php?f=4&t=40606 Now that the worm has turned yet again and my interest in ship models has resurfaced I’d like to revisit the old girl yet again. One thing I want to accomplish is a larger scale. The original card model was at 1/100 scale—common enough for card models but a bit small for my eyesight these days. I wanted to go to 1/72 scale to match the Viking ship I recently finished. I also wanted to try out a different electronic workflow. I still enjoy using Wings3d (www.wings3d.com) to create virtual models and the original model is still valid. However, back in ’16 I wrote my own script to extract UV coordinates from the model and output them in SVG format in order to create the patterns for card modeling. UV mapping was (and remains) a tedious process in Wings3d. And, UV coordinates don’t necessarily reflect the true shape of the model’s surfaces. Let’s just say it was more work than it was worth. Making revisions was a nightmare. However, over the intervening 7 years other tools have become available. I recently came across a plug-in for Blender which ‘unrolls’ a 3d model. I want to explore that option and see if it really is usable for card modeling or if it is still too limited. So far, the signs are good. In future posts I intend to document how I’ve used Wings3d, Blender and Inkscape to design a card model of Kathryn. While I’m not entirely certain this experiment is going to work, I’m fairly convinced that—at least for a fairly simple model—the real challenge is going to be my rather limited modeling experience. But for now I’ve accomplished enough with a test build to show some progress. The pictures pick up after I’ve cut the longitudinal spine and various bulkheads out of 1mm chipboard. The keel/spine is then doubled to give a final thickness of 2mm. I have explored having these pieces laser cut by a third party but I finally decided I was putting the cart before the horse. I think I need to ensure the design is good before committing to that. After all, I want to make sure it's functional before going for efficiency and ease of construction. As mentioned elsewhere there was a fair amount of warping going on with the spine and the bulkheads. Nevertheless, I dry-fitted all the components in order to assess the situation. Puzzling this out it dawned on me that I had the locations of a number of the bulkheads and the spine marked on the deck piece. That was not intentional, it was just a by-product of the modeling/unrolling process. But I figured I could use those marks to ensure the straightness of the framework. Then I proceeded to cut out the various side pieces. Again, the dotted lines represent the triangles of the electronic model. But as I assembled the model I found that they provided reliable guides to aligning everything. Notice the bottle of isopropyl alcohol in the background. I had inadvertently skipped gluing the 'skin' to one of the bulwarks. This resulted in a bit of puckering since the side pieces do undergo a bit of twisting to make them fit. So... I had my first experience of using IPA to unglue things. Actually, it works pretty well. Poured a little IPA in my paint tray and used a cotton swab to apply it to the glue joints. After giving it a few moments to soak in I carefully started to separate the joins with a dental tool I keep in the hobby toolbox. I had to unglue four bulkheads to get to the puckered area. No harm done, though. The IPA did cause some of the printed ink to run slightly but it did not affect the paper at all. You can also notice that Kathryn suffers from 'hungry horse' syndrome. The smaller, 1/100 scale version didn't suffer like this. IIRC, the card I'm using for the skin is 67#. Maybe 90 or 110# would be better for this larger model. While the model in general is incredibly sturdy, the skin seems more flimsy than in the smaller model. I suppose this is due to the card having to span larger distances at 1/72 scale than it does at 1/100. You can really notice it along the sides of the hull from an end view. Here's a view of both the old 1/100 and the new 1/72 scale models for comparison. And finally a shot to compare sizes between the two models. I've not yet attached the transom and it appears that I've cut the deck about 1mm too long. But I think the next step is to lay on a second layer of skin to smooth out the starving nag look. I'm not sure if I need to apply some putty and a sanding stick to smooth out the inner skin or whether that would just be extra work with no significant benefit. My intent is to make the outer layer slightly longer than the first and to arrange them so that the seams between the top and middle pieces are staggered (probably at the waterline rather than higher up as they are in the first skin). The seam between the middle and bottom will of course still be located at the chine. A second skinning will also allow me to finish up the graphics. After that I'll deal with the transom. Well, that's how things sit for now.
  5. What do experienced card models use for scratch building? I started a quick proof of concept build but didn't have any materials on hand. Perusing a popular buy-anything-you-want-and-have-it-delivered-almost-before-you've-hit-the-buy-button site I ordered some 1/16 inch thick mat board thinking that is should be fairly good for card modeling. It arrived with a built in warp and I almost sent it back. Probably should have. It wasn't even accurate in its thickness. And I've discovered that it de-laminates in a soft breeze. Once you've cut though the outer surface the layers inside aren't much more cohesive than dryer lint. But the problem when ordering things on-line is that you simply can't trust the descriptions or even the reviews. I decided to just get on with the build. I know I'm going to regret it but this is just a proof of concept. At least... that's what I keep telling myself. So, in order to turn lemons into lemonade: What materials have you used that have worked well? What card stocks or other materials have been a joy to work with? Do you have favorite sources? TIA Not bad from a distance: But, oh, so curvaceous:
  6. So, @Kevin-the-lubber, what type of specs do you need in a dxf file? I've currently got my drawings as svg in Inkscape which has two dxf export options: AutoCad R.12 and AutoCad R.14. I'm assuming it depends more on the software used to program the cutter and what it can import to create the G-code. I've also read about assigning the cut in black but any etching in red. Is that a thing? Since I've got 15 similar bulkheads I think etching a part number onto them is important to avoid confusion. If I go this route I'd like to make it as easy as possible and less time consuming for the laser operator. As for material right now I'm thinking chipboard or something similar... 1.0 or preferably 1.5 mm thick. @clarkt reading the services provided by the Etsy laser-cutting vendors most of them seem to decline doing any cutting of metal. Looks like they'll etch but not cut. I'm thinking you'd have to go to a more industrial vendor. Photo-etch seems more practical. Seems like hobbyist photo-etch is fairly common.
  7. I once owned a rescue dog who needed a lot of behavioral work. So after some one-on-one sessions with a specialist we eventually graduated to attending obedience classes with others. I can’t say that we ever overcame all the issues (and I’m not sure who was training whom!) but I certainly learned the value of positive reinforcement. Consequently, since I have a tendency to be easily distracted and leave unfinished projects laying around, I wanted to reward myself for completing my first wooden ship model. While I enjoyed the wood model, my situation is perhaps not the best for them. Simply put, sanding wood makes too much dust for me to do in our living spaces and I really don’t have an interior space to do it. With the arrival of Winter sanding outside isn’t much of an option. So I’m putting off the next wood model until Spring and the return of good weather. So returning to my interest in card models I read up on the models produced by Tomasz Weremko, aka, Seahorse. Card models are certainly more apartment friendly than wood models and they are much more budget friendly. Level of detail, of course, is entirely in the hands of the builder and designer. While I’ve tinkered with designing and building my own card models, I’ve never actually built a commercially available kit. I still consider myself a novice builder and while I love the look of fully rigged ships I hesitate to commit to building one. I wanted something small, preferably in 1/72 scale to match my last model, and without too much rigging. I first decided that Searhorse’s Armed Virginia Sloop would fit the bill. However, its 1/100 scale means that some of the details are going to be quite challenging for my hand-eye coordination. I confirmed that by reading Clare Hess’ build log. (Mr. Hess’ log can be found here: https://shipmodeler.wordpress.com/2022/07/29/building-the-armed-virginia-sloop-paper-model-part-1/) But Seahorse also offers a US Revenue Cutter in 1/72 scale. In addition, according to Mr. Weremko’s complexity scale the cutter ranks as a ‘2’ as opposed to the sloop’s level of ‘3’. It ticks all the boxes! Did I mention the budget friendlyness of card models? I ordered both as full kits complete with laser cut parts, sails, dowels and (almost) all the necessary bits and bobs provided. Both kits and shipping from Poland came in at $72.00 USD. I ordered directly from the Seahorse web site on December 4th and eagerly awaited the arrival of the kits from Poland. After checking the tracking website daily (which stopped showing progress once the packages arrived in Los Angeles on the 9th) they arrived in my mailbox on December 16th. Mustering my dog-training discipline, I’ll save the sloop for later but I instantly opened the cutter package and reviewed the contents. As expected, there’s nothing disappointing about this kit. The basic model is presented as a saddle-stitched (e.g., stapled) booklet with full color photos of a finished model on front and rear covers. Ah, something to aspire to! There is, of course, a minimum of written text in both Polish and English comprising of a short history of the ship and ‘Basic Rules and Tools’ for construction. There are four pages of pictorial instructions, two pages of parts printed in black on white paper and two pages of parts printed in color on card. Now, in my set there was a second set of the card-printed parts inserted into the fold. I’m not sure if this was an oversight or if the second loose set was included because the printing of the first set (which is bound into the booklet) is a bit weak. Or, perhaps Seahorse can sense a ‘newbie’ and kindly included spares. Whatever the reason, intentional or not, it gives me a sense of security and a makes me think that Seahorse is a quality operation. (It’s also a bit unsettling that I joyfully anticipate looking at a centerfold of a model… ship!) There are a couple of hazards for neophytes. The first is that the required thickness of card for laminated parts is appended to the part number and is easily overlooked. The number is followed by ‘//’ or ‘*’ or ‘**’ to indicate 0.3, 0.5 or 1.0 mm card thickness. However, I think I’ve shielded myself from this potential error by purchasing the laser cut parts sheets. I’m also puzzled by this sentence in the instructions: “To avoid too many symbols, uncommon thickness of some parts should be matched to the width of the stripes covering its edges.” I can only assume that this refers to the keel which is considerably thicker than 1.0 mm and has a piece that runs along the bottom edge of the keel. That ‘edge’ piece appears to be about 4 mm wide so, therefore the keel should be laminated to that thickness. Now that I’ve typed that up it makes sense to me. I also see a couple parts with ‘W’ numbers which are not part of the printed sheets. I believe these need to be created from wire (which is mentioned in the ‘Basic Rules’). The templates for these parts are on the fourth page of instructions along with the mast and spar diagrams. The most numerous of these appear to be the rail stanchions surrounding the deck to prevent crew from falling overboard. My last observation is in regard to the copper sheathing below the waterline. It’s interesting that Seahorse has provided a simple solution and a detailed solution to the sheathing. On one side of the copper colored sheet the sheathing is designed as strips to cut and apply much like the hull planking. But if you flip the sheet over you find that it has been printed to represent the individual sheets of copper. So, depending up on your sense of fanaticism, er, level of detail, you have options. I like that. All said and done, I’m quite happy with my purchase. I’m not certain when I’ll get started on the cutter and the Virginia sloop is certainly farther down the line. (Maybe the sloop will be next Winter’s project.) At this point I’m still mustering my canine-induced self-discipline and working on resizing my skipjack design. But once I’ve hit the ‘proof-of-concept’ stage in that project it’s ‘game on!’ on the cutter. Pictures (or it didn't happen!):
  8. Hmm... yeah. Yowsa! Somehow I thought laser cutting would be less expensive than 3d printing. Doesn't seem to be the case. I see a couple Etsy vendors I might contact. Thanks for that suggestion. I don't really have a budget nor the space right now for my own equipment. It was mostly an idle thought as I rework my old skipjack card model design. But I could picture myself designing and selling laser cut models as a retirement activity in a few years. I enjoy the design work and if the equipment was robust enough to produce make-as-ordered kits it might help offset the expense. I'm sure making a profit is highly unlikely. Spending a couple thousand on the equipment isn't totally out of the question. Probably cheaper than golf as a hobby!
  9. Are there any laser cutting/die cutting services that cater to the hobbyist? Having built one laser cut wood model (and I'm awaiting some laser cut card models from Seahorse) I was wondering if there are any services that would laser from my own svg or dxf files for reasonable prices. Surely, there's someone out there in 'maker' world who does this? TIA
  10. Well, it took 7 hours to figure out how to do it but I was able to name the islands and identify the individual bulkheads in Blender. It's tedious, though, and duplicates work I already have to do when creating the model. I'd really like to have them auto-named from the 3d model part names. Oh, well. I kept simplifying and simplifying the model to try and get rid of the unrolling anomalies I was seeing. If that keeps up I may end up with a boat in the form of a cube. That would explain why all the tutorials for this Blender plug-in show you how to make a cube! Nevertheless, I think I've got enough to try a little proof-of-concept build just to see if the shapes are accurate. Maybe next weekend.
  11. Thank you, Frank. I suppose everyone has their own style which they impart to their models. We're all artists! Just not all of the same skill levels, of course 😉 Yeah, I threw away a number of those shroud thingies. Tiny, tiny, tiny.
  12. Hmmm... I've been tinkering with this. Most of the on-line examples of people using this Blender Plug-in are just simple models and the plug-in works just find. But how many card models of cubes do you need? Ships are a bit more complicated. So the workflow I've been following is to export my Wings3d model to *.obj format, import into Blender; Define where the seams will be on the various parts and then export the model via the paper-model plug-in to an *.svg document; Edit the document in Inkscape. There are challenges--even with the fairly simple hull form of the skipjack. First, what I really like about the plug-in is that it extracts the actual shapes of the polygons (well, triangles--the model must be triangulated) of the model and basically unrolls the model into 'islands'. The script I wrote years ago worked by extracting UV coordinates from the model but that opened a whole new can of worms as UV coordinates do not necessarily represent the true shape of the polygon. This leads to the first challenge. The 'unrolling' is not totally predictable. While you can mark where you want seams (e.g. edges of the 'islands'), the plug-in will not hesitate to add additional seams (or even add islands) if it determines that the island will not lay flat. I've found that I have to go back to the original model and tweak it in order to prevent unwanted seams. But by tweaking the model you also change the way the plug-in 'solves' where seams are needed. So it can be a very iterative process. I've not been entirely successful in getting rid of unwanted seams and islands. For example, the skipjack has a port and starboard bulwark. In the model, the geometry of each is identical except that they face opposite directions. Yet the plug-in resolves them differently--even though one bulwark is a duplicate of the other. In fact, while it resolves one bulwark as a single island, it insists on taking one triangle from the other and making it a separate island so that that bulwark consists of two islands while the opposite one is only one. Frustrating! I've also had the situation where the plug-in does not recognize two separate islands if they share a single vertex. (Actually, I don't think they share the vertex. In the original model it's two vertices that are located at the same coordinates.) I've not found a solution for this--it could be a Wings export or Blender import issue that merges the two vertices. The second challenge is that while the plug-in will generate glue tabs and labels for the islands they really aren't very usable. I'm not too concerned about the tabs because I'd rather create them when I undertake the graphics work in Inkscape. But it would be nice to be able to name the islands or better yet have the plug-in recognize the names of the parts in the model. When creating the *.svg file the plug-in places the islands rather randomly on the page. Without labels it can be difficult to determine which bulkhead is which. There are 15 of them in the skipjack model scattered across the *.svg file. This would be a significant issue with a more complex model. Thirdly, it seems that all the parts that you want to unroll have to be joined into a single part for the plug-in to be able to solve them. At this point I haven't found a way to undo that joining in Blender. So if I need to tweak the model, in essence I need to go back into my modeling program to do it. So for every change prompted by the results of the plug-in I need to tweak the model, export the model, import the model, reapply the seams and export to *.svg to see the results. I'm sure this is partly due to my knowing just the bare basics of Blender. That's because I've always found Blender work-flows to be terribly labor intensive. Catch 22. While this sounds like a lot of whining I'm still optimistic. I guess worst case/best case scenario is that I can maybe translate the plug-in's Python code for unrolling and implement them in my old Ruby script. Or, maybe I finally learn Python and Blender and fix the 'challenges' myself in the plug-in. Ultimately, though, I'd rather be making models! None of these issues are show-stoppers. Yet. Here's a re-arranged sample of the Blender's *.svg output. This is a 1/72 scale rendition shown on a 8.5x11in page:
  13. So I've been thinking about reviving a project I started years ago: a Chesapeake Bay Skipjack card model. I originally modeled it in Wings3d (which I still use frequently) and wrote a script to extract UV coordinates from the 3d model and convert them to *.svg files which could then be printed out and assembled into a card model. Not being very good at 3d math, however, posed some real challenges in the writing the script which I was never able to completely solve. At the time there weren't many options for converting a 3d model to a card model except for Pepakura--but since I don't operate any Windows computers that was not available to me. I've noticed that Blender now has an add-on that that seems to duplicate what my script did. But perhaps better? I've tinkered with it a little bit but I'm wonder if there's enough potential to continue. Blender being rather infamous for dumping you into the deep end right off the bat. So has anybody come to grips with the add-on? Is it reliable?
  14. Yep, right there with you. That first build is more about learning what you didn't know but thought you did! Congrats on finishing. On to number two.
  15. Thanks, everyone. I'll sit back and contemplate my next build. While I've got the Dusek bireme staring at me it will require sanding which I'll need to do outdoors. So I might wait until late winter to start that. Meanwhile I started designing a card Skipjack years ago which I abandoned. But the force is strong with this one!
  16. This is such a cool enhancement. Thanks for sharing your idea!
  17. FINISHED! Took a bit longer than anticipated but finishing the build was important to me. I can be a bit like a hummingbird with my hobby projects. I didn't take pictures of the rigging process. I found the rigging frustrating. I can't imagine trying something more complex rigging-wise for quite some time. Some of the challenges are non-negotiable--like my eyesight--but having better tools and materials would probably help. I used string which I had on hand but I couldn't tell that it was any different than what was provided in the kit. Plus, mine was on a spool rather than wrapped around a card and had less kinks in it. However, my string is nylon and I found that knots slipped too easily and the thread always wanted to resume its curl. Basically, it was difficult to manipulate. I also found that the thread unraveled if I looked at it cross-eyed and once I clipped an end the thread tended to fray. Tool wise... I've only got one pair of tweezers small enough for this work so last night I found myself looking at surgical needle holders on-line. I think those will help. I also need a better way to cut the string. I have a little pair of squeeze scissors but unless the string is under tension they tend to chew through the string rather than cut it. Overall, I think my rigging is pretty rough. Especially the lines attaching the sail to the spar. I keep telling myself that this is a learning project and I learned a lot! What I did find very helpful is that I've got two LED lights on flex-stands that stick out over the work surface. Having the ability to hang lines from the light supports proved beneficial. I could even cut a number of lines and drag the ends through CA then drape the lines over the lights to let them dry. It kept them out of the way until needed. Same thing for my 'helping hands' with alligator clips. Just being able to keep tension on the lines by clipping them with the alligators and setting the 'hands' off to the side was helpful. Anyway. I'm calling this one finished. Overall, I'm pretty happy with it. It's been a (mostly) enjoyable voyage. I'd recommend this kit to others at a beginning level. I might even see if I can find some 1/72 scale Vikings to crew her!
  18. Yeah, I've seen the diamond shape lines on the rock carvings. I always assumed they were probably some type of netting to provide strength to the sail. I did (briefly) consider doing something like that but I'm glad I didn't!
  19. Oh, I agree in regards to looking at ships and boats as machines with various systems. Painted Ocean looks cool. But.. ah, Windows only. I haven't run microsoft stuff for 10 years or so. I'm pretty wedded to open source these days. --jeff
  20. Great job, Martes! I think we've traveled parallel paths in regards to sail simulators. I got started in 3d modeling long ago making models for the proprietary but mod-friendly Virtual Sailor--version 2 if I remember correctly. I eventually got tired of being limited by a closed system and started looking for alternatives. Every sim system seems to come up short on capabilities or it veers off into fantasy in the search for marketability. Most recently, though, I've been tinkering with the open source fight simulator FlightGear but with boats. (I call it FloatGear.) So far I've imported some of my old models into the simulator with various levels of success and various features. Granted, there's a steep learning curve and I've barely scratched the surface--the challenge is really in the scripting and programming realm rather than the modeling. I consider everything I've done so far simply to be proof-of-concept stuff but I'm convinced Flightgear can be a decent sailing simulator. 'Real Life TM' has temporarily derailed me from working on it for the past couple of months but I do intend to get back to it. Most recently I was working on implementing waves in the simulator. Anyway... You might consider looking into it. I posted a couple in-sim screenshots when I joined MSW:
  21. Instead of installing the standing rigging I decided to see what I could accomplish with the sail. Since I wanted to paint the sail I knew that regular 20# paper wouldn’t work as it would simply buckle with the application of water-based acrylic paints. So, I ordered some ‘mixed media’ paper. Turns out this is 120 lb, 200 g/m2 drawing paper which took the acrylic paint just fine. I had drawn up the design on the computer and simply printed out the outline on the new paper. I then painted it in with craft acrylics. I thought about impressing the vertical panel lines into the sail after painting but decided they probably wouldn’t be noticeable within the vertical stripes. I did cut and glue small strips to represent reefing bands. I guess it’s somewhat debatable as to whether Viking ships used reef points but I figured if the Danish Viking Museum is using them on their reconstructions… it’s good enough for me. The next step was to give the sail some shape. For this I used a broad paint brush to moisten both sides of the sail with water, placed it between two sheets of wax paper and then used rubber bands to wrap it around a one gallon bleach bottle. I quickly noticed that while the moisture didn’t affect the acrylic paint, the same was not true of the printed outline. The ink quickly ran and muddled up the sail. To be honest, though, this didn’t bother me. I thought the colors were too bright and the washed out ink toned them down a bit. The sail was left bound to the bleach bottle for 24 hours to dry. On to the rope work! I used some tan nylon thread left over from a previous project. I first stretched the thread by attaching a binder clip to one end of it and letting it hang from an elevated point. While it was hanging I worked some diluted PVC glue into the thread with my fingers and let it dry over night. This takes the curl out of the thread and makes it easier to work with. I also smeared PVC over the edges of the sail and let that dry to enable a quick bind when gluing the rope to the sail edge. Finally, I glued the thread to the head of the sail, looped it at the corners to form the cringles and then down the sides and foot leaving loops for clews. Bolt rope complete. I then drilled holes for the reef points using a pin vice and ran short lengths of thread through the holes with a dab of PVC to keep them in place. Getting the reef points to lie down was a PITA but I eventually dabbed some PVC to the underside and held them in place with painter’s tape until dry. Notice that I wasn’t very successful in trimming the reef points to consistent size. The final step was to coat the entire sail with acrylic matt medium to give it a consistent finish. I’ve found that I’m not terribly neat with my application of PVC and the matt finish hides the telltale signs of shaky hands and poor eyesight!
  22. A great looking no-sew cloth sail! Thanks for posting that. You've got my wheels spinning now.
  23. Thanks, Frank. I've been enjoying the build and enjoying learning about Norse vessels. The sail as provided was just a swatch of off-white cloth. No stitching, no hem, no bolt rope. There's nothing in the instructions about preparing the sail but the first appearance of the sail in the instructions does show the bolt rope. C'est la vie! But I'm happy to experiment with making a paper sail. In fact, I have a card skipjack I was designing a few years back that stalled because I didn't know what to do for sails so there's 'additional value' to this project.
  24. Pulling up a chair to watch! I'm still considering this model as a second build so it's nice to watch someone else's progress.
  25. After spending a lot of time at the Vikingeskib Museet boat collection web site I decided that the bare wood of the model would look better with more color than I had originally intended. So, I painted the Sliepnir with the acrylics I had on hand. I've been studying the rigging instructions and the photographs at the museum and I'll probably start rigging today or tomorrow. I was shocked that I was able to drill the required holes in the comma-shaped pieces that are used to tighten the lines. These holes are parallel to the surface of the wood, through 1mm thick pieces. I'm still not convinced I'll be able to run lines through them but we'll see! I've rigged a fair number of 1/600 scale AOS ships but I think the larger 1/72 scale will be a bit of a challenge. The earlier ships were war-gaming models so it mostly just running thread from point to point. Not much in tying things off realistically. I'm still working on the sail. I've decided on a design for the sail, and I have the materials ready but I've not yet decided exactly how to do it. I have decided to create a paper sail, striped with ochre and terra cotta (my test can be seen in the overhead shot below). Superimposed overall with be a silhouette of Odin's horse, Sliepnir.
