RGL
Everything posted by RGL
  1. There a 2 sets of Smaller guns that have PE barrels which I replaced
  2. Main guns, there is a nice little motto on the side of the aft gun
  3. There are 6 high altitude AA guns, the kit is quite nice, but the barrels get replaced and I’ve added some extra panels on top (I would have required some surgery to cut the panels out.
  4. Hahaha description! You are kidding. You know as well as me there is a lot of ‘interpretive dance’ in Chinese instructions. ive gotten quite/ bit done this block of days off. Deck fittings next. Then ships boats, then I can step and rig the mast.
  5. No I’m just going to replace it. The problem is I tried to peel it off the plastic backing thinking it was an adhesive deck which it wasn’t
  6. I’ve glued down most of the painted bits now except for the rear building as I’ve ripped off the horrible deck and will replace it.
  7. Added a bit of rust and the focsle, replaced the capstans with one that is a bit more accurate
  8. Weathering starts. Grime, filters washes. I feel much more comfortable now it’s a bit dirty a. Rust next.
  9. It’s not that it’s bright as rubbish. It has to be glued down which just does not work well.
  10. The stick down wooden deck. Isn’t stick down. First one I’ve come across. The plastic backing will come off, but it is not adhesive and it’s wafer thin. A lot of slicing and inserting glue needed.
  11. Dryfit. Now time to go to work to try and make it not look like a toy
  12. Grey day. The main burg prices are now done. I want it to dry overnight then I can start filters etc.
  13. Now back to the bridge. I only figured out what was changed by 1941 after I finished the bridge. there is a cabin behind the directional finder. I cannot pull the entire thing to pieces, so I've just added a cabin.
  14. I’ve really had too much on at work and home to do much on her. Once I can finish the main top mast I can go back to painting.
  15. As much as I hate bashing kits, no one will notice until they do. I joined an Italian warship group on FB and it was correctly pointed out.
  16. As you can see, the side range finders are gone as of post 1939, there is a big fuel or water tank underneath and a gantry alongside the funnel. the crew has places life vets on the railings and canvas dodgers (I’m not doing that)
  17. It does not look as good but the rangefinders were removed in 1939
  18. So, after all that, the range finders on the side were removed in 1939, so a bit more bashing required.
  19. Mainmast, part a. Tripods armrest horrible things to build, the housing is added to a bit as there appears to be another cabin added on top by wartime. Top mast next
