Steve 12345
Everything posted by Steve 12345
  1. Hi Doug the photos seemed to come out the reverse of how i posted them try looking at them from bottom to top the paper is infact doublesided tape used to stick the line to the board when wrapping the trawl doors are the strange looking device the winch operates
  2. Hello all bit more final touches completed ive done some of the winch lines and various ropes as for the trawl doors im not satisfied with the look of the 2mm brass surround i have decided to remake these using one of them i removed the brass and added 3mm to the bottom and 3mm to the side then i was able to use this as a template to create two new doors 1mm shy of the door with fitted brass wire i will next attach 0.5mm brass all around doors and see how that looks
  3. Yeah doug back to the bounty looking forward to it still got couple more we surprises with the mare on the cards tho
  4. finish applied to fishboxes I have build the trawl doors however they are having finish applied at present so I have completed and rigged winch gallery as the build begins to come to a close there will be no more parts to make I have included a pic of left over parts
  5. fish boxes just temp at the moment still have to visit the sand and paint department think I will ca them in place so many logs depict the two top ones slightly out of place think im a wee bit to ocd for that mine will be nicely stacked
  6. base for winch and the fish boxes complete next I will turn my attention to the trawl doors
  7. Challenge accepted ! Just kidding racing leads to mistakes take your time and enjoy
  8. Thank you harry for the kind comments and checking in it was your build that inspired me to choose the mare nostrum
  9. hope this diagram helps Derek only make your spacing 10 mm or 3/8 kind regards steve
  10. Thanks Rob Indeed looking at the frizzy line lets her down a bit I may redo the rat lines as there is so little of them
  11. Came across this kit a few times will be keen to follow and see how it builds up
  12. Had a think about the last question I posted about the rigging it's no Hms victory if I run out I'll just strip it off and redo but the provided stuff looks plenty
  13. How did anybody go for rigging thread on this ship ? If there is a hint the provided stuff will run out unless used conservatively then I will purchase my own hate running out then trying to match the provided stuff thanks Steve
  14. Hi Harry I did the stanchions first then kept the inside of handrail flush with them
  15. Hello all nice productive weekend managed to plank the inner bulwarks fit the vertical stanchions which is changed to 3x2 instead of 3x3 and managed to get the handrails fitted
  16. Giving it some thought fitting the hand rail first would mean you get the advantage of fitting each upright one at a time fine tuning as required I've put some thought into it I'm not impressed with the kit recommendations the handrail doesn't meet it just butts against the keel leaving an ugly space between I think I will recess the two handrails in so they meet also I don't like how the uprights prutred the hand rails the kit calls for 3mm x 3mm ill will use 3mm x 2mm I think I will fit the three by two uprights first then try the modified handrail using the ply wood originals and see how that works I'll post pics tomo night with how it turns out
